Software Archive
Read-only legacy content
17060 Discussions
Can't install Amplifier XE update 13
Patrick_Frants
I installed "Intel Parallel Studio XE 2013" for which we have a license. Problem is it contains an older version of the Amplifier component. Now I want to install update 13 (which appears in the Intel Software Manager, implying that I can install it). During install I choose "alternative activation" and "use a license manager", because we have floating licenses. When the installer asks for host and port and I press "Next", it shows a dialog box with "The license file provided is invalid".
So it seems I can't upgrade one of the components of the "Intel Parallel Studio XE 2013" suite, while it is clear that the Intel Software Manager implies that I can. Looks like a bug to me.
Any comments?
Sukruth_H_Intel
    I have sent you an license file for your registered email-id :- patrick.frants@quintiq.com . Could you please try the following :-
1. Save the *.lic file that you receive through email.
2. While installing at "Activation stage", could you try using "Choose Alternate Avtivation" --> "Activate using lic file" and then browse to the lic file that you saved in step1.
Please do let me know if this resolves the issue.
Sukruth H V
