Software Archive
Read-only legacy content
Can not ping to mic when using Internal bridge
Xiao_peng_W_
When I was using Internal bridge, sometimes (not sure how to recreate it) after reseting configuration of mic, I could NOT ping to the mic. On mic, from ifconfig command, there were a lot of dropped packages. reboot host node could resolve the issue. Any idea?
mic0      Link encap:Ethernet  HWaddr 36:6C:E7:6E:B3:5D
          inet addr:192.168.1.31  Bcast:192.168.1.255  Mask:255.255.255.0
          UP BROADCAST RUNNING  MTU:64512  Metric:1
          RX packets:2508 errors:0 dropped:1155 overruns:0 frame:0
          TX packets:27 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:327172 (319.5 KiB)  TX bytes:1350 (1.3 KiB)
TaylorIoTKidd
Your issue was lost.
Do you still have this problem?
Taylor
