Software Archive
Read-only legacy content
17060 Discussions
CILK_NWORKERS don't have impact when using cilk_for
amina-jarraya
I use a loop for with cilk_for and when i run my program i use the CILK_NWORKERS to specify the number of workers.
So, when runnig, i see that my loop for is always divised on two workers even i set 8 or another number on the parameter CILK_NWORKERS.
How can i divise my loop for on 2, 4 or 8 workers ?
Thank you,
Barry_T_Intel
cilk_for uses a hueristic to determine the "grain size" that is used by the recursive divide-and-conquer algorithm. The code is in cilk-abi-cilk-for.cpp, if you've got the sources from the cilkplus branch of gcc. Roughly speaking, it's:
Px8 = 8 * g->P * 8;
grain = (loop_count + (Px8 - 1)) / Px8;
Where g-> is the number of workers.
So my first question is, how sure are you that you've specified CILK_NWORKERS correctly? You can use __cilkrts_get_nworkers() to get the number of workers that the Cilk runtime created (or will create).
Then there's the question of how you know how many workers are working on your loop?
- Barry
amina-jarraya
I change successfully the number of workers dynamically by calling__cilkrts_set_param befor my loop as follwing :
__cilkrts_set_param("nworkers", "2");
printf ("nworkers : %d \n", __cilkrts_get_nworkers());
__cilkrts_init();
cilk_for(int k=0;k<50;k++) {.....}
It works fine :)
Thank you,
Barry_T_Intel
I'm glad to hear that your code is working now.
Be aware that if you want to change the number of workers during a run, you have to do the following:
  1. Make sure that *ALL* threads have returned from their spawning functions (functions containing a _Cilk_spawn statement).
  2. Call __cilkrts_end_cilk() to have the runtime shutdown. If there are *any* threads running a spawning function, the applicaiton will be aborted with an error message.
  3. Call __cilkrts_set_param("nworkers", "value") to set the new number of workers to use
The next call to a spawning function will automatically restart the runtime with the new number of workers.
- Barry
amina-jarraya
Thank you a lot for your advices,
John_Forrest
I am having a similar problem using gcc-4.7.
To make sure I was not doing something stupid, I downloaded an old version of Cilk++ SDK and used two of the examples qsort and cilk-for. Using Cilk++ SDK both scale nicely to four workers.
If I use gcc-4.7 qsort still scales well, but cilk-for only scales to two - I am printing out the number of workers using __cilkrts_get_nworkers().
John Forrest
Balaji_I_Intel
Hello John,
Can you please tell me the location from where and whenyou downloaded the Cilk Plus sources?
Balaji V. Iyer.
John_Forrest
Balagi,
I am using gcc/branches/cilkplus-4_7-branch (svn at revision 186706). Using the libcilkrts created by compiling that was even worse, so I downloaded cilkplus-rtl-001857.tgz.
I am running 64 bit Ubuntu 11.10 on an Intel CORE I7.
Thanks for any help.
John
Balaji_I_Intel
Hello John,
Can you please download the one from gcc/branches/cilkplus and try? It is the most up-to-date one.
Balaji V. Iyer.
John_Forrest
Balaji,
Downloaded but no luck.
I downloaded
URL: svn://gcc.gnu.org/svn/gcc/branches/cilkplus
Repository Root: svn://gcc.gnu.org/svn/gcc
Repository UUID: 138bc75d-0d04-0410-961f-82ee72b054a4
Revision: 186880
Node Kind: directory
Schedule: normal
Last Changed Author: bviyer
Last Changed Rev: 186838
Last Changed Date: 2012-04-25 20:27:55 +0100 (Wed, 25 Apr 2012)
I built it
../cilk/configure --prefix=/j/mycilk \
--libexecdir=/usr/lib \
--enable-__cxa_atexit \
--enable-clocale=gnu \
--enable-languages=c,c++ \
--disable-multilib \
--disable-bootstrap \
--with-system-zlib \
CFLAGS="-fPIC \
-march=x86-64" \
AS=/usr/local/bin/as AS_FOR_TARGET=/usr/local/bin/as LDFLAGS=-L/usr/lib/x86_64-linux-gnu
Tried with previous runtime library from cilkplus-rtl-001857.tgz
john@fasterCoin2:~/trunk/debug2/Clp/examples$ export CILK_NWORKERS=4;time cilk-for
Iterating over 10000 integers
real 0m4.511s
user 0m11.609s
sys 0m5.872s
john@fasterCoin2:~/trunk/debug2/Clp/examples$ export CILK_NWORKERS=2;time cilk-for
real 0m4.352s
user 0m8.517s
sys 0m0.052s
john@fasterCoin2:~/trunk/debug2/Clp/examples$ export CILK_NWORKERS=1;time cilk-for
real 0m8.634s
user 0m8.509s
sys 0m0.004s
So 2 looks good but 4 is bad
with libcilkrts from cilkplus build
real 0m8.726s
user 0m13.745s
sys 0m20.757s
real 0m8.651s
user 0m10.117s
sys 0m7.080s
real 0m8.663s
user 0m8.537s
sys 0m0.012s
Not good at all
showing that qsort example i.e. spawn is fine
john@fasterCoin2:~/trunk/debug2/Clp/examples$ export CILK_NWORKERS=1;time qsort
Sorting 10000000 integers
real 0m8.791s
user 0m8.593s
sys 0m0.020s
john@fasterCoin2:~/trunk/debug2/Clp/examples$ export CILK_NWORKERS=2;time qsort
real 0m5.586s
user 0m9.509s
sys 0m0.244s
john@fasterCoin2:~/trunk/debug2/Clp/examples$ export CILK_NWORKERS=4;time qsort
real 0m3.686s
user 0m9.521s
sys 0m0.512s
Any suggestions?
John Forrest
Balaji_I_Intel
Thank you for the descriptive message. I will look into it and get back to you!
-Balaji V. Iyer.
