Software Archive
Read-only legacy content
17061 Discussions
Can I use MPI within Parallel studio xe 2011, and how?
gbliu
Hello everyone,
I installed the Parallel Studio XE 2011 non-commercial verison for linux on a linux cluster (64bit, non-root mode). However, after installation I found that there were no MPI compiler. How can I use MPI within Parallel studio xe 2011? I note that there is a "Intel Cluster Studio 2011 for Linux" which contains MPI, but it seems there is no non-commercial version of it.
BTW: After installation of Parallel Studio XE 2011, following info is shown:
Intel Math Kernel Library 10.3 Update 4 for Linux*
(for applications running on Intel 64) component... failed
But there are a lot of files under path "~/intel/composerxe/mkl/lib/intel64". So I'm confused that, is the mkl for intel64 installed successfully? Can I use it securely?
