Software Archive
Read-only legacy content
17060 Diskussionen
Como inserir duas galerias em um mesmo projeto sem dar erro no tamanho?
Marcelo_R_
Einsteiger
1.647Aufrufe
Quando insiro mais de uma galeria no intel xdk aparece um erro Could not extract a stage height from the CSS. Traced height: ... como resolver isto?
8 Antworten
PaulF_IntelCorp
Mitarbeiter
1.647Aufrufe
Inserting two galleries on the same project without giving error in size?
When I insert more than one gallery on intel XDK comes a mistake Could not extract the stage height from the CSS. Traced height: ... how to solve this?
I will ask one of my colleagues to take a look.
Rakshith_K_Intel
Mitarbeiter
1.647Aufrufe
I'm able to add 2 galleries on one page with AppFramework 3, Which UI framework are you using?
Marcelo_R_
Einsteiger
1.647Aufrufe
Bootstrap
Rakshith_K_Intel
Mitarbeiter
1.647Aufrufe
Can you give more details how you are adding the image gallery,
I tried adding 2 gallaries like in the attached screenshot below:
Marcelo_R_
Einsteiger
1.647Aufrufe
ocorre um erro como na foto. Estou somente arrastando image gallery para o projeto duas vezes
Anusha_M_Intel1
Mitarbeiter
1.647Aufrufe
an error occurs as pictured . I'm just dragging image gallery for the project twice
I am going to escalate this issue to Engineering to see if they might have a fix. In the meantime, when the image gallery is created, are there two styles that are automatically created when you drag and drop? - d-margins and image-gallery-size. You can find them on the right panel under styles in app designer.
Marcelo_R_
Einsteiger
1.647Aufrufe
quando clico em image-gallery- size o erro desaparece, mas me parece que ele não esta carregando este style automaticamente, após uns 5 segundos o erro aparece
Anusha_M_Intel1
Mitarbeiter
1.647Aufrufe
It looks like this is not an XDK related error but a bootstrap (third party gallery widget) error.
Try creating a new blank project and try this again. Maybe some project files got corrupted during the last create. None of us are able to reproduce this.
Antworten
