Software Archive
Read-only legacy content
Can't see tab file name when split the windows
Muhammad_Y_Efendi
When I use split windows, sometimes I can't see the file name tab.
Please see the attachment file. I use Mac Book Pro.
PaulF_IntelCorp
Interesting. I'm not able to reproduce, I'm on a Macbook Pro. I see that you have changed the default theme. It's possible the theme is at fault, or that it is a bug in Brackets.
Muhammad_Y_Efendi
I use the default theme, and still the same issue is happened.
Anthony_H_Intel
Muhammad -
I was not able to reproduce this either.
Did you do any additional steps to make this happen?
Is it still happening?
Tony
Muhammad_Y_Efendi
Yes, it is still happening.
I  upgraded my mac OS to Sierra, and it is still the same. I don't have any additional step.
When I split the windows, and right windows tab title doesn't show up.
I put my attachment file.
Do you think because some plugin or theme that I installed ?
PaulF_IntelCorp
Muhammad -- my guess is it's due to the old version of Node.js that's being used with Brackets (it's build into the XDK, you cannot replace it). Our next release will include a significant update to the version of node used in the XDK as well as the version used by the Brackets sub-component (they are independent). Interested to see if that release makes a difference.
Anthony_H_Intel
I'm also on Sierra and just tried again to reproduce this issue and still cannot.
It's possible that it is being caused by a brackets theme or plugin.
One way you might check is to do a complete uninstall:
https://software.intel.com/en-us/xdk/faqs/general#uninstall-xdk
Then reinstall and see if the problem was fixed.
Of course, you'd lose any customizations that you've made to Intel XDK including additional themes and plugins.
Sorry I don't have any more convenient suggestions!
