I built my cordova 5.1.1 android apk using the newest XDK released this week. I'm using standard plugins: media, device, file transfer, file, inappbrowser, notification, camera and capture at their default versions. No 3rd party plugins.
It builds ok but the APK won't install on android 5.0 (and other versions) with a "Parse Error".
Not sure what to do. Ideas?
You can see the apk at http://www.insurance-services.us/apk/p8.apk .
Thanks in advance,
Rich
PS - (sorry if this posted twice to the forum)
- Tags:
- HTML5
- Intel® XDK
Any ideas? Based on the limited research I've been able to do, it looks like something is wrong with the manifest (generated by the XDK).
I generated below with the aapt tool. Does anything pop out as incorrect? Does anyone know how I can use aapt to validate the apk?
Archive: c:\xer\apk\p14.apk
Length Method Size Ratio Offset Date Time CRC-32 Name
17554 Deflate 5954 66% 0 09-25-15 02:04 efbea595 META-INF/MANIFEST.MF
17675 Deflate 6047 66% 6020 09-25-15 02:04 806ff7b8 META-INF/APPMOBI.SF
828 Deflate 723 13% 12132 09-25-15 02:04 a20a3cf5 META-INF/APPMOBI.DSA
4560 Deflate 1352 70% 12921 09-25-15 02:04 0216bec6 AndroidManifest.xml
1268 Deflate 550 57% 14342 09-25-15 02:04 49a9a753 assets/www/app/deviceCheck.js
4397 Deflate 1395 68% 14967 09-25-15 02:04 c397a0e3 assets/www/app/springboard.js
186 Deflate 114 39% 16437 09-25-15 02:04 af3c7aee assets/www/closeit.html
2146 Deflate 846 61% 16620 09-25-15 02:04 2d25784c assets/www/config.xml
1322 Deflate 675 49% 17533 09-25-15 02:04 6851f99d assets/www/cordova-js-src/android/nativeapiprovider.js
1441 Deflate 746 48% 18308 09-25-15 02:04 90b7c094 assets/www/cordova-js-src/android/promptbasednativeapi.js
10522 Deflate 3440 67% 19157 09-25-15 02:04 1ae46f77 assets/www/cordova-js-src/exec.js
3490 Deflate 1339 62% 22676 09-25-15 02:04 3f8fbacc assets/www/cordova-js-src/platform.js
4005 Deflate 1464 63% 24098 09-25-15 02:04 417c9738 assets/www/cordova-js-src/plugin/android/app.js
63882 Deflate 16214 75% 25655 09-25-15 02:04 c542bed8 assets/www/cordova.js
8755 Deflate 1006 89% 41936 09-25-15 02:04 4d9e28ab assets/www/cordova_plugins.js
3719 Deflate 1471 60% 43017 09-25-15 02:04 063b2f6e assets/www/css/index.css
2516 Deflate 1034 59% 44558 09-25-15 02:04 364fdd4a assets/www/css/style.css
19583 Deflate 5119 74% 45662 09-25-15 02:04 24843e83 assets/www/debugger.js
21565 Deflate 1995 91% 50849 09-25-15 02:04 f78a713f assets/www/dsclaim.js
1168 Deflate 226 81% 52911 09-25-15 02:04 1d8bc103 assets/www/dscommand.js
1922 Deflate 337 82% 53206 09-25-15 02:04 12d4bb1a assets/www/dsdocument.js
25098 Deflate 2236 91% 53613 09-25-15 02:04 8c459d05 assets/www/dspolicy.js
1415 Deflate 254 82% 55917 09-25-15 02:04 601bd012 assets/www/dsquickpolicy.js
57040 Deflate 28999 49% 56244 09-25-15 02:04 d277368f assets/www/fonts/CoveredByYourGrace.ttf
4361 Deflate 1929 56% 85328 09-25-15 02:04 31acbf63 assets/www/fonts/OFL.txt
7577 Stored 7577 0% 87327 09-25-15 02:04 e718e90d assets/www/images/Primero_100x100.png
9648 Stored 9648 0% 94973 09-25-15 02:04 82769a00 assets/www/images/Primero_120x120.png
108447 Stored 108447 0% 104688 09-25-15 02:04 1de1936a assets/www/images/Primero_1242x2208.png
12484 Stored 12484 0% 213207 09-25-15 02:04 65376d2d assets/www/images/Primero_150x150.png
12228 Stored 12228 0% 225760 09-25-15 02:04 ea541881 assets/www/images/Primero_152x152.png
