Software Archive
Read-only legacy content
17060 Discussions
Calling Conventions in Fortran
Intel_C_Intel
Hi!
Ich try to write a dll in Fortran that exports function having strings as parameters to be used in a Fortran program. But I doesn't work!!! Can somebody give me an example of this? Thank you!
Below are parts of my Fortran code. Where is the error?
interface
logical function LoadInterActionParameter(Anco, Ansteu, &
     &	AMixRule, Atblock, k, la, l, s, kkap, kep, Aexdataname)
!DEC$ IF DEFINED(_X86_)
!DEC$ ATTRIBUTES STDCALL, ALIAS : '_LOADINTERACTIONPARAMETER@48' :: LOADINTERACTIONPARAMETER
!DEC$ ELSE
!DEC$ ATTRIBUTES STDCALL, ALIAS : 'LOADINTERACTIONPARAMETER' :: LOADINTERACTIONPARAMETER
!DEC$ ENDIF
!DEC$ ATTRIBUTES REFERENCE::Aexdataname, Anco, ansteu
DEC$ ATTRIBUTES REFERENCE::AMixRule, Atblock
!DEC$ ATTRIBUTES REFERENCE::k, la, l, s, kkap, kep
character*(*) AExdataName
integer Ansteu, AMixRule, Atblock, Anco
double precision k(10,10), la(10,10), l(10,10)
double precision s(10,10), kkap(10,10), kep(10,10)
end function
end interface
logical function LoadInterActionParameter(Anco, Ansteu, AMixRule, Atblock,    &
&                 k, la, l, s, kkap, kep, Aexdataname)
!DEC$ ATTRIBUTES DLLEXPORT::LOADINTERACTIONPARAMETER
!DEC$ ATTRIBUTES REFERENCE::Aexdataname, Anco, ansteu, AMixRule, Atblock
implicit none
integer xnsteu, xmixrule, xkt, Anco
character*(*) Aexdataname
  LoadInterActionParameter = .false.
! Body
end function
Jugoslav_Dujic
Valued Contributor II
Please never use the term "doesn't work" (especially not followed by !!!). Doesn't compile? Doesn't link? Causes your application to crash? Causes your computer to burn?.
With combination STDCALL+REFERENCE on string arguments, length of
the string is not passed. Thus, you have to "hard-code" string length in the callee, i.e. CHARACTER(LEN=50).
If you intend to use it only from Fortran caller, STDCALL, REFERENCE and ALIAS are not necessary (but do no harm as long as they're consistent). In the actual case, if you omit STDCALL, your declaration of character variable could retain standard (LEN=*).
Jugoslav
Intel_C_Intel
Thank you for your answer, Jugoslav!
I could solve my problem with giving the length explicitly (Len = 50 etc.). Can I find somewhere a WORKING example of how to use functions with strings from a DLL in Fortran?
Thank you!
Stan
