Software Archive
Read-only legacy content
17060 Discussions
Cannot extract package problem
Adam_t_1
Again i have problem :D ... I try install this new update and if i try turn on intel xdk "Failed to unzip the package file: C:\Users\mypc\AppData\Local\Intel\XDK\xdk\xdk-wrapper"
FGold
New Contributor II
I am having the same issue.
Windows 7 system (System Info below)
Downloaded latest XDK release 3619
Error:
Dialog - Cannot Run Package
Failed to unzip the package file: d:\Users\UserName\AppData\Local\Intel\XDK\xdk\xdk-wrapper
Note: Windows 8 system did install and "Open XDK" successfully.
OS Name    Microsoft Windows 7 Professional
Version    6.1.7601 Service Pack 1 Build 7601
Other OS Description     Not Available
OS Manufacturer    Microsoft Corporation
System Name    FLOYDGXPS17-PC
System Manufacturer    Dell Inc.
System Model    Dell System XPS L702X
System Type    x64-based PC
Processor    Intel(R) Core(TM) i7-2720QM CPU @ 2.20GHz, 2201 Mhz, 4 Core(s), 8 Logical Processor(s)
BIOS Version/Date    Dell Inc. A19, 9/7/2012
SMBIOS Version    2.6
Windows Directory    C:\Windows
System Directory    C:\Windows\system32
Boot Device    \Device\HarddiskVolume2
Locale    United States
Hardware Abstraction Layer    Version = "6.1.7601.17514"
User Name    floydgXps17-PC\floydgXps17
Time Zone    Pacific Daylight Time
Installed Physical Memory (RAM)    8.00 GB
Total Physical Memory    7.96 GB
Available Physical Memory    40.2 MB
Total Virtual Memory    19.9 GB
Available Virtual Memory    10.1 GB
Page File Space    11.9 GB
Page File    D:\pagefile.sys
Reineke__H_
I have the same issue: Cannot extract package. Failed to unzip the package file: C:\IntelXDK\xdk\xdk-wrapper.
After remove and a new installing of intel xdk the applications was already running. After closing application and start new this message appears
Dmitry_B_2
I have the same issue on Windows 10 :(
Darrell_L_
I have the same error, I just installed the update today
Failed to unzip the package file: C:\Users\Administrator\AppData\Local\Intel\XDK\xdk\xdk-wrapper
PaulF_IntelCorp
What happens if you download the installer directly from http://xdk.intel.com and update using that?
PaulF_IntelCorp
Please see this post for detailed workaround instructions > https://software.intel.com/en-us/forums/intel-xdk/topic/699456 <
