Software Archive
Read-only legacy content
17060 Discussions
Cannot get Device Instance
John_M_9
Hi All,
I have seen numerous examples of getting the device instance; looks simple enough.  However, I am getting a null return from QueryDevice().  I have tried (using c++):
	// Create a PXCSenseManager instance
	PXCSenseManager *sm = PXCSenseManager::CreateInstance();
	if (!sm)
		return 1;
	// find Device Instance
	PXCCapture::Device *cp = sm->QueryCaptureManager()->QueryDevice();
	if (!cp)
		sm->Release();
		return 3;
and
	if (!sm)
		return 1;
	// find Capture Manager Instance
	PXCCaptureManager *cm = sm->QueryCaptureManager();
	if (!cm)
		sm->Release();
		return 2;
	PXCCapture::Device *cp = cm->QueryDevice();
	if (!cp)
		sm->Release();
		return 3;
QueryCaptureManager() returns a non-NULL cm, but QueryDevice() returns a NULL for cp.
Any help would be greatly appreciated.  Thanks!
John
Xusheng_L_Intel
You need add sm->init() before PXCCaptureManager *cm = sm->QueryCaptureManager(); Thanks!
John_M_9
Probably should have mentioned:  Using R200 camera with latest SDK
Xusheng_L_Intel
John_M_9
That did it, David!  Thank you very much!
Aaron_S_4
Is it possible to get a PXCMCapture::Device without initializing SenseManager?
I want to be able to enumerate allowed stream configurations (e.g. which configurations of color+depth are possible) before calling SenseManager::init()
The "Enumerating Streams" and "Enumerating Stream Configurations" sections of the SDK Documentation assume that we already have a reference to the device, but as best I can tell, the only way to get the actual Device (and not just DeviceInfo) is to initialize SenseManager, but that seems so round-about.
Henning_J_
Yes, there is another option: create a PXCMCapture (by using PXCSession::CreateImpl()), then use PXCCapture::CreateDevice().
Something like this:
PXCSession::ImplDesc desc={};
desc.group=PXCSession::IMPL_GROUP_SENSOR;
desc.subgroup=PXCSession::IMPL_SUBGROUP_VIDEO_CAPTURE;
for (int i=0;;i++) {
   PXCSession::ImplDesc desc1;
   if (session->QueryImpl(&desc,i,&desc1)<PXC_STATUS_NO_ERROR) break;
   PXCCapture *capture;
   session->CreateImpl<PXCCapture>(&desc1,&capture);
   for (int d=0;;d++) {
       PXCCapture::DeviceInfo dinfo;
       if (capture->QueryDevice(d,&dinfo)<PXC_STATUS_NO_ERROR) break;
	   PXCCapture::Device *device = capture->CreateDevice(d);
	   break;
   capture->Release();
