Software Archive
Read-only legacy content
17060 Discussions
Can XDK's project be build by cordova or phonegap CLI command?
gloCalHelp_com_G_
Hi,  because there are several times that XDK's build can not connect to server,
moreover, to prove XDK's API fundament is crossplatform, can  Can XDK's project be build by cordova or phonegap CLI command?
If developer can use Phonegap or other mobile crossplatform to build, then what are the steps to build XDK's project by using
other third party tools?
Brandon_K_Intel
We currently do not a command line interface for the XDK builds. This is something that has been discussed. I, unfortunately, cannot give you a definitive answer at the moment concerning the CLI. We are working to make sure the XDK build servers have consistent uptime.
