Software Archive
Read-only legacy content
Can not detect the camera as image device
Kaven_S_
            Hello! I got some problems when I install the driver of the realsense 3d camera.As the camera connected to the computer,the system installed the driver automatically,but when I browsed the device in the device manager,I found that the camera was identified as audio equipment and the imamge device was empty. Then I installed the driver downloaded from "support.creative.com/Downloads/searchdownloads.aspx?filename=C3DG_0800_PCAPP_DRV_EN_1_00_07a.exe&ShowDetails=1". The problem still exists.I got the error "we can't find the real sense 3d camera in your computer" when I run the camera manager.
            I hope your response could solve the problem,thank you!
Xusheng_L_Intel
You should download the DCM and install the DCM. DCM can be found @https://downloadcenter.intel.com/download/25044/Intel-RealSense-Depth-Camera-Manager-DCM-. Thanks!
Kaven_S_
David Lu (Intel) wrote:
You should download the DCM and install the DCM. DCM can be found @https://downloadcenter.intel.com/download/25044/Intel-RealSense-Depth-Ca.... Thanks!
When I installed the DCM,it told me can not find a 3D camera in your computer.
Shivang_D_
Which camera are you using? You can use sdk_info.exe from {RSSDK}\bin\x64 to check what all you are missing.
Shivang
NBans1
I am trying to install DCM, but it gives me error of "Firmware upgrade failed" and setup ended prematurely.
Snapshot is attached, Please guide me.
Even I can not see the Real sense camera in Imaging devices under Device Manager.
