Software Archive
Read-only legacy content
17060 Discussions
Cannot call function from Index_user_script.js - Why?
ben4
I am having a lot of problems trying to get a function to kick in when my sidebar close button is clicked.
in the Intel Sdk there is apart that shows this:
        /* listitem  Close Side bar */
    $(document).on("click", ".uib_w_17", function(evt)
         /*global uib_sb */
         /* Other possible functions are:
           uib_sb.open_sidebar($sb)
           uib_sb.close_sidebar($sb)
           uib_sb.toggle_sidebar($sb)
            uib_sb.close_all_sidebars()
          See js/sidebar.js for the full sidebar API */
         uib_sb.toggle_sidebar($(".uib_w_1"));
         setTimeout(show_interstitial_app, 3000);<--My function
         return false;
In the index.html file I created  a function as:
function show_interstitial_app(){
    AdMob.createBanner( {
    adId: admobid.banner,
    position: AdMob.AD_POSITION.BOTTOM_CENTER,
    isTesting: true, // TODO: remove this line when release
    overlap: false,
    offsetTopBar: false,
    bgColor: 'black'
I am not asking any help about the code itself, but why I cannot call my function
 (from another js file) using the Index_user_script.js?
Where is the catch please as I cannot work this one out....
I am just trying to get a delay on an interstitial ad from ad mob cordova, thats all.
Ben
Diego_Calp
Valued Contributor I
Hi Ben,
Try placing your function in app.js file.
Because index.html is modified a lot by Designer, seems better to me to place the code in files that are only manually edited.
Diego
ben4
Thanks, unfortunately I cannot because it has to be placed in the body of the app.
Diego_Calp
This is strange, I added this function into index.html:
<script>
function test(){console.log('hello');}
</script>
In three places: between body tags and before and after the including of index_user_script.js on header tag. And in all places it works.
But my tests were only with Simulator.
Did you check the console for errors?
ben4
Yes earlier on I tried to include this ad code above the body and on the mobile, no ads were showing. This is why I am forced to add this code in the body itself. No problem I have done it and it is working now:-)
