Software Archive
Read-only legacy content
17060 Discussions
Connecting coprocessor to bridge to communicate with internet
Eric_B_2
I am running Ubuntu 14.04 with a xeon phi 31s1p and I have been trying to set up a bridge so that I can have the phi access the internet, although I have been having a lot of trouble and can't seem to figure out what's wrong. I'm pretty sure the bridge itself is fine but the phi can't connect to it, anytime I try and use the simple command for it to connect to the bridge it gives this:
/var/mpss/mic0/etc/network# micctrl --network=static --bridge=br0 --ip=172.31.1.1
  [Error] br0: Failed - required brctl command not installed
But it is installed...some mess with the mpss tooling.
The output of ifconfig is the following:
br0       Link encap:Ethernet  HWaddr 30:85:a9:a7:d0:06
          inet addr:192.168.0.100  Bcast:192.168.0.255  Mask:255.255.255.0
          inet6 addr: fe80::3285:a9ff:fea7:d006/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:1768 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1635 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:552300 (552.3 KB)  TX bytes:294748 (294.7 KB)
eth0      Link encap:Ethernet  HWaddr 30:85:a9:a7:bb:27
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
          Interrupt:17 Memory:f0800000-f0820000
eth1      Link encap:Ethernet  HWaddr 30:85:a9:a7:d0:06
          RX packets:48290 errors:0 dropped:5 overruns:0 frame:0
          TX packets:33720 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:13352617 (13.3 MB)  TX bytes:6396673 (6.3 MB)
          Interrupt:18 Memory:f0700000-f0720000
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:119 errors:0 dropped:0 overruns:0 frame:0
          TX packets:119 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:18648 (18.6 KB)  TX bytes:18648 (18.6 KB)
mic0      Link encap:Ethernet  HWaddr 4a:79:ba:15:00:21
          inet addr:172.31.1.254  Bcast:172.31.1.255  Mask:255.255.255.0
          UP BROADCAST RUNNING  MTU:1500  Metric:1
          RX packets:4 errors:0 dropped:0 overruns:0 frame:0
          TX packets:2068 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:1056 (1.0 KB)  TX bytes:321903 (321.9 KB)
-Eric