103603 Stored 103603 0% 238056 09-25-15 02:04 929eab10 assets/www/images/Primero_1536x2008.png
11811 Stored 11811 0% 341731 09-25-15 02:04 4729390d assets/www/images/Primero_158x158.png
13550 Stored 13550 0% 353611 09-25-15 02:04 43fadefe assets/www/images/Primero_180x180.png
3448 Stored 3448 0% 367230 09-25-15 02:04 3ef81e31 assets/www/images/Primero_26x26.png
3549 Stored 3549 0% 370744 09-25-15 02:04 597a307c assets/www/images/Primero_30x30.png
19433 Stored 19433 0% 374361 09-25-15 02:04 4303ec15 assets/www/images/Primero_320x426.png
19955 Stored 19955 0% 393861 09-25-15 02:04 7587b6b0 assets/www/images/Primero_320x470.png
20024 Stored 20024 0% 413883 09-25-15 02:04 2a3b23b4 assets/www/images/Primero_320x480.png
29284 Stored 29284 0% 433976 09-25-15 02:04 bf591b63 assets/www/images/Primero_336x336.png
3884 Stored 3884 0% 463328 09-25-15 02:04 9af88522 assets/www/images/Primero_36x36.png
29300 Stored 29300 0% 467280 09-25-15 02:04 1cc1bed0 assets/www/images/Primero_480x640.png
4574 Stored 4574 0% 496648 09-25-15 02:04 8c1001e7 assets/www/images/Primero_48x48.png
4541 Stored 4541 0% 501290 09-25-15 02:04 b282d09a assets/www/images/Primero_50x50.png
5344 Stored 5344 0% 505897 09-25-15 02:04 7012e46c assets/www/images/Primero_60x60.png
36217 Stored 36217 0% 511308 09-25-15 02:04 51be56c3 assets/www/images/Primero_620x300.png
55823 Stored 55823 0% 547593 09-25-15 02:04 0f98d233 assets/www/images/Primero_640x1136.png
49689 Stored 49689 0% 603487 09-25-15 02:04 22bf8a1a assets/www/images/Primero_640x960.png
47237 Stored 47237 0% 653245 09-25-15 02:04 88970ff6 assets/www/images/Primero_720x1280.png
44774 Stored 44774 0% 700553 09-25-15 02:04 e5cd3a46 assets/www/images/Primero_720x960.png
6205 Stored 6205 0% 745394 09-25-15 02:04 7cc037c2 assets/www/images/Primero_72x72.png
68356 Stored 68356 0% 751665 09-25-15 02:04 5ba3f838 assets/www/images/Primero_750x1334.png
49718 Stored 49718 0% 820092 09-25-15 02:04 6941fc8b assets/www/images/Primero_768x1004.png
6343 Stored 6343 0% 869878 09-25-15 02:04 4a736045 assets/www/images/Primero_76x76.png
7845 Stored 7845 0% 876287 09-25-15 02:04 38976af5 assets/www/images/Primero_96x96.png
415 Deflate 288 31% 884197 09-25-15 02:04 b2bdcd2c assets/www/images/annotation-check.svg
883 Deflate 452 49% 884569 09-25-15 02:04 83f3680e assets/www/images/annotation-comment.svg
2168 Deflate 1068 51% 885107 09-25-15 02:04 6ab0da8e assets/www/images/annotation-help.svg
408 Deflate 283 31% 886258 09-25-15 02:04 f53277ce assets/www/images/annotation-insert.svg
1452 Deflate 842 42% 886626 09-25-15 02:04 158fe8a3 assets/www/images/annotation-key.svg
426 Deflate 290 32% 887550 09-25-15 02:04 7b67fbd9 assets/www/images/annotation-newparagraph.svg
158 Deflate 131 17% 887931 09-25-15 02:04 58634a46 assets/www/images/annotation-noicon.svg
1041 Deflate 357 66% 888147 09-25-15 02:04 535a17b9 assets/www/images/annotation-note.svg
1143 Deflate 619 46% 888587 09-25-15 02:04 8a4a5d09 assets/www/images/annotation-paragraph.svg
2545 Stored 2545 0% 889294 09-25-15 02:04 e01fc7b0 assets/www/images/loading-icon.gif
290 Stored 290 0% 891905 09-25-15 02:04 8c7e7238 assets/www/images/shadow.png
24766 Stored 24766 0% 892254 09-25-15 02:04 f92f0c8d assets/www/images/springboard/agenticon.png
31382 Stored 31382 0% 917094 09-25-15 02:04 eb10d27c assets/www/images/springboard/crash.png
47144 Stored 47144 0% 948546 09-25-15 02:04 1452a7f3 assets/www/images/springboard/documents.png
