Software Archive
Read-only legacy content
17060 Discussions
Can't set button label. Bug?
Juan_C_
Hey all,
I'm new to HTML5, Javascript and XDK, so maybe I'm making a mistake here.  I'm trying to reset the label of a button.  Try this:
1)Create new XDK project with blank HTML5+Cordova template, App Framework, and App Designer
2) Using App Designer, insert one button, with id="button"
3) Add the following on app.js
 function register_event_handlers()
     document.getElementById("button").addEventListener("touchend",function(){document.getElementById("button").value = "Worked!";}, false);
 document.addEventListener("app.Ready", register_event_handlers, false);
4) Clicking on the button using emulate does not change the button label to "Worked!".  Setting the button's 'enabled=false' instead of 'value' doesn't work either.
What am I doing wrong?
Diego_Calp
Valued Contributor I
Look for DOM documentation, but my suggestion is go for jquery to DOM manipulation. XDK includes it in AF3 projects.
For example, the same code with jquery:
$("#button").html("Worked!");
jquery make easier to access every element of the DOM, the model besides web pages.
Diego_Calp
No bug, the problem is that the App Framework button is not an input type element that has a value property.
If you look at index.html your button is something like this:
<a class="button widget uib_w_1 d-margins"
data-uib="app_framework/button" data-ver="2"
id="button">Button</a>
You need to change the innerHTML, this is the correct line:
document.getElementById("button").innerHTML = "Worked!";
Diego
Juan_C_
I see, thank you.  How would I do other things like set the button to disabled?
Where can I find documentation on this?
Thanks!
Diego_Calp
