Software Archive
Read-only legacy content
17060 Discussions
C# application development with UPnP tools
postaquestion
I am developing a C# application and using UPnP.DLL provided with "Tools for UPnP Technologies".
I can iterate all devices on the network using UPnPSmartControlPoint class and using upnp:rootdevice as the matching filter.
But i don't know how to use Rescanning logic. If I call Rescan function of UPnPSmartControlPoint class; it does not iterate devices on the network. It even doesn't call the delegate function.
Intel_Software_Netw1
The rescan doesn't work that way. What rescan does, is issue a newsearch. Devices that were not discovered previously will get evented as anewly discovered device. Devices that were previously discovered but do notrespond to the search, will get evented as a device that was removed.
If you simply want to iterate the devices that were already discovered,there should be a property on the smartcontrolpoint for that.
Gina B.
Intel Software Network Support
http://www.intel.com/software
email: ISN.support@intel.com
Intel is a registered trademark of Intel Corporation or its subsidiaries in the United States and other countries.
*Other names and brands may be claimed as the property of others.
bmaduskar
please can i have that sample code.
i m also using C# for the UPNP
