Software Archive
Read-only legacy content
17060 Discussions
Cordova Build Server don't work
A_B_3
I don't receive e-mail with link after pressing "Build App Now". I did 50 attempts in 2 days already.
Is it holidays begin?
PaulF_IntelCorp
The build server does not go on holidays. :) We have had some issues with the build server not sending out that email, the root of the problem is still under investigation. Do you get a build complete message in the XDK, with a download link? If so, you can download the build from that page, you don't need the email to download the built package.
John_H_Intel2
You only get the email if your build succeeds. Are you seeing the build successful screen?
A_B_3
No, I don't get any answer. No mail, no answer.
Only label "BUILDING" on waiting ring.
Anusha_M_Intel1
You mean the build is taking a long time? How long do you typically wait for the build to end? A screenshot of what you are seeing will be helpful.
Sometimes the build takes a long time. I suggest waiting it out. If you did get a build successful screen, you can directly download the build as a zip file from there.
If you could PM your account details, we might be able to see your last build status.
A_B_3
It takes from 5 minutes and more. It was month ago. Now I don't get a build successful screen at all. And no email with link.
It may depends on Internet connection. If you tell IP address of Cordova Build Server, I can write ping or tracert logs.
That forum is not friendly for Retina screen shots -
The specified file Screen Shot 2015-12-21 at 21.39.26.png could not be uploaded. Maximum allowed dimensions for image uploads are 2000 x 1000.
PaulF_IntelCorp
We can't give you an IP address to the build server, the App Center is the main frontend for building. It can be located via this address: http://appcenter.html5tools-software.intel.com/
John_H_Intel2
I see you did a couple successful build for your app. Try removing the plugin/folder com.ezartech.ezar from your app and reupload/building.
A_B_3
Yes, the problem was there. It was a bug in third-part Cordova plugin. I fixed it and began to receive email with link from Build server.
Thanks for everybody and get congratulations with holidays!
