Software Archive
Read-only legacy content
17060 Discussions
Controlling the output of Gestures
Fadi_H_
Hello Guys,
I am creating a program in Java for my Bachelor Thesis,
Scenario: Its an Image viewer controller by Gestures (Swipe right and left for next and prev.)
The images are saved in an array m.
Problem: When i use swipe gesture once, it repeates the action 2-4 times, so it skips some images.
Its the same situation when i add println("swiping left"), then i shows "swiping left" repeated in the console.
What should i change to make the Program work more stable (for example "one order per 2 seconds")?
Part of the Code:
if (sts.compareTo(pxcmStatus.PXCM_STATUS_NO_ERROR) >= 0) {
			senseManager.Init();  //initialize if no error
			for (int nframes = 0; nframes < 3000; nframes++) {
			sts = senseManager.AcquireFrame(true);
			if (sts.compareTo(pxcmStatus.PXCM_STATUS_NO_ERROR) < 0)
			break;
				while (senseManager.AcquireFrame(true).isSuccessful()) {
				// Retrieve current hand tracking results
				handData = handModule.CreateOutput();
				handData.Update();
				PXCMHandData.IHand hand = new PXCMHandData.IHand();
				sts = handData.QueryHandData(PXCMHandData.AccessOrderType.ACCESS_ORDER_BY_TIME,0,hand);
				//getting the 4 gestures
				if (handData.IsGestureFired("swipe_left", gestureData)) {
					System.out.println("swipe left!!");
					if(i==0)
				     JOptionPane.showMessageDialog(null,"This is first Image");
						else{
						i=i-1;           //previous image in the array m
					    l.setIcon(m);
				else if (handData.IsGestureFired("swipe_right", gestureData)) {
					System.out.println("swipe right!!");
					if(i==m.length-1)
				     JOptionPane.showMessageDialog(null,"This is Last Image");
					    else {
				    	i=i+1;                    //next image in the array m
				        l.setIcon(m);
				else if (handData.IsGestureFired("thumb_up", gestureData)) {
					System.out.println("thumb up!!");
				else if (handData.IsGestureFired("thumb_down", gestureData)) {
						System.out.println("thumb down!!");
				senseManager.ReleaseFrame();
			handData.close();
			senseManager.close();
Xusheng_L_Intel
You can detect the gestureData.state to avoid this issue. You can either use GESTURE_STATE_START or GESTURE_STATE_END.
Fadi_H_
Hello David, thanx for your comment. i was searching for an example about GESTURE_STATE_START and as always, no examples in java...
could you please where should i put GESTURE_STATE_START in the code?
first i defined it like this:   GestureStateType state = GestureStateType.GESTURE_STATE_START;
where should i put what to make it work as wished?
thank you!
Fadi_H_
gesture.Data.state equals null the whole time, thats what i saw in debugging
what does that mean and how correct it?
