Software Archive
Read-only legacy content
Cannot udpate the flash/smc the mpss 3.1
Xiao_peng_W_
In the readme of mpss 3.1, it mentioned that the flash should be updated otherwise might encounter stranage problem.
Then I tried to update my mic card, but it failed to update SMC and then get into 'failed resetting'  status.  What I can do to solve this issue?
micflash -getversion -device 0
mic0: Flash read started
mic0: Read done
mic0: Version: 2.1.01.0372
mic0: Transitioning to ready state
# micflash -update /usr/share/mpss/flash -device 0
mic0: Flash image: /usr/share/mpss/flash/EXT_HP2_B1_0386-03.rom.smc
mic0: Flash update started
mic0: Flash update done
mic0: SMC update started
micflash: mic0: Flash operation timed out
Please restart host for flash changes to take effect
# micctrl -s
mic0: reset failed
mic1: online (mode: linux image: /usr/share/mpss/boot/bzImage-knightscorner)
Frances_R_Intel
Not being able to get the flash to update properly has been an issue with you for some time. Have you tried power cycling the host (actually pull the plug - make sure their is no power to the card at all, then retrying the flash as explained in the last post to http://software.intel.com/en-us/forums/topic/407610?
If that doesn't work, did the flash update to mic1 work? If yes, have you tried swapping the ports these cards are connected to and try again?
Xiao_peng_W_
Frances,
Thanks for your reply.
I tried to power off, wait a while and power on, it could resolve the issue of mic card hanging at 'reset failed'.
If the 'power recycle' (pull and plug cable) takes much difference with 'power off', I'll try it later since my machines are in remote.
