Software Archive
Read-only legacy content
17061 Discussions
Como Leer contenido de directorio(xdk/cordoba)
jaime_m_
hola cree un archivo de texto y lo grabe a traves de mi aplicacion en el directorio Dcim/Camera.
ahora quiero ller los archivos que se encuentran en ese directorio, por leer me refiero a listar el nombre de los archivos.
encontre una aplicacion que supuestamente hace eso pero el codigo no funciona , aqui esta
Read Contents of a File
Using FileEntry object we can read contents of a file. In the above code we saw how to get FileEntry object using DirectoryEntry object.
Here is the code to read content of the file we created
        document.addEventListener("deviceready", onDeviceReady, false);
        function onDeviceReady()
            requestFileSystem(LocalFileSystem.PERSISTENT, 0, onSuccess,onError);
        function onSuccess(fileSystem)
            var directoryEntry = fileSystem.root;
            directoryEntry.getFile("readme.txt", {create: true,exclusive: false}, function(fileEntry){
                //lets read the content of the file.
                fileEntry.file(function(file){
                    //FileReader object streams the content of the file from storage disk to app
                    var reader = new FileReader();
                    reader.onloadend = function (evt) {
                        //result property is string type if you read data as string. If you read data as array buffer then its assigned to a array buffer object.
                        console.log(evt.target.result);
                    //to read the content as binary use readAsArrayBuffer function.
                    reader.readAsText(file);
                }, function(error){
                    console.log("Error occurred while readline file. Error code is: " + error.code);
            }, function(error){
                console.log("Error occurred while getting a pointer to file. Error code is: " + error.code);
        function onError(evt)
            console.log("Error occurred during request to file system pointer. Error code is: " + evt.code);
si aguien me puede ayuda de lo agradeceria, el plugins File esa agregado a mi app
saludos
PaulF_IntelCorp
I recommend you look at the following pages for help:
Mr. Raymond Camden has been involved in the Cordova and PhoneGap projects for a very long time and is very accomplished in the art of creating Cordova apps. His blogs contain very useful information.
jaime_m_
thankyou but the example on the web no work for me
I don't know why
