I have successfully been able to add an App onto the Android Store.
But I am now trying to get notifications on the app.
So far I've only been able to see Firebase which allows you to easily add notifications.
However, I need to add Firebase to my app but on the website
https://firebase.google.com/docs/android/setup
It only allows this through Android Studio. Is there any way around this in Intel XDK?
Edit: If its possible please list the example of the code used.
- Tags:
- HTML5
- Intel® XDK
You need to use a Cordova plugin. This one might help > https://www.npmjs.com/package/cordova-plugin-firebase < unfortunately, that plugin uses a gradle script, which means you cannot use our build system with that plugin. You may have to find another notification plugin, there are many out there; some of them will work with our build system, see these FAQs for additional details:
Hi i have the same problem. i dont know if you find a solution. i was looking for www.onesignal.com
give you intruccion and tutorials to do the notifications using One Signal and conect to firebase.
But im Stuck in the Script i have tu put on mi APP (APK).
Couse the APK does not conecct with Onesignal.
Should by simple, but cant make it work.
// Add to index.js or the first page that loads with your app.
// For Intel XDK and please add this to your app.js.
document.addEventListener('deviceready', function () {
// Enable to debug issues.
// window.plugins.OneSignal.setLogLevel({logLevel: 4, visualLevel: 4});
var notificationOpenedCallback = function(jsonData) {
//console.log('notificationOpenedCallback: ' + JSON.stringify(jsonData));
alert("La Notificacion fue Recivida");
window.plugins.OneSignal.init("ONESIGNAL_ID_APP",)
{googleProjectNumber:"NUMBER_ID_FIREBASE"},
notificationOpenedCallback);
//window.plugins.OneSignal
// .startInit("67c4fa25-20f0-4b00-b6ad-2192cc825113")
// .handleNotificationOpened(notificationOpenedCallback)
// .endInit();
window.plugins.OneSignal.setSubscription(true);
window.plugins.OneSignal.enableNotificationWhenActive(true);
// Sync hashed email if you have a login system or collect it.
// Will be used to reach the user at the most optimal time of day.
// window.plugins.OneSignal.syncHashedEmail(userEmail);
}, false);
