Software Archive
Read-only legacy content
Code Hints
Gianluca_I_1
hi, it will probably be nonsense, but by enabling or disabling the code hints, do not change anything, I no longer have any hints while editing
regards
Gianluca Izzo
Amrita_C_Intel
If you mean the code hints in the editor I'm not aware of how to turn that off or on . It is the Brackets editor, so you might have to lookup how to do that with Brackets. You can also use your own editor, you're not required to use the one that is built into the XDK. The XDK monitors changes to the filesystem, so it will behave properly if you use an external editor. I frequently use Sublime and Brackets with my projects, alongside the built-in editor.
Gianluca_I_1
thanks for reply.
the problem is solved magically , closing the project and creating a new one ; once back on the original project has gone well
thanks
best regards
Gianluca
