[bash]#include#include #include #include #ifdef __cilk #include #else #define cilk_spawn #define cilk_sync #endif #define THRESH 16 void inssort(int *a, int l, int r){ int i,j,v,t; for(i=r; i>l; i--)if(a[i-1] > a){t=a[i-1]; a[i-1]=a; a=t;} for(i=l+2; i<=r; i++){ j=i; v=a; while(v < a[j-1]){ a =a[j-1]; j--; } a =v; } } void qsort3(int *A,int p,int r){ /* Input A(p:r), rnk (p <= rnk <= r). Returns the value of the element of rank rnk. The array is partitioned about A[rnk], as well */ int k,t,q,rnd,f,x,j,rnk,p0,r0; // median is all that we want lq: p0=p, r0=r; rnk=(p+r)/2; if (r <= p) { cilk_sync; return; } if(r+1-p <= THRESH){ inssort(A,p,r); cilk_sync; return; } while(1){ if(p==r){ q=p; break;} rnd=rand(); k=p+(r-p)*(double)rnd/(double)RAND_MAX+0.5; t=A ; A =A ; A =t; /* randomize */ q=p-1; x=A ; //Inline version of q=rpart(A,p,r); for(j=p; j <= x){ t=A[++q]; A =A; A =t; } t=A ; A =A[++q]; A =t; if(15*(rnk-q) < (r0-p0)*8)break; // stop chasing median if close enough //For exact median: if(rnk==q)break; if(rnk < q)r=q-1; else p=q+1; // set up for next iteration, } // choosing left or right part p=q-1; t=A; while(A==t)p--; // segregate middle part r=q+1; while(A
==t)r++; // the middle part has all elements = median, needs no sorting if(p-p0 > r0-r){ cilk_spawn qsort3(A,p0,p); p=r; r=r0; goto lq; // Avoid tail recursion qsort3(A,r,r0); } else { cilk_spawn qsort3(A,r,r0); r=p; p=p0; goto lq; // Avoid tail recursion qsort3(A,p0,p); } cilk_sync; // superfluous, but keep for safety } int main(int argc, char* argv[]) { int size,*a,i,med; int c1,c2; int nl,nr; printf("Threshhold = %d\n",THRESH); for(size=0x4000; size <= 0x1000000; size+=size){ a = malloc(sizeof(int)*size); if(!a){ fprintf(stderr,"Could not allocate space for %08X integers\n",size); exit(1); } for(i=0; i = (double)rand()*size/RAND_MAX; c1=clock(); qsort3(a, 0, size-1); c2=clock(); printf("M %08d %6.3f\n", size,(double)(c2-c1)/CLOCKS_PER_SEC); free(a); } return 0; } [/bash]
However, CilkView gives a rather pessimistic estimate of 2.2 for the upper bound on parallel speed-up. On Windows 7 Home Premium X64 running on a Dell XPS 17 laptop with i7-2720QM, I get speed-ups that are never less than 3.0.
[bash]s:\sort\sav>icl /O3 /DNOCHECK /MD ssort.c Intel C++ Compiler XE for applications running on IA-32, Version 12.0.4.196 Build 20110427 [/bash]
[bash]s:\sort\sav>cilkview -trials one ssort.exe cilkview: running with 8 workers Threshhold = 16 M 00016384 0.001 M 00032768 0.001 M 00065536 0.002 M 00131072 0.003 M 00262144 0.006 M 00524288 0.012 M 01048576 0.023 M 02097152 0.038 M 04194304 0.078 M 08388608 0.153 M 16777216 0.293 cilkview: generating scalability data Cilkview Scalability Analyzer V2.0.0, Build 1113 Threshhold = 16 M 00016384 0.120 M 00032768 0.052 M 00065536 0.060 M 00131072 0.079 M 00262144 0.111 M 00524288 0.178 M 01048576 0.279 M 02097152 0.448 M 04194304 0.834 M 08388608 1.528 M 16777216 2.923 Whole Program Statistics 1) Parallelism Profile Work : 10,511,027,859 instructions Span : 4,781,368,295 instructions Burdened span : 4,790,901,465 instructions Parallelism : 2.20 Burdened parallelism : 2.19 Number of spawns/syncs: 433,563 Average instructions / strand : 8,081 Strands along span : 767 Average instructions / strand on span : 6,233,856 Total number of atomic instructions : 44 Frame count : 867,137 2) Speedup Estimate 2 processors: 1.13 - 2.00 4 processors: 1.20 - 2.20 8 processors: 1.25 - 2.20 16 processors: 1.27 - 2.20 32 processors: 1.28 - 2.20[/bash]
Bear in mind that you're timing a subsection of the code with respect to what Cilkview is measuring. Your timing interval covers only the sorting section of the code, whereas Cilkview is estimating the speedup of the whole program. Cilkview's measurement includes your creation of the array and the (serial) assignment of values to it, which your timing mechanism ignores.
My guess is that if you expanded your timing measurements to start at the beginning of main() and end just before the return (and, obviously, a printf), you would be finding speedup numbers that were much closer to the values that Cilkview gives you.
You can make Cilkview instrument specific subsections of code and outputstatistics for themin addition to the whole-program statistics you are seeing, now. Use cilktools/cilkview.h:
cilkview_data_t start, end;
__cilkview_query(start);
// do work.
__cilkview_query(end);
__cilkview_do_report(&start, &end, "Sort", CV_REPORT_WRITE_TO_LOG | CV_REPORT_WRITE_TO_RESULTS);
// do work.