36143 Stored 36143 0% 995764 09-25-15 02:04 08492354 assets/www/images/springboard/idcard.png
30213 Stored 30213 0% 1031979 09-25-15 02:04 9afa4e3b assets/www/images/springboard/login.png
8050 Deflate 4327 46% 1062261 09-25-15 02:04 831381cd assets/www/images/springboard/loginplease.pdf
1019 Stored 1019 0% 1066679 09-25-15 02:04 1271659f assets/www/images/springboard/loginplease.png
67350 Stored 67350 0% 1067775 09-25-15 02:04 7935984d assets/www/images/springboard/payment.png
6075 Stored 6075 0% 1135198 09-25-15 02:04 7b591167 assets/www/images/springboard/pdfview.png
69751 Stored 69751 0% 1141347 09-25-15 02:04 8a87b56b assets/www/images/springboard/photo.png
43684 Stored 43684 0% 1211167 09-25-15 02:04 5f31b6b9 assets/www/images/springboard/quote.png
27970 Stored 27970 0% 1254920 09-25-15 02:04 1d841e2f assets/www/images/springboard/signature.png
2418 Stored 2418 0% 1282966 09-25-15 02:04 ac525c7c assets/www/images/texture.png
21814 Stored 21814 0% 1285446 09-25-15 02:04 e3434c11 assets/www/img/logo.png
124927 Deflate 17016 86% 1307314 09-25-15 02:04 42bb5daa assets/www/index.html
1933 Deflate 880 54% 1324397 09-25-15 02:04 fdfefd5f assets/www/js/index.js
6535 Deflate 1118 83% 1325345 09-25-15 02:04 b3b50016 assets/www/locale.properties
2857 Deflate 998 65% 1326537 09-25-15 02:04 4be03cd4 assets/www/plugins/cordova-open/www/disusered.open.js
3108 Deflate 1227 61% 1327634 09-25-15 02:04 34a02a7f assets/www/plugins/cordova-plugin-camera/www/Camera.js
2157 Deflate 1032 52% 1328961 09-25-15 02:04 ee0d7258 assets/www/plugins/cordova-plugin-camera/www/CameraConstants.js
1221 Deflate 653 47% 1330102 09-25-15 02:04 6177ff06 assets/www/plugins/cordova-plugin-camera/www/CameraPopoverHandle.js
1408 Deflate 743 47% 1330868 09-25-15 02:04 7c6fe870 assets/www/plugins/cordova-plugin-camera/www/CameraPopoverOptions.js
2918 Deflate 1247 57% 1331725 09-25-15 02:04 1303c2ea assets/www/plugins/cordova-plugin-device/www/device.js
2356 Deflate 954 60% 1333072 09-25-15 02:04 466722c6 assets/www/plugins/cordova-plugin-dialogs/www/android/notification.js
5268 Deflate 1681 68% 1334141 09-25-15 02:04 22ec5ecb assets/www/plugins/cordova-plugin-dialogs/www/notification.js
8735 Deflate 2646 70% 1335929 09-25-15 02:04 8836ca71 assets/www/plugins/cordova-plugin-file-transfer/www/FileTransfer.js
1529 Deflate 739 52% 1338688 09-25-15 02:04 65856266 assets/www/plugins/cordova-plugin-file-transfer/www/FileTransferError.js
4671 Deflate 1430 69% 1339545 09-25-15 02:04 8cc12d4e assets/www/plugins/cordova-plugin-file/www/DirectoryEntry.js
2729 Deflate 1115 59% 1341081 09-25-15 02:04 94556fdd assets/www/plugins/cordova-plugin-file/www/DirectoryReader.js
9925 Deflate 2442 75% 1342303 09-25-15 02:04 ae8e0391 assets/www/plugins/cordova-plugin-file/www/Entry.js
2712 Deflate 1162 57% 1344842 09-25-15 02:04 ad2e42a1 assets/www/plugins/cordova-plugin-file/www/File.js
3073 Deflate 1236 60% 1346100 09-25-15 02:04 2129faa9 assets/www/plugins/cordova-plugin-file/www/FileEntry.js
1480 Deflate 770 48% 1347437 09-25-15 02:04 bd954167 assets/www/plugins/cordova-plugin-file/www/FileError.js
11858 Deflate 2208 81% 1348308 09-25-15 02:04 49c718d9 assets/www/plugins/cordova-plugin-file/www/FileReader.js
1621 Deflate 792 51% 1350618 09-25-15 02:04 9b369465 assets/www/plugins/cordova-plugin-file/www/FileSystem.js
