Software Archive
Read-only legacy content
17060 Discussions
Centos 7.3 - do I really need OFED from openfabric.org ?
lejeczek
hi everyone
One quick question - do I really really need OFED from openfabrics.org and all the packages from centos/rhel + epel repos will NOT do?
Reason I'm asking is - compilation/installation of OFED 3.18.x which MPSS manuals says to use fails. Compiler fails somewhere in rdma-compat I think.
Rob_J_
In the MPSS Users Guide there are four distributions mentioned. See section 3.7.1
lejeczek
And both 3.18 and newer which is not metioned 4.8.1 fail to build on my vanilla Centos:
$ perl install.pl --with-xeon-phi --basic
Running rpmbuild --rebuild --define 'PSM_HAVE_SCIF 1' --define '_topdir /var/tmp//OFED_topdir' --nodeps --define '_dist .unsupported' --define 'configure_options   --with-core-mod --with-user_mad-mod --with-user_access-mod --with-addr_trans-mod --with-mlx4-mod --with-mlx4_en-mod --with-mlx5-mod --with-cxgb3-mod --with-cxgb4-mod --with-nes-mod --with-qib-mod --with-ipoib-mod --with-qed-mod --with-firmware-mod --with-qede-mod --with-qedr-mod --with-bnxt_en-mod --with-bnxt_re-mod' --define 'KVERSION 3.10.0-693.21.1.el7.x86_64' --define 'K_SRC /lib/modules/3.10.0-693.21.1.el7.x86_64/source' --define 'K_SRC_OBJ /lib/modules/3.10.0-693.21.1.el7.x86_64/build' --define '_release 1.1.gd5db855.3.10.0_693.21.1.el7.x86_64' --define 'network_dir /etc/sysconfig/network-scripts' --define '_prefix /usr' --define '__arch_install_post %{nil}' /root/rpmbuild/tars/OFED-4.8-1/SRPMS/compat-rdma-4.8-1.1.gd5db855.src.rpm
Failed to build compat-rdma RPM
See /tmp/OFED.16178.logs/compat-rdma.rpmbuild.log
I see that many of those rpm packeges OFED from openfabrics.org is trying to install are already there in default/epel repos so I am hoping maybe rather those than adding extra weight, if it can work?
With OFED installation problem - where to look for help, here or seek some at openfabric.org?
Rob_J_
Like I said, there are three other distros available: TSR 7.4.2, OFED 3.12-1 and Mellanox OFED 2.4
The build line you used also varies from the instructions. There's no --basic appended.
Rocha__João
Dear all,
I'm trying to run an offload .c code but i'm having trouble getting some libs in the right place, although i've put (so i suppose) the correct path's on my bashrc. I get this line when running the executable:
error while loading shared libraries: liboffload.so.5: cannot open shared object file: No such file or directory
Location for the lib:
/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64/liboffload.so.5
/opt/intel/composer_xe_2015.1.133/compiler/lib/mic/liboffload.so.5
which i've exported in bashrc as:
export SINK_LD_LIBRARY_PATH="/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64:$SINK_LD_LIBRARY_PATH"
export SINK_LD_LIBRARY_PATH="/opt/intel/composer_xe_2015.1.133/compiler/lib/mic:$SINK_LD_LIBRARY_PATH"
I've tried to -rpath and -rpath-link but still doesn't work. Is my line wrongly written?
(e.g.): icc -fopenmp -rpath=/opt/intel/composer_xe_2015.1.133/compiler/lib/intel64 flops3_offload.c -o flops3_offload
Can someone give a clue on this?
Thanks a lot,
João Rocha
Rob_J_
Don't know the answer to that. You probably should start a new thread since it's not related to OFED.
