Software Archive
Read-only legacy content
17060 Discussions
Como obter o certificado de um aplicativo android?
Jonathan_S_
Olá, preciso saber como posso obter o certificado de um aplicativo gerado pelo xdk.
alguém pode me ajudar?
obrigado.
Elroy_A_Intel
You can create your developer certificate for your iOS build on the Apple Developer Portal using the .csr file provided by Intel XDK. You can start this process on the Projects window > select project > Cordova Hybrid Mobile App Settings > iOS > Developer Certificate.
Jonathan_S_
How I can do for a Android app? this case, I need a android application certificate.
Elroy_A_Intel
You can follow the same flow similar to Android with the exception of selecting Android on the Projects window > select project > Cordova Hybrid Mobile App Settings > Android.
Jonathan_S_
thanks!
I found more information about signed apk's in this article:
https://software.intel.com/en-us/xdk/docs/intel-xdk-certificate-management