1830 Deflate 861 53% 1351512 09-25-15 02:04 0fc53d60 assets/www/plugins/cordova-plugin-file/www/FileUploadOptions.js
1101 Deflate 608 45% 1352482 09-25-15 02:04 c14dbaf3 assets/www/plugins/cordova-plugin-file/www/FileUploadResult.js
9601 Deflate 2477 74% 1353198 09-25-15 02:04 82106f79 assets/www/plugins/cordova-plugin-file/www/FileWriter.js
1335 Deflate 706 47% 1355777 09-25-15 02:04 dc6efa24 assets/www/plugins/cordova-plugin-file/www/Flags.js
957 Deflate 554 42% 1356580 09-25-15 02:04 980af437 assets/www/plugins/cordova-plugin-file/www/LocalFileSystem.js
1485 Deflate 734 51% 1357241 09-25-15 02:04 d5a8bc78 assets/www/plugins/cordova-plugin-file/www/Metadata.js
2581 Deflate 1106 57% 1358075 09-25-15 02:04 f6219b83 assets/www/plugins/cordova-plugin-file/www/ProgressEvent.js
1299 Deflate 712 45% 1359286 09-25-15 02:04 b0611e38 assets/www/plugins/cordova-plugin-file/www/android/FileSystem.js
2547 Deflate 1093 57% 1360108 09-25-15 02:04 0f32dbf4 assets/www/plugins/cordova-plugin-file/www/fileSystemPaths.js
1632 Deflate 821 50% 1361308 09-25-15 02:04 916f4246 assets/www/plugins/cordova-plugin-file/www/fileSystems-roots.js
1046 Deflate 602 42% 1362238 09-25-15 02:04 affda261 assets/www/plugins/cordova-plugin-file/www/fileSystems.js
2981 Deflate 1217 59% 1362943 09-25-15 02:04 04230939 assets/www/plugins/cordova-plugin-file/www/requestFileSystem.js
3859 Deflate 1550 60% 1364269 09-25-15 02:04 6b1017e4 assets/www/plugins/cordova-plugin-file/www/resolveLocalFileSystemURI.js
3721 Deflate 1278 66% 1365936 09-25-15 02:04 5b43f27f assets/www/plugins/cordova-plugin-inappbrowser/www/inappbrowser.js
1270 Deflate 694 45% 1367326 09-25-15 02:04 11bd3946 assets/www/plugins/cordova-plugin-media-capture/www/CaptureAudioOptions.js
1670 Deflate 866 48% 1368140 09-25-15 02:04 bd7393be assets/www/plugins/cordova-plugin-media-capture/www/CaptureError.js
1181 Deflate 656 44% 1369119 09-25-15 02:04 282064e3 assets/www/plugins/cordova-plugin-media-capture/www/CaptureImageOptions.js
1265 Deflate 693 45% 1369895 09-25-15 02:04 d911061d assets/www/plugins/cordova-plugin-media-capture/www/CaptureVideoOptions.js
2058 Deflate 1006 51% 1370708 09-25-15 02:04 ebbcd428 assets/www/plugins/cordova-plugin-media-capture/www/MediaFile.js
1392 Deflate 700 50% 1371824 09-25-15 02:04 3f692404 assets/www/plugins/cordova-plugin-media-capture/www/MediaFileData.js
3237 Deflate 1119 65% 1372638 09-25-15 02:04 7972a62e assets/www/plugins/cordova-plugin-media-capture/www/capture.js
6481 Deflate 2094 68% 1373865 09-25-15 02:04 04f6a95a assets/www/plugins/cordova-plugin-media/www/Media.js
2308 Deflate 1054 54% 1376057 09-25-15 02:04 2cbb8b16 assets/www/plugins/cordova-plugin-media/www/MediaError.js
12436 Deflate 3317 73% 1377214 09-25-15 02:04 087d7ed2 assets/www/signature_pad.js
7432 Deflate 3506 53% 1380604 09-25-15 02:04 066302ea assets/www/vendor/jquery.mobile/AUTHORS.txt
1100 Deflate 644 41% 1384199 09-25-15 02:04 16f68bd9 assets/www/vendor/jquery.mobile/MIT-LICENSE.txt
7825 Stored 7825 0% 1384936 09-25-15 02:04 926aa883 assets/www/vendor/jquery.mobile/images/ajax-loader.gif
340 Stored 340 0% 1392845 09-25-15 02:04 0337988d assets/www/vendor/jquery.mobile/images/ajax-loader.png
1767 Stored 1767 0% 1393272 09-25-15 02:04 db82a569 assets/www/vendor/jquery.mobile/images/icons-18-black.png
1806 Stored 1806 0% 1395127 09-25-15 02:04 3a5dbb0d assets/www/vendor/jquery.mobile/images/icons-18-white.png
