Software Archive
Read-only legacy content
17061 Discussions
Choose version of Crosswalk
Antoine_D_
In the Intel XDK doc (https://software.intel.com/en-us/xdk/docs/using-the-crosswalk-for-android-build-option) last chapter :
If you want to test against the latest Crosswalk code base for bug fixes or new features, you can opt to build using the beta version of Crosswalk code base. This option is available on the Details page under "Select Code Base." The default option is to use the stable version. If you choose to use the beta code base, please note that this version of code base has not been completely tested, hence your application may be buggy when built using this option; this build option is not recommended for deployment to app stores.
Where is that or how I can do that ?  I only found a choice between 7 and 10 in build settings.
John_H_Intel2
We have not released them yet. Once we do, they will show up in the drop down menu under the Crosswalk build settings.
Antoine_D_
Have you an idea of when does it come out?
And you should edit the doc.
Anyway, thanks for the answer.
Swati_S_Intel1
Crosswalk 11 and 12 are available in XDK now.
