Software Archive
Read-only legacy content
Cilkview bug
William_H_5
   I'm getting some suspicious cilkview output (pasted below).  Notice that the work calculated in the cilk parallel region is implausibly large.
I'm using:
Cilkview version 2.0.0, build 3566, built Aug 20 2013 13:58:06
Using PIN 2.12, Build 59761
gcc (GCC) 4.8.0 20120618 (experimental)
gcc -o qsort.64 -O3 -g -Werror -gdwarf-3 -std=gnu99 -m64 -I/afs/csail.mit.edu/proj/courses/6.172/cilkutil/include qsort.c -lcilkrts -ldl
Whole Program Statistics
1) Parallelism Profile
Work : 13,138 instructions
Span : 5,129,893,803 instructions
Burdened span : 91,087,059,418 instructions
Parallelism : 0.00
Burdened parallelism : 0.00
Number of spawns/syncs: 20,000,000
Average instructions / strand : 0
Strands along span : 33,456,971
Average instructions / strand on span : 153
Total number of atomic instructions : 20,000,040
Frame count : 40,000,000
2) Speedup Estimate
2 processors: 0.00 - 0.00
4 processors: 0.00 - 0.00
8 processors: 0.00 - 0.00
16 processors: 0.00 - 0.00
32 processors: 0.00 - 0.00
64 processors: 0.00 - 0.00
128 processors: 0.00 - 0.00
256 processors: 0.00 - 0.00
Cilk Parallel Region(s) Statistics - Elapsed time: 0.793 seconds
Work : 18,446,744,073,168,188,722 instructions
Span : 4,588,517,771 instructions
Burdened span : 90,545,683,386 instructions
Parallelism : 4020196715.76
Burdened parallelism : 203728586.32
Average instructions / strand : 381,237,467,926
Strands along span : 16,728,485
Average instructions / strand on span : 274
Entries to parallel region : 10
2) Speedup Estimate
2 processors: 1.90 - 2.00
4 processors: 3.80 - 4.00
8 processors: 7.60 - 8.00
16 processors: 15.20 - 16.00
32 processors: 30.40 - 32.00
64 processors: 60.80 - 64.00
128 processors: 121.60 - 128.00
256 processors: 243.20 - 256.00
Barry_T_Intel
Is this run using one of our sample programs?
    - Barry
William_H_5
No, I'm running cilkview --trials=all ./qsort.64
qsort.64 is generated using the gcc command in my original post and the source is qsort.c which I included in my original post.
Will
Barry_T_Intel
Ah.  I missed it in the original post.  I'll take a look and get back to you.
   - Barry
Barry_T_Intel
FYI, I'm unable to reproduce the problem with they latest build from the "cilkplus" branch.  I'm pulling the snapshot from the "cilkplus-4_8_branch" now.
    - Barry
Balaji_I_Intel
Hello William,
   Is there any reason why you are forcing dwarf3? If not, then can you please try to compile without that flag and try using cilk tools? In the past we have had issues with the metadata info. when the drawf version is changed.
Balaji V. Iyer.
Barry_T_Intel
It's not reproducing for me with the cilkplus-4_8-branch either.
4.9: gcc (GCC) 4.9.0 20130520 (experimental)
4.8: gcc (GCC) 4.8.1 20130520 (prerelease)
Cilkview run with the image produced by the cilkplus-4_8-branch compiler:
Cilkview: Generating scalability data
Cilkview Scalability Analyzer V2.0.0, Build 3808
Sorting 1000000 integers
Running 10 trials
All sorts succeeded
Sort time: 6.694000e+00 seconds
Work : 6,799,746,125 instructions
Span : 835,654,456 instructions
Burdened span : 851,217,096 instructions
Parallelism : 8.14
Burdened parallelism : 7.99
Average instructions / strand : 113
Strands along span : 1,407
Average instructions / strand on span : 593,926
Total number of atomic instructions : 20,000,070
2) Speedup Estimate
2 processors: 1.65 - 2.00
4 processors: 2.44 - 4.00
8 processors: 3.21 - 8.00
16 processors: 3.82 - 8.14
32 processors: 4.21 - 8.14
64 processors: 4.44 - 8.14
128 processors: 4.57 - 8.14
256 processors: 4.63 - 8.14
Cilk Parallel Region(s) Statistics - Elapsed time: 0.631 seconds
Work : 6,258,755,107 instructions
Span : 294,663,438 instructions
Burdened span : 310,226,078 instructions
Parallelism : 21.24
Burdened parallelism : 20.17
Average instructions / strand : 104
Strands along span : 703
Average instructions / strand on span : 419,151
2) Speedup Estimate
2 processors: 1.84 - 2.00
4 processors: 3.19 - 4.00
8 processors: 5.03 - 8.00
16 processors: 7.07 - 16.00
32 processors: 8.86 - 21.24
64 processors: 10.14 - 21.24
128 processors: 10.94 - 21.24
256 processors: 11.38 - 21.24
The copy of Cilkview I'm running is from the current build, but nothing's been done to it since the release you're using.
I just discussed the GCC version numbers with Balaji.  While GCC does not automatically generate a new version number when a fix is checked in, your build number is 2012 date.  I suspect we've fixed the problem you're seeing in a more recent compiler.
    - Barry
William_H_5
Hey guys,
   Thanks - I updated my version of GCC and it all seems to be working fine.  It's a little bizarre that Cilkview behaved that way, but the subtlety may just be a curiosity left for the archaeologists of the next millenium...
Will