3611 Stored 3611 0% 1397022 09-25-15 02:04 a0776612 assets/www/vendor/jquery.mobile/images/icons-36-black.png
3648 Stored 3648 0% 1400723 09-25-15 02:04 a38074a5 assets/www/vendor/jquery.mobile/images/icons-36-white.png
23299 Deflate 3389 85% 1404460 09-25-15 02:04 acc0ca08 assets/www/vendor/jquery.mobile/jquery.mobile-1.1.1-custom.css
12911 Deflate 2345 82% 1407957 09-25-15 02:04 a5d2e28d assets/www/vendor/jquery.mobile/jquery.mobile-1.1.1-custom.min.css
102759 Deflate 14023 86% 1410414 09-25-15 02:04 7a6e178d assets/www/vendor/jquery.mobile/jquery.mobile-1.1.1.css
244345 Deflate 69659 71% 1424538 09-25-15 02:04 c0af0568 assets/www/vendor/jquery.mobile/jquery.mobile-1.1.1.js
66061 Deflate 9804 85% 1494297 09-25-15 02:04 ed9c9f23 assets/www/vendor/jquery.mobile/jquery.mobile-1.1.1.min.css
244345 Deflate 69659 71% 1504206 09-25-15 02:04 c0af0568 assets/www/vendor/jquery.mobile/jquery.mobile-1.1.1.min.js
239943 Deflate 32285 87% 1573969 09-25-15 02:04 60643ef0 assets/www/vendor/jquery.mobile/jquery.mobile-1.4.5.css
465716 Deflate 126440 73% 1606355 09-25-15 02:04 3c8c1c57 assets/www/vendor/jquery.mobile/jquery.mobile-1.4.5.js
207465 Deflate 25197 88% 1732895 09-25-15 02:04 c89ca1f2 assets/www/vendor/jquery.mobile/jquery.mobile-1.4.5.min.css
200143 Deflate 55604 72% 1758197 09-25-15 02:04 2ab0c5e6 assets/www/vendor/jquery.mobile/jquery.mobile-1.4.5.min.js
235912 Deflate 88399 63% 1813905 09-25-15 02:04 f0e4b3e8 assets/www/vendor/jquery.mobile/jquery.mobile-1.4.5.min.map
5032 Deflate 2387 53% 1902409 09-25-15 02:04 7e12f69d assets/www/vendor/jquery/AUTHORS.txt
1099 Deflate 644 41% 1904878 09-25-15 02:04 df52d41f assets/www/vendor/jquery/MIT-LICENSE.txt
258377 Deflate 76776 70% 1905608 09-25-15 02:04 5ee0d58f assets/www/vendor/jquery/jquery-1.8.0.js
92555 Deflate 33079 64% 1982470 09-25-15 02:04 0e445661 assets/www/vendor/jquery/jquery-1.8.0.min.js
270232 Deflate 80272 70% 2015639 09-25-15 02:04 aadb88c7 assets/www/vendor/jquery/jquery-1.8.2-win8-1.0.js
95060 Deflate 33917 64% 2096006 09-25-15 02:04 5e8b950d assets/www/vendor/jquery/jquery-1.8.2-win8-1.0.min.js
15089 Stored 15089 0% 2130022 09-25-15 02:04 726b563b assets/www/win8-images/logo.png
1099 Stored 1099 0% 2145173 09-25-15 02:04 c839b383 assets/www/win8-images/smalllogo.png
140050 Stored 140050 0% 2146339 09-25-15 02:04 7886df92 assets/www/win8-images/splashscreen.png
3240 Stored 3240 0% 2286458 09-25-15 02:04 c1dcb3ab assets/www/win8-images/storelogo.png
5170 Deflate 1202 77% 2289764 09-25-15 02:04 e44a6fb2 assets/www/win8-proj/jqm-springboard-nav.jsproj
2512 Stored 2512 0% 2291059 09-25-15 02:04 94e762e4 assets/www/win8-proj/jqm-springboard-nav_TemporaryKey.pfx
1092 Deflate 521 52% 2293660 09-25-15 02:04 78f45acd assets/www/win8-proj/package.appxmanifest
393 Deflate 283 28% 2294268 09-25-15 02:04 ff6e60a0 assets/www/xdk/project-info.json
577 Deflate 225 61% 2294629 09-25-15 02:04 1ede1513 assets/www/xdk/services/service-credentials.js
148053 Deflate 19137 87% 2294946 09-25-15 02:04 7e1310fb assets/www/xdk/services/service-methods.js
9685 Deflate 2572 73% 2314171 09-25-15 02:04 d9fb7759 assets/www/xdk/services/xml2json.js
275 Stored 275 0% 2316824 09-25-15 02:04 0a2c1c81 res/drawable-hdpi-v4/ic_action_next_item.png
276 Stored 276 0% 2317175 09-25-15 02:04 893b2449 res/drawable-hdpi-v4/ic_action_previous_item.png
231 Stored 231 0% 2317532 09-25-15 02:04 0f911ab1 res/drawable-hdpi-v4/ic_action_remove.png
