Software Archive
Read-only legacy content
17060 Discussions
Can't see the device in debug module
Antonio_Za
since I've upgraded to the v.3522 I lost the device inspector frontend in the debug tab. Should I activate it somewhere in options?
PaulF_IntelCorp
If you are referring to this?
It no longer exists as part of the Debug tab, and is not an essential component. You can use the Elements tab to get the same inspection. Including it resulted in a tremendous engineering overhead for very little return, so it was removed.
PaulF_IntelCorp
Are you trying to connect an iOS 10 device? There is a known issue with recognizing an iOS 10 device from the XDK. Older devices still work, as do Android devices. Please clarify.
Antonio_Za
Here attached is my debug interface. As you can see, normally at the far left I got the device frontend, but now there is nothing. I debug using a tablet Android 4.4
PaulF_IntelCorp
Antonio_Za
Thank you for the answer Paul, it's the right thing I was looking for.
