Software Archive
Read-only legacy content
17060 Discussions
Can't run MeasurementSP sample
Tony_X_
I am new here.  I just set up the system.  I have run most samples without problem except this one.
This line always returned false.
if(!pScenePerceptionController->InitPipeline())
Any ideas?  Please.
I traced into code and did not help.
I copied some code here, all original.
int wmain(int argc, WCHAR* argvW[])
QueryPerformanceFrequency(&clockFrequency);
printf("SP_MeasurementTool: Starts.\n");
pScenePerceptionController.reset(new ScenePerceptionController(L"Measurement SP", argc, argvW, L"", RGB_IMG_WIDTH, RGB_IMG_HEIGHT, RGB_FRAMERATE,
IMG_WIDTH, IMG_HEIGHT, DEPTH_FRAMERATE));
if((*pScenePerceptionController.get()) == false)
return 1;
pScenePerceptionController->PauseScenePerception(true);
if(!pScenePerceptionController->SetVoxelResolution(PXCScenePerception::VoxelResolution::MED_RESOLUTION))
wprintf_s(L"RF_MeasurementSP: Failed Enable Scene Perception module\n");
return 1;
return 1;
FreeConsole();
Colleen_C_Intel
what camera do you have?
Tony_X_
I am using F200, this sample must be for R200 only, right?
I forgot it, I read it somewhere.
Tony