3472 Stored 3472 0% 2317835 09-25-15 02:04 0bfc0b32 res/drawable-hdpi-v4/icon.png
1151 Stored 1151 0% 2321368 09-25-15 02:04 d3f7afb7 res/drawable-ldpi-v4/icon.png
225 Stored 225 0% 2322579 09-25-15 02:04 09532a9d res/drawable-mdpi-v4/ic_action_next_item.png
226 Stored 226 0% 2322881 09-25-15 02:04 ab4b63d4 res/drawable-mdpi-v4/ic_action_previous_item.png
186 Stored 186 0% 2323186 09-25-15 02:04 8948bd33 res/drawable-mdpi-v4/ic_action_remove.png
1840 Stored 1840 0% 2323446 09-25-15 02:04 adc2881f res/drawable-mdpi-v4/icon.png
26521 Stored 26521 0% 2325348 09-25-15 02:04 ec7f39ba res/drawable-port-hdpi-v4/screen.png
16719 Stored 16719 0% 2351937 09-25-15 02:04 2b394b7d res/drawable-port-ldpi-v4/screen.png
17244 Stored 17244 0% 2368723 09-25-15 02:04 4c01ae5c res/drawable-port-mdpi-v4/screen.png
41627 Stored 41627 0% 2386036 09-25-15 02:04 fc79428b res/drawable-port-xhdpi-v4/screen.png
308 Stored 308 0% 2427731 09-25-15 02:04 f9f1f695 res/drawable-xhdpi-v4/ic_action_next_item.png
311 Stored 311 0% 2428116 09-25-15 02:04 b94b51a4 res/drawable-xhdpi-v4/ic_action_previous_item.png
260 Stored 260 0% 2428507 09-25-15 02:04 e9eac05c res/drawable-xhdpi-v4/ic_action_remove.png
5112 Stored 5112 0% 2428840 09-25-15 02:04 9c1ef09f res/drawable-xhdpi-v4/icon.png
383 Stored 383 0% 2434012 09-25-15 02:04 25342d6f res/drawable-xxhdpi-v4/ic_action_next_item.png
389 Stored 389 0% 2434471 09-25-15 02:04 e3a4da97 res/drawable-xxhdpi-v4/ic_action_previous_item.png
338 Stored 338 0% 2434941 09-25-15 02:04 bf9c84db res/drawable-xxhdpi-v4/ic_action_remove.png
9616 Deflate 2748 71% 2435354 09-25-15 02:04 a8e6d84b res/xml/config.xml
3036 Stored 3036 0% 2438166 09-25-15 02:04 2c35e379 resources.arsc
328124 Deflate 116365 65% 2441248 09-25-15 02:04 91ff8cf4 classes.dex
5353924 2542383 53% 183 files
Resource table:
Package Groups (1)
Package Group 0 id=0x7f packageCount=1 name=Primero.InsuredApp.v1
Package 0 id=0x7f name=Primero.InsuredApp.v1
type 1 configCount=9 entryCount=5
spec resource 0x7f020000 Primero.InsuredApp.v1:drawable/ic_action_next_item: flags=0x00000100
spec resource 0x7f020001 Primero.InsuredApp.v1:drawable/ic_action_previous_item: flags=0x00000100
spec resource 0x7f020002 Primero.InsuredApp.v1:drawable/ic_action_remove: flags=0x00000100
spec resource 0x7f020003 Primero.InsuredApp.v1:drawable/icon: flags=0x00000100
spec resource 0x7f020004 Primero.InsuredApp.v1:drawable/screen: flags=0x00000100
config ldpi-v4:
resource 0x7f020003 Primero.InsuredApp.v1:drawable/icon: t=0x03 d=0x00000001 (s=0x0008 r=0x00)
config port-ldpi-v4:
resource 0x7f020004 Primero.InsuredApp.v1:drawable/screen: t=0x03 d=0x00000002 (s=0x0008 r=0x00)
config mdpi-v4:
resource 0x7f020000 Primero.InsuredApp.v1:drawable/ic_action_next_item: t=0x03 d=0x00000003 (s=0x0008 r=0x00)
resource 0x7f020001 Primero.InsuredApp.v1:drawable/ic_action_previous_item: t=0x03 d=0x00000004 (s=0x0008 r=0x00)
resource 0x7f020002 Primero.InsuredApp.v1:drawable/ic_action_remove: t=0x03 d=0x00000005 (s=0x0008 r=0x00)
resource 0x7f020003 Primero.InsuredApp.v1:drawable/icon: t=0x03 d=0x00000006 (s=0x0008 r=0x00)
config port-mdpi-v4:
resource 0x7f020004 Primero.InsuredApp.v1:drawable/screen: t=0x03 d=0x00000007 (s=0x0008 r=0x00)
config hdpi-v4:
resource 0x7f020000 Primero.InsuredApp.v1:drawable/ic_action_next_item: t=0x03 d=0x00000008 (s=0x0008 r=0x00)
