Software Archive
Read-only legacy content
17060 Discussions
Cant profile OpenMP code
AndrewC
New Contributor III
When trying to profile some OpenMP code using "Intel Parallel Amplifier 2011 Update 1, (build 127928)", in Studio 2008, Windows XP 64,
I am getting.....
OMP: Error #134: Cannot set thread affinity mask.
OMP: System error #87: The parameter is incorrect.
And the profile operation stops at that point.
The code runs fine outside of Amplifier.
I am not trying to set affinity flags in my code , it is "vanilla omp"
I do not have any KMP_ variables set.
Kirill_R_Intel
Could you please provide some more info about the problem:
- Is the issue seen when application runs from Amplifier only? Is there a problem if it is started standalone?
- Please set environment variables KMP_SETTINGS=1 and KMP_VERSION=1. Than reproduce the issue. There should be more detailed error output.
- Can you attach a reproducer sample? Well try to reproduce it in our lab.
Kirill_R_Intel
Two more questions:
What compiler do you use: MSVS of Intel?
And do you use Intel openMP runtime? If Microsoft compiler is used, Intel openMP should be explicitly set.
Kirill
