Software Archive
Read-only legacy content
17061 Discussions
Compiling Supersonic on Xeon Phi
anxuan_y_
I'm tring to compile supersonic(an opensource in-memory database of google) on Xeon Phi with an Makefile:
CC = icc
CFLAGS= -Wall -O2 -g -DNDEBUG -mmic
but after executing "make", yield the following error:
/tmp/iccDgxoGdas_.s: Assembler messages:
/tmp/iccDgxoGdas_.s:2189: Error: `lfence' is not supported on `k1om'
/tmp/iccDgxoGdas_.s:2403: Error: `lfence' is not supported on `k1om'
/tmp/iccDgxoGdas_.s:3345: Error: `lfence' is not supported on `k1om'
/tmp/iccDgxoGdas_.s:3559: Error: `lfence' is not supported on `k1om'
/tmp/iccDgxoGdas_.s:3634: Error: `lfence' is not supported on `k1om'
/tmp/iccDgxoGdas_.s:3848: Error: `lfence' is not supported on `k1om'
/tmp/iccDgxoGdas_.s:4284: Error: `lfence' is not supported on `k1om'
/tmp/iccDgxoGdas_.s:4498: Error: `lfence' is not supported on `k1om'
/tmp/iccDgxoGdas_.s:4573: Error: `lfence' is not supported on `k1om'
/tmp/iccDgxoGdas_.s:4787: Error: `lfence' is not supported on `k1om'
/tmp/iccDgxoGdas_.s:28235: Error: `lfence' is not supported on `k1om'
/tmp/iccDgxoGdas_.s:28438: Error: `lfence' is not supported on `k1om'
/tmp/iccDgxoGdas_.s:42077: Error: `lfence' is not supported on `k1om'
/tmp/iccDgxoGdas_.s:42337: Error: `lfence' is not supported on `k1om'
/tmp/iccDgxoGdas_.s:42560: Error: `lfence' is not supported on `k1om'
/tmp/iccDgxoGdas_.s:42820: Error: `lfence' is not supported on `k1om'
/tmp/iccDgxoGdas_.s:43096: Error: `lfence' is not supported on `k1om'
/tmp/iccDgxoGdas_.s:43310: Error: `lfence' is not supported on `k1om'
/tmp/iccDgxoGdas_.s:44296: Error: `lfence' is not supported on `k1om'
/tmp/iccDgxoGdas_.s:44554: Error: `lfence' is not supported on `k1om'
/tmp/iccDgxoGdas_.s:44638: Error: `lfence' is not supported on `k1om'
/tmp/iccDgxoGdas_.s:44852: Error: `lfence' is not supported on `k1om'
/tmp/iccDgxoGdas_.s:46414: Error: `lfence' is not supported on `k1om'
/tmp/iccDgxoGdas_.s:46674: Error: `lfence' is not supported on `k1om'
/tmp/iccDgxoGdas_.s:46758: Error: `lfence' is not supported on `k1om'
/tmp/iccDgxoGdas_.s:46972: Error: `lfence' is not supported on `k1om'
/tmp/iccDgxoGdas_.s:47561: Error: `lfence' is not supported on `k1om'
/tmp/iccDgxoGdas_.s:47821: Error: `lfence' is not supported on `k1om'
/tmp/iccDgxoGdas_.s:47905: Error: `lfence' is not supported on `k1om'
/tmp/iccDgxoGdas_.s:48119: Error: `lfence' is not supported on `k1om'
make: *** [../supersonic/base/infrastructure/projector.o] Error 1
but when I compile it with G++ and without option -mmic, it worked.
anybody can explain to me why the errors happens and how to fix them?
and are there any options that are similar to '-mmic' in G++ so that I can compile supersonic with G++ instead of icc?
Thank you very much for any help!
Frances_R_Intel
I'm afraid using a different compiler won't help. I didn't know this before but I just checked it in the Intel® Xeon Phi™ Coprocessor Instruction Set Architecture Reference Manual to be sure - there is no LFENCE instruction on the coprocessor. I think if you tried compiling the code for the host instead of the coprocessor (if you took the -mmic off the command line) you would find that the code would compiler the same as it did using g++. If you tried compiling with g++ for the coprocessor (there is a cross-compiler in /usr/linux-k1om-4.7/bin/ on the host) you will find yourself having the same problem as you did with 'icc -mmic'.
As to what you can do about this - it will really depend on where that lfence is coming from and if the source code provides an alternative. I am kind of suspicious that the assembly code is not being generated correctly - that it isn't really coprocessor code. Perhaps the -mmic is getting lost somewhere?
JJK
New Contributor III
quick analysis:
  • supersonic depends on Google's glog, gflags and protobuf.
  • glog and gflags build for the Xeon Phi
  • However, the "lfence" instruction is present as inline assembly in the protobuf code
  • The "configure" script for protobuf does not recognize the k1om architecture and detects x86_64 instead - which triggers the inline assembly code
Solution:
- port 'protobuf' to the mic: I am not sure what is needed for this (modify the config.sub code? specify an architecture flag?)
- then recompile the supersonic code again, and override the location of the glog, gflags and protobuf libraries using the appropriate environment variables.
Frances_R_Intel
Ah, yes. Thank you, Jan Just K., for pointing out that this code uses a configure script. Perhaps this comment, describing how to modify your environment and 'gnu-configurize' the script.will help - https://software.intel.com/en-us/forums/topic/401046#comment-1786509.
anxuan_y_
Jan Just K. wrote:
quick analysis:
Solution:
Thanks very much for your reply, your solution sounds reasonable, I will try and see whether it work.
anxuan_y_
Okey, Thank you very much Frances, I will try whether it help.
