Software Archive
Read-only legacy content
17060 Discussions
Error Building iOS
nicolas_r_
Hi i try my first iOS build on intel XDK with a project that is working fine on android i follow all the guides that the programe gives to generate the certificates and provisioning files. but when i build i get an error.
John_H_Intel2
The error is with your bundle ID and provisioning profile mismatch.What you specify in the XDK for the appID, must match what you use to create the appID on apples developer portal and then use that to create the provisioning profile.
