Software Archive
Read-only legacy content
17060 Discussions
Change href of sprite button in JavaScript
Ruben_S_
Hi all,
I have a javascript function in which I want to set the href of a sprite button. Nothing seems to work. I have tried
- document.getElementById('button').href
- document.getElementById('button').src
with jQuery via setAttribute..
Anyone who can tell me what I should do to set the href of a sprite button?
Chris_P_Intel
If it is the "Sprite Button" from App Designer, just register a click handler on it.
In the Interactivity pane in App Designer find your button and in the right column choose "Custom Script".  Then click the "Edit Script" button - that'll add a handler for you and you can just put whatever code you want in there.
Elroy_A_Intel
What type of element is 'button'? The HTML href attribute can only be added to a HTML <a> tag.
Chris_P_Intel
Chris_P_Intel
Where are you attempting to go ? To another file? To a #section on the page?
Ruben_S_
I have registered a click handler for it.
document.getElementById('button').onclick = (function(value){ code... });
This did the trick
