I've tried to fix this problem. I understand that it might a known issue. However, the solutions are too technical for me a -- a simpler computer user.
If someone could please tell me how to fix it -- as simply as possible -- I'd be appreciative. I spent $1400 for the computer set and I'd like to get it work.
I appreciate all help.
I really do.
It might, but he may have to tweak the settings a bit because it's a different brand of monitor. The first value in the list (last two digits of the pixel clock) can be tweaked up and down to get the monitor working, but there's also differences in sync pulse width and offsets which vary from manufacturer to manufacturer, model to model, and even interface to interface (VGA vs DVI vs HDMI). For instance, on the LG 204WT, the manual suggests using a horizontal scan of 65.290 kHz for digital, and 64.674 kHz for analog... which means that the settings have to be different for VGA and DVI. How they are different is, alas, not clear.
If you can find a Linux Modeline for your monitor or the PowerStrip settings at 1680x1050, I can probably help you construct the right DTD settings... butoften the pixel clock is the trickiest.
Model name............... L204WT
Manufacturer............. LGE
Plug and Play ID......... GSM4E48
Serial number............ 341125
Manufacture date......... 2007, ISO week 9
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 430 x 270 mm (20.0 in)
Power management......... Standby, Suspend, Active off/sleep
Extension blocs.......... None
DDC/CI................... Supported
MCCS revison............. 2.0
Display technology....... TFT
Controller............... Not supported
Firmware revision........ 0.1
Firmware flags........... 0x68
Active power on time..... Not supported
Current frequency........ Not supported
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.651 - Ry 0.333
Green chromaticity....... Gx 0.277 - Gy 0.614
Blue chromaticity........ Bx 0.145 - By 0.082
White point (default).... Wx 0.313 - Wy 0.329
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 28-83kHz
Vertical scan range...... 56-75Hz
Video bandwidth.......... 150MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1680x1050p at 60Hz
Modeline............... "1680x1050" 146.250 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync
Standard timings supported
720 x 400p at 70Hz - IBM VGA
640 x 480p at 60Hz - IBM VGA
640 x 480p at 75Hz - VESA
800 x 600p at 56Hz - VESA
800 x 600p at 60Hz - VESA
800 x 600p at 75Hz - VESA
832 x 624p at 75Hz - Apple Mac II
1024 x 768p at 60Hz - VESA
1024 x 768p at 75Hz - VESA
1280 x 1024p at 75Hz - VESA
1152 x 870p at 75Hz - Apple Mac II
1280 x 1024p at 60Hz - VESA STD
1280 x 960p at 60Hz - VESA STD
1152 x 864p at 75Hz - VESA STD
Report information
Date generated........... 10/07/2009
Software revision........ 2.30.0.797
Operating system......... 6.0.6001.2.Service Pack 1
Raw data
00,FF,FF,FF,FF,FF,FF,00,1E,6D,48,4E,85,34,05,00,09,11,01,03,EA,2B,1B,78,EA,D1,05,A6,55,47,9D,25,
15,50,54,A7,6B,80,01,01,81,80,81,40,71,4F,01,01,01,01,01,01,01,01,21,39,90,30,62,1A,27,40,68,B0,
36,00,B2,0E,11,00,00,1C,00,00,00,FD,00,38,4B,1C,53,0F,00,0A,20,20,20,20,20,20,00,00,00,FC,00,4C,
32,30,34,57,54,0A,20,20,20,20,20,20,00,00,00,FC,00,0A,20,20,20,20,20,20,20,20,20,20,20,20,00,ED
Report information
Raw data
I've found the solution to my problem... I was using DVI-D Dual link cables. Took the monitors to a computer guy today for some back to back testing and to verify my problem... he tested my monitors with my leads and it totally failed exactly the same as on my computer at home.
Then he pulled out a single link DVI-D cable and PRESTO! Instant video at the correct resolution.
So it seems that while the dual link cable will tell the monitor to expect a picture, the picture goes missing along the way.
Anyway, solved my own problem... bought 3 x DVI-D single link cables and I have all three monitors working perfectly.
