Software Archive
Read-only legacy content
17060 Discussions
Canvas in cordova app not drawing anti aliased
David_B_12
Débutant
728 Visites
N00b here :)
I'm trying to build a drawing app so the first thing I looked at as the Canvas Touch Draw HTML5 + Cordova sample app.  When I run it however, the draw command are not not aliased.
Also when I draw with the mouse it actually looks like the canvas is scaled up slightly as the jagged pixels look bigger than 1 pixel.
These problems are showing up on the software emulator and also hardware.
Any ideas about why these problems happen?
0 Compliments
4 Réponses
Amrita_C_Intel
Employé
728 Visites
Which version of XDK are you using? Which testing device are you using to test your app?
0 Compliments
David_B_12
Débutant
728 Visites
Found an excellent tutorial about how it should be done:
http://codetheory.in/html5-canvas-drawing-lines-with-smooth-edges/
0 Compliments
David_B_12
Débutant
728 Visites
Intel XDK 1912 on Windows.  The issue was noticed on all devices, the emulators and a physical Sony Z3 compact.  I tried the suggested link I found and that solution works very well.  I still don't know why you can't just draw with antialiasing on straight away, rather than using what looks like some sort of display buffer.
0 Compliments
PaulF_IntelCorp
Employé
728 Visites
Why you have to jump through hoops for anti-aliasing is a question for the HTML5 gods. :) The XDK does not prescribe the behavior of the HTML5 runtime engines, it just provides convenient access to them for a packaged app. See this article for a hint as to what this means: http://blogs.intel.com/evangelists/2014/09/02/html5-web-app-webview-app/
0 Compliments
Répondre
