Software Archive
Read-only legacy content
17060 Discussions
Cordova Build - email download links and iOS OTA links
Kevin_L_2
How long are the download links that are in the automatic emails good for?  This is for both the download links and the OTA links.
Thanks!
John_H_Intel2
The OTA links are good until you build again. Once you build again, only the most recent email will work.
Kevin_L_2
I think the trouble I'm running into is that I build one application and send out the links for people to download and install, but then I build another application and now the previously distributed links no longer work.
Is my understanding of this correct?  If so, then there should be a separate link per application and per build type.
Swati_S_Intel1
Hi Kevin,
There is a separate link for each app for each platform and they are valid for 30 days or until you build for the same app on same platform.
Swati
Kevin_L_2
Sorry, but that isn't what I'm experiencing.
Here is the scenario I am having troubles with:
Built App1 using Cordova iOS --> used OTA link1 to install App1:  App1 installed successfully.
Built App2 using Cordova iOS --> used OTA link2 to install App2:  App2 installed successfully.
Uninstalled App1 --> used OTA link1 to install App1:  "Unable to Download Application:  'App1' could not be downloaded at this time."
John_H_Intel2
I can not reproduce this, it works fine for me. Are you sure you are using the correct email?
Kevin_L_2
Yes, I'm sure it was the same email.  This may all be related to another issue I'm having with my account being a legacy appMobi account.  This problem is an inconvenience, but we can work around it.  I plan to contact your team at a later time to have my account deleted and start over; perhaps that will fix it.
