Software Archive
Read-only legacy content
17061 Discussions
XDK 3619: "Open an Intel Project -older project does not appear to retain App designer capability
FGold
New Contributor II
Develop mode does not display Code or Design
Using latest 3619 XDK, and attempted to open a previous project created with XDK with "App Designer".selected.
Lost capability of App Designer!
FGold
New Contributor II
Solution:
After loading ./www/index.html
The Code and Design tab selections did populate, and appears to be working.
Note:
the dimensions for the "Tablet setting: size", were not retained, I had to modify and enter my original 1280x800 selected.
FGold
New Contributor II
Additional Note:
Selecting "File->Open" was inactive/inhibited in the "DEVELOP" tab, immediately after performing the XDK update.
In order to perform the "File->Open" selection, I had to select "Explore Services"
and then I was able to successfully perform "File->Open"  ../www/index.html to activate the "CODE" and "DESIGN" tabs
