Software Archive
Read-only legacy content
CLI 5.1.1 Build Fail : PushWoosh
Miguel_R_1
5.1.1 CLI failure in 4.2 works well, I think missing dependencies on the new server
Using PushWoosh Plugin.
* What went wrong:
A problem occurred configuring root project 'android'.
> Could not resolve all dependencies for configuration ':_debugCompile'.
   > Could not find any version that matches com.google.android.gms:play-services-gcm:+.
     Searched in the following locations:
         https://repo1.maven.org/maven2/com/google/android/gms/play-services-gcm/maven-metadata.xml
     Required by:
         :android:unspecified
   > Could not find any version that matches com.android.support:support-v4:+.
         https://repo1.maven.org/maven2/com/android/support/support-v4/maven-metadata.xml
     Required by:
PaulF_IntelCorp
Yes, those library files are not available on the server. :(
  • Could not find any version that matches com.google.android.gms:play-services-gcm:+.
  • Could not find any version that matches com.android.support:support-v4:+.
I haven't had a chance to try this, but try including the Google Play Game Services plugin in the Featured plugin list, I think it will include the required library for you.
Tony_J_
hm.. I have the same issue..  for my particular case, my app isn't a game so I don't want to go through the process of adding the Google Play Game Services plugin.  Are there any other workarounds?
Miguel_R_1
does not work =/
PaulF_IntelCorp
I was afraid of that, thanks for checking. I'm bringing this issue up so we can find a resolution.
Amrita_C_Intel
Upgrade XDK version to 2548. And try creating new project and include this version of pushwoosh.And see if it works.
Pedro_O_
I´m have the same problem.
Today i´m update the pushwoosh plugin to the latest version and try build again.
You can help me?
Miguel_R_1
It Doesn't Not Work =/
FAILURE: Build failed with an exception.
* What went wrong:
     Required by:
     Required by:
* Try:
Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
PaulF_IntelCorp