resource 0x7f020001 Primero.InsuredApp.v1:drawable/ic_action_previous_item: t=0x03 d=0x00000009 (s=0x0008 r=0x00)
resource 0x7f020002 Primero.InsuredApp.v1:drawable/ic_action_remove: t=0x03 d=0x0000000a (s=0x0008 r=0x00)
resource 0x7f020003 Primero.InsuredApp.v1:drawable/icon: t=0x03 d=0x0000000b (s=0x0008 r=0x00)
config port-hdpi-v4:
resource 0x7f020004 Primero.InsuredApp.v1:drawable/screen: t=0x03 d=0x0000000c (s=0x0008 r=0x00)
config xhdpi-v4:
resource 0x7f020000 Primero.InsuredApp.v1:drawable/ic_action_next_item: t=0x03 d=0x0000000d (s=0x0008 r=0x00)
resource 0x7f020001 Primero.InsuredApp.v1:drawable/ic_action_previous_item: t=0x03 d=0x0000000e (s=0x0008 r=0x00)
resource 0x7f020002 Primero.InsuredApp.v1:drawable/ic_action_remove: t=0x03 d=0x0000000f (s=0x0008 r=0x00)
resource 0x7f020003 Primero.InsuredApp.v1:drawable/icon: t=0x03 d=0x00000010 (s=0x0008 r=0x00)
config port-xhdpi-v4:
resource 0x7f020004 Primero.InsuredApp.v1:drawable/screen: t=0x03 d=0x00000011 (s=0x0008 r=0x00)
config xxhdpi-v4:
resource 0x7f020000 Primero.InsuredApp.v1:drawable/ic_action_next_item: t=0x03 d=0x00000012 (s=0x0008 r=0x00)
resource 0x7f020001 Primero.InsuredApp.v1:drawable/ic_action_previous_item: t=0x03 d=0x00000013 (s=0x0008 r=0x00)
resource 0x7f020002 Primero.InsuredApp.v1:drawable/ic_action_remove: t=0x03 d=0x00000014 (s=0x0008 r=0x00)
type 2 configCount=1 entryCount=1
spec resource 0x7f030000 Primero.InsuredApp.v1:xml/config: flags=0x00000000
config (default):
resource 0x7f030000 Primero.InsuredApp.v1:xml/config: t=0x03 d=0x00000000 (s=0x0008 r=0x00)
type 3 configCount=1 entryCount=3
spec resource 0x7f040000 Primero.InsuredApp.v1:string/activity_name: flags=0x00000000
spec resource 0x7f040001 Primero.InsuredApp.v1:string/app_name: flags=0x00000000
spec resource 0x7f040002 Primero.InsuredApp.v1:string/launcher_name: flags=0x00000000
config (default):
resource 0x7f040000 Primero.InsuredApp.v1:string/activity_name: t=0x01 d=0x7f040002 (s=0x0008 r=0x00)
resource 0x7f040001 Primero.InsuredApp.v1:string/app_name: t=0x03 d=0x00000015 (s=0x0008 r=0x00)
resource 0x7f040002 Primero.InsuredApp.v1:string/launcher_name: t=0x01 d=0x7f040001 (s=0x0008 r=0x00)
Android manifest:
N: android=http://schemas.android.com/apk/res/android
E: manifest (line=2)
A: android:versionCode(0x0101021b)=(type 0x10)0x13
A: android:versionName(0x0101021c)="1.2.3" (Raw: "1.2.3")
A: android:installLocation(0x010102b7)=(type 0x10)0x0
A: android:hardwareAccelerated(0x010102d3)=(type 0x12)0xffffffff
A: package="Primero.InsuredApp.v1" (Raw: "Primero.InsuredApp.v1")
A: platformBuildVersionCode=(type 0x10)0x16 (Raw: "22")
A: platformBuildVersionName="5.1.1-1819727" (Raw: "5.1.1-1819727")
E: uses-sdk (line=9)
A: android:minSdkVersion(0x0101020c)=(type 0x10)0x16
A: android:targetSdkVersion(0x01010270)=(type 0x10)0x16
E: supports-screens (line=13)
A: android:anyDensity(0x0101026c)=(type 0x12)0xffffffff
A: android:smallScreens(0x01010284)=(type 0x12)0xffffffff
A: android:normalScreens(0x01010285)=(type 0x12)0xffffffff
A: android:largeScreens(0x01010286)=(type 0x12)0xffffffff
A: android:resizeable(0x0101028d)=(type 0x12)0xffffffff
A: android:xlargeScreens(0x010102bf)=(type 0x12)0xffffffff
E: uses-permission (line=21)
A: android:name(0x01010003)="android.permission.INTERNET" (Raw: "android.permission.INTERNET")
E: uses-permission (line=22)
A: android:name(0x01010003)="android.permission.ACCESS_NETWORK_STATE" (Raw: "android.permission.ACCESS_NETWORK_STATE")
