Is it possible to call SOAP asmx web service within XDK project?
Any example?
- Tags:
- HTML5
- Intel® XDK
Here is a sample ASMX file to return JSON data from a table.
Imports System.Web Imports System.Web.Services Imports System.Web.Services.Protocols Imports System.Data Imports System.Data.SqlClient Imports System.Web.Script.Serialization ' To allow this Web Service to be called from script, using ASP.NET AJAX, uncomment the following line. ' <System.Web.Script.Services.ScriptService()> _ <WebService(Namespace:="http://tempuri.org/")> _ <WebServiceBinding(ConformsTo:=WsiProfiles.BasicProfile1_1)> _ <Global.Microsoft.VisualBasic.CompilerServices.DesignerGenerated()> _ Public Class WebService1 Inherits System.Web.Services.WebService Dim strConnString As String = System.Configuration.ConfigurationManager.ConnectionStrings.Item("strConnString").ToString() Dim myconn As New SqlConnection(strConnString) Dim sqlstr As String Dim mycommand As SqlCommand Dim sqlda As SqlDataAdapter Dim ds As DataSet <WebMethod()> Public Function getCols(ByVal col1 As String) As String Try sqlstr = "SELECT no,name FROM Dept WHERE no = col1;" mycommand.Connection = myconn If myconn.State <> ConnectionState.Open Then myconn.Open() End If sqlda = New SqlDataAdapter(sqlstr, myconn) sqlda.Fill(ds) myconn.Close() Dim jsonData As String = GetJson(ds.Tables(0)) Return jsonData Catch ex As Exception myconn.Close() Return False End Try End Function Public Shared Function GetJson(ByVal dt As DataTable) As String Return New JavaScriptSerializer().Serialize(From dr As DataRow In dt.Rows Select dt.Columns.Cast(Of DataColumn)().ToDictionary(Function(col) col.ColumnName, Function(col) dr(col))) End Function End Class
From your Javascript call the following to build a Dropdown list in HTML and display it at a DIV defined on your page.
function getCols() { $.ajax({ type: "POST", url: "http://myURL/service.asmx/getCols", data: "{'col1':'" + localStorage.getItem("col1") + "'}", contentType: "application/json; charset=utf-8", dataType: "json", async: true, crossDomain: true, success: function(json){ jsonArray = $.parseJSON(json.d); $("#cols").empty(); var html = "<option>[Select]</option>"; for(i=0; i < jsonArray.length; i++) { col1 = jsonArray.no; col2 = jsonArray.name; html += "<option value='"+col1+"'>"+col2+"</option>"; } //console.log(html); $('#cols').html(html); $("#cols option:first").attr('selected','selected'); $("#cols option:eq(0)").prop("selected", true) $("#cols")[0].selectedIndex = 0; $.mobile.changePage("#uib_page_1", {transition: "slide"}); var myselect = $("#cols"); myselect.selectmenu('refresh'); }, error: function(msg) { navigator.notification.alert("Unable to retrieve cols:" + msg.d); } }); return false; }
Thank you, I'll try it.
OK great, just to say I use MYSQL but the same goes for other databases. I also tend to use VB.NET but again post my VB code to a VB to C# convertor if your need another language.
I have a problem, my WS needs header credentials.
This is my WS url: http://zipris.co.il/nextws/next.asmx and the method is test_Header_json.
How can I make a script with header? UserId and and UserPassword?
Hi
I'm not sure I get what you mean.
If you want to confirm a username and password then send this values in the data string from Javascript like this:-
function verifyDetails(){ var username = $('#username').val(); var password = $('#password').val(); $.ajax({ type: "POST", url: "http://myURL/service1.asm/confirmUser", data: "{'username':'" + username + "','password':'" + password + "'}", contentType: "application/json; charset=utf-8", dataType: "json", async: true, crossDomain: true, success: function (msg) { if (msg.d) { navigator.notification.alert("Your username is correct.",saveDismissed,"Success"); } else { navigator.notification.alert("Your username and or password is incorrect.",DeviceDismissed,"User Details Error"); } }, error: function(jqXHR, textStatus, errorThrown) { navigator.notification.alert("Error cannot confirm user details: " + textStatus + ' : ' + errorThrown); } }); }
Your ASMX web service then returns True or False depending on whether the credentials are correct.
