Software Archive
Read-only legacy content
17060 Discussions
Cannot add controls using Framework 7
Sascha_S_
adding controls (input fields, checkboxes, ...) works in every framework. Except in Framework 7. I can add rows, cols, and so and but if I'm trying to add other controls like input fields, text areas the XDK does not give me the "orange" dropzone for this element.
Hope someone can give me a hint what's going wrong...
Thx
Sascha
Elroy_A_Intel
In order to use UI elements in the List Block collapsible section, you must first drag a List block element to the desired position in the layout. The slider, checkbox and other UI elements can only be inserted into the List block element at this time.
Chris_P_Intel
Elroy has the right of it.  This is how Framework 7 works. Consult their docs to better understand how F7 works.