E: uses-permission (line=23)
A: android:name(0x01010003)="android.permission.ACCESS_WIFI_STATE" (Raw: "android.permission.ACCESS_WIFI_STATE")
E: uses-permission (line=24)
A: android:name(0x01010003)="android.permission.WRITE_EXTERNAL_STORAGE" (Raw: "android.permission.WRITE_EXTERNAL_STORAGE")
E: uses-permission (line=25)
A: android:name(0x01010003)="android.permission.RECORD_AUDIO" (Raw: "android.permission.RECORD_AUDIO")
E: uses-permission (line=26)
A: android:name(0x01010003)="android.permission.MODIFY_AUDIO_SETTINGS" (Raw: "android.permission.MODIFY_AUDIO_SETTINGS")
E: uses-permission (line=27)
A: android:name(0x01010003)="android.permission.READ_PHONE_STATE" (Raw: "android.permission.READ_PHONE_STATE")
E: uses-permission (line=28)
A: android:name(0x01010003)="android.permission.RECORD_VIDEO" (Raw: "android.permission.RECORD_VIDEO")
E: uses-permission (line=29)
A: android:name(0x01010003)="android.permission.android.permission.WRITE_EXTERNAL_STORAGE" (Raw: "android.permission.android.permission.WRITE_EXTERNAL_STORAGE")
E: uses-permission (line=30)
A: android:name(0x01010003)="android.permission.android.permission.READ_EXTERNAL_STORAGE" (Raw: "android.permission.android.permission.READ_EXTERNAL_STORAGE")
E: uses-permission (line=31)
A: android:name(0x01010003)="android.permission.READ_EXTERNAL_STORAGE" (Raw: "android.permission.READ_EXTERNAL_STORAGE")
E: application (line=33)
A: android:label(0x01010001)=@0x7f040001
A: android:icon(0x01010002)=@0x7f020003
A: android:debuggable(0x0101000f)=(type 0x12)0x0
A: android:supportsRtl(0x010103af)=(type 0x12)0xffffffff
E: activity (line=39)
A: android:theme(0x01010000)=@0x1030009
A: android:label(0x01010001)=@0x7f040000
A: android:name(0x01010003)="Primero.InsuredApp.v1.MainActivity" (Raw: "Primero.InsuredApp.v1.MainActivity")
A: android:launchMode(0x0101001d)=(type 0x10)0x1
A: android:configChanges(0x0101001f)=(type 0x11)0x4b4
A: android:windowSoftInputMode(0x0101022b)=(type 0x11)0x10
E: intent-filter (line=46)
A: android:label(0x01010001)=@0x7f040002
E: action (line=47)
A: android:name(0x01010003)="android.intent.action.MAIN" (Raw: "android.intent.action.MAIN")
E: category (line=49)
A: android:name(0x01010003)="android.intent.category.LAUNCHER" (Raw: "android.intent.category.LAUNCHER")
Couple questions for you:
Did you recently update your device?
Were you able to install XDK built APK's on the device prior to update?
Do you get this error with all XDK built APK's?
What is the device?
Try changing his package name from Primero.InsuredApp.v1 to primero.InsuredApp.v1
The upper case starting letter might be making it fail
Wow! It's working!
I changed my package name to "primero.insuredapp.v1" . Also changed min/target versions to "19" with the 5.1.1 build.
Thanks!
Just for the benefit of others:
Did you recently update your device? NO
Were you able to install XDK built APK's on the device prior to update? I was able to install older CLI versions, but never 5.1.1 .
Do you get this error with all XDK built APK's? No, seemed to get it more with 5.1.1 .
What is the device? Nextbook Ares 8.
Thanks again!
I got parse errors during installation of package on Android 5.0.2. (using cordova 5.4.1). Found out that the source of the problem was the fact that I hadn't checked the "Signed" check box on building options. I'm writing it here couse it might save someone's time.
