Software Archive
Read-only legacy content
17060 Discussions
Click of Graphic button don't work
Maxim_K_
Click event of graphic button control doesn't work on iPhone and iPad devices only, but work well on Android device and on Emulate tab of XDK. Any suggestions? Thank you.
Rakshith_K_Intel
can u post example code that is having issue ?
Maxim_K_
Good morning Rakshith,
Any kind of code, even the simple one:
$(document).on("click", ".uib_w_39", function(evt)
activate_subpage("#page_67_15");
Rakshith_K_Intel
I will need complete code to check.
I tried new project, dragged a button, added custom script for button to alert("hello"), tested on iphone, worked. Can u check it this is working for you?
Anusha_M_Intel1
@Maxim,
Are all your button clicks causing issues or only the ones that redirect to another page?
Maxim_K_
Dear Rakshith,
I've created the new blank html5+cardova project on jQuery mobile framework with only one graphic button and one page and the simple code:
$(document).on("click", ".uib_w_1", function(evt)
 alert("Hello");
Then I've shifted to the "test" tab and I've synchronized the project. After that I've checked from iPhone by Intel App Preview software and the same broblem.
Dear Anusha,
All of buttons work fine, the problem only with the GRAPHIC buttons. Yes, all of graphic buttons have the same issue.
Rakshith_K_Intel
@maxim I have reproduced the issue with "Graphic" button on ios, I have reported to engineering team, will update you when I have status, Thank You
Maxim_K_
There is one more problem with the same configuration (html5+cardova+jQuery). The layout of button grid is one column only for Android, but for iOS and emulator tab of xdk is correct.
Chris_P_Intel
For the graphic button, if you add   href="#" to the <a> tag that is the base button, it'll work on iOS.
Maxim_K_
@CHRIS P
Thank you so much!
any updates with Android layout issue? or shall I create a new topic?
