Software Archive
Read-only legacy content
17060 Discussions
Cannot rebuild GPL gear for KNC_gold_update_1-2.1.4982-15-suse-11.2
Mal_H_
It works fine untill it starts building the manpages then I get
FAILED: /root/KNC_gold_update_1-2.1.4982-15-suse-11.2/gpl/documentation/man/scif_open.txt: line 40: missing endif::scif_user[]
a2x: failed: asciidoc --doctype=manpage -a "scif_user" -d manpage -b docbook "scif_open.txt"
It seems that the ascidoc package with SUSE 11 SP2 doesn't like something. I've not used asciidoc before so I have no idea where to start hitting it to make it work.
Frances_R_Intel
According to my reading of the asciidoc manual, the .txt file is correct and no #endif is required. I do not have a2x installed on the machine I use at the moment but will try to do that. In the meantime, if anyone else has done this rebuild, perhaps they could share their experience.
Mal_H_
That is what I could determine as well.. Which version of asciidoc was used to build the original RPM's possibly I have a version skew issue.
Also adding an endif::scif_user[] block causes a pile of other errors..
Is there a way I can rebuild without the man pages.. because we really don't need them.
Mal_H_
*bump*
I'm still unable to rebuild. Which is annoying as I can't use the damn things at the moment because of it...
Frances_R_Intel
Just FYI - when I tried building the man pages everything worked. We are now several releases past KNC_gold_update_1-2.1.4982-15 and I haven't heard of any more problems.
