Software Archive
Read-only legacy content
17060 Discussions
Camera stopped working
James_M_5
I recently started using the RealSense F200 camera on a computer running Windows 8.1 Enterprise. I followed some setup instructions and got everything working properly. I was even using it successfully in Unity. However, the camera eventually stopped working for no apparent reason. The sample programs (which had all been working up to this point) displayed the message "Init failed" when I tried to use them. I eventually uninstalled the SDK and DCM. When I tried to reinstall DCM 1.3, I got the following error message:
"Intel RealSense 3D camera firmware update failed. The installer failed to update the firmware of your Intel RealSense 3D camera. The camera firmware may be corrupted. Contact your computer manufacturer for recovery instructions. Error code: -4"
I then tried to install DCM 1.2 and got the message "The installer failed to detect an Intel® RealSense™ 3D Camera on this system. The installation was terminated". I checked the device manager and the camera was still being detected (it was plugged into a USB 3.0). Finally, I tried installing DCM 1.3 and 1.2 on a different computer and got the same errors. Looking at the device manager, the camera was being detected on that computer as well.
Is there anything I can do to get it working again? Any help is appreciated.
Xusheng_L_Intel
James, could you send the installation log to us so we can do further investigation? You can find DCM installation folder @%temp%\micl_tmp_<yourlogin>%temp%\micl_tmp_<yourlogin> Thanks!
Nicy_T_
I have installed DCM v1.3 and Intel RealSense SDK R3. My Visual Studio 2013 Hello World app runs successfully but the camera does not get started on clicking start button.
Can anyone suggest how to get the camera on????
Moreover, while running sample codes in RealSense SDK, the camera does not start up. It only start up in camera viwer sample but does not work for other samples.hw.png
James_M_5
David,
I sent you the installation log in a private message about a week ago. Did you receive it?