This is the request for the WS, as you can see the user and pass are in the header.
<?xml version="1.0" encoding="UTF-8" standalone="no"?> <soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/"> <soap:Header> <tns:WSCredentials xmlns:tns="http://tempuri.org/"> <tns:UserId>user</tns:UserId> <tns:UserPassword>pass</tns:UserPassword> <tns:Server></tns:Server> </tns:WSCredentials> </soap:Header> <soap:Body> <tns:test_Header_json xmlns:tns="http://tempuri.org/"/> </soap:Body> </soap:Envelope>
Any reason why you are using SOAP, why not use HTTP POST as per my example.
Either way you should be able to send the Username and Password as criteria to your web service.
Unfortunetly it does not work.
I press the button but nothing happened.
Any idea?
<html> <head> <title>AJAX and XDK</title> <meta name="viewport" content="initial-scale=1.0, maximum-scale=1.0, minimum-scale=1.0, user-scalable=0;" /> <script type="text/javascript" charset="utf-8" src="http://code.jquery.com/jquery-2.0.3.min.js"></script> <script src="intelxdk.js"></script> <script src="xhr.js"></script> <script> function doAJAX() { $.ajax({ type: "POST", url: "http://zipris.co.il/nextws/next.asmx/test_json", data: "{'col1':'" + localStorage.getItem("col1") + "'}", contentType: "application/json; charset=utf-8", dataType: "json", async: true, crossDomain: true, success: function(json){ jsonArray = $.parseJSON(json.d); $("#cols").empty(); var html = "<option>[Select]</option>"; for(i=0; i < jsonArray.length; i++) { col1 = jsonArray.EmpNo; col2 = jsonArray.EmpName; html += "<option value='"+col1+"'>"+col2+"</option>"; } //console.log(html); $('#cols').html(html); $("#cols option:first").attr('selected','selected'); $("#cols option:eq(0)").prop("selected", true) $("#cols")[0].selectedIndex = 0; $.mobile.changePage("#uib_page_1", {transition: "slide"}); var myselect = $("#cols"); myselect.selectmenu('refresh'); }, error: function(msg) { navigator.notification.alert("Unable to retrieve cols:" + msg.d); } }); } </script> <style> body {font-family:arial;background-color:white} </style> </head> <body> <h3>AJAX Call</h3> <button onclick="doAJAX()">AJAX Call</button><br> <select name="myselect"></select> </body> </html>
Zipsoft,
Have you stepped through your code while running on device? Where does it get stuck? Using the Debug Tab to step through your code can be very helpful (or the Test Tab with weinre for a Windows 8 device).
Pamela
How can I debug javascript?
I put alert message in the function doAJAX and it does not go after the $.ajax({ .
If you run your ASMX file directly in a browser
http://zipris.co.il/nextws/next.asmx then click on test_json you get the following error:-
The test form is only available for requests from the local machine.
You will need to fix this error before you can test your ASMX script from a live server. Check your web.config file and check this line in your asmx file
' To allow this Web Service to be called from script, using ASP.NET AJAX, uncomment the following line. |
09 |
' <System.Web.Script.Services.ScriptService()> _ |
Can you refer me please to an working example of Intel XDK html5 Ajax calling a web service or a website?
Your code works fine.
I have just copied and pasted your Javascript and displayed the results in a DIV called cols. The Button has an onclick event to fire doAJAX()
Above is a screen grab from the XDK Emulator Tab.
Can you send me please the XDK project?
I Have sent you a private message with a link to the project.
Thank you.
I appreciate it a lot.
Glad I could help.
