Greetings of the day,
I'm using ASMX web service for saving data on to the server using ajax call, but the call does not return me anything even it does not alert me sucess of failure for HTTP request, Is there any way which will definitely tell me what's the problem between the call, need help in calling ASMX web service in intel XDK or should I directely make a ajax call like we do from a HTML Page . Hope you guys understand the issue and revert back as soon as possible.
Thanks and regards
Vaibhav Hedaoo
- Tags:
- HTML5
- Intel® XDK
Here is a simple example, I have concatenated the data to send to the server and the ASMX webservice splits it, but these values could be sent as individual values. A True or False is returned to the Javascript function dependant on whether the write was successful or not.
ASMX Webservice code:-
Imports System.Web
Imports System.Web.Services
Imports System.Web.Services.Protocols
Imports System.Data.MySqlClient
Imports System.Data
Imports System.Text
Imports System
Imports System.Web.Script.Services
Imports System.Web.Script.Serialization
' To allow this Web Service to be called from script, using ASP.NET AJAX, uncomment the following line.
<System.Web.Script.Services.ScriptService()> _
<WebService(Namespace:=<a data-cke-saved-href="http://myURL" href="http://myURL">http://myURL</a>)> _
<WebServiceBinding(ConformsTo:=WsiProfiles.BasicProfile1_1)> _
<Global.Microsoft.VisualBasic.CompilerServices.DesignerGenerated()> _
Public Class Service
Inherits System.Web.Services.WebService
Dim encodedpassword As String
Dim SQLServerStr As String = "xxx.xxx.xxx.xxx"
Dim SQLUserStr As String = "Username"
Dim SQLPassStr As String = "Password"
Dim myConnString As String = String.Format("server={0};user id={1};password={2}; pooling=false", SQLServerStr, SQLUserStr, SQLPassStr)
Dim myconn As New MySqlConnection(myConnString)
Dim sql As String
Dim mycommand As New MySqlCommand
Dim ds As New DataSet
Dim da As MySqlDataAdapter
<WebMethod()> _
Public Function saveData(ByVal data As String) As String
'Try
Dim myData() As String = Split(data, ",")
Dim Name As String = myData(0)
Dim Age As Date = myData(1)
mycommand.Connection = myconn
If myconn.State <> ConnectionState.Open Then
myconn.Open()
End If
sql = "INSERT INTO mytable(name,age) VALUES("
sql = sql & "'" & Name & "',"
sql = sql & Age & "); SELECT LAST_INSERT_ID()"
mycommand.CommandText = sql
Dim RowAdded As Integer = mycommand.ExecuteScalar()
myconn.Close()
If RowAdded > 0 Then
myconn.Close()
Return True
Else
myconn.Close()
Return False
End If
'Catch ex As Exception
' myconn.Close()
' Return False
'End Try
End Function
Here is the XDK Javascript element that calls the ASMX to write to your database.
function saveData(){
var dataStr = $("#name").val()+","+$("#age").val();
$.ajax({
type: "POST",
url: "http://myURL/service1.asmx/saveData",
data: "{'data':'" + dataStr + "'}",
contentType: "application/json; charset=utf-8",
dataType: "json",
async: true,
crossDomain: true,
success: function (msg) {
if (msg.d) {
navigator.notification.alert("Data Saved",afterSaveData,"Success");
else
navigator.notification.alert("Unable to save data.",Dismissed,"Error");
error: function(msg) {
navigator.notification.alert("Unable to save data:" + msg.d);
return false;
Hello Nick,
Thanks a lot for helping me
Great work done by you. Before Posting question I have tried a lot and also tried the code which you posted but code is still not working for me. also I have make proper domain whitelisting, but still I'm not getting anything in the ajax call response. I don't know what's going wrong with my code.
Hi
I won't know without looking at your code.
Can you zip up the ASMX file and XDK project and send me the files via a private message.
I'll take a look for you.
