Hey there,
I marked cordovas "File"-Plugin to be included in my APP.
On "Emulate" in JS "cordova.file" exists, but all Settings are "null". When using AppPreview on my iOS / Windows Phone (doesn't matter if using "Server Apps" or connected device via USB and "Debug" tab) "cordova.file" is undefined...
WHAT can I do?
- Tags:
- HTML5
- Intel® XDK
This should get you going. Make sure you have enabled the file plugin and pushed your app to the cloud.
FILE<br>
<button onclick="writeFile();">write file</button><br>
<p id="fileWritten"></p>
<button onclick="readFile();">read file</button><br>
<p id="fileRead"></p>
// file write stuff
function writeFile()
window.requestFileSystem(LocalFileSystem.PERSISTENT, 0, gotFS, fail);
function gotFS(fileSystem) {
fileSystem.root.getFile("readme.txt", {create: true, exclusive: false}, gotFileEntry, fail);
function gotFileEntry(fileEntry) {
fileEntry.createWriter(gotFileWriter, fail);
function gotFileWriter(writer) {
console.log("success");
var element = document.getElementById('fileWritten');
element.innerHTML = "file written successfully";
/*writer.onwriteend = function(evt) {
console.log("contents of file now 'some sample text'");
writer.truncate(11);
console.log("contents of file now 'some sample'");
writer.seek(4);
writer.write(" different text");
writer.onwriteend = function(evt){
console.log("contents of file now 'some different text'");
var d = new Date();
var n = d.toString();
writer.write("jph was here!" + n + "<br>");
function fail(error) {
console.log(error.code);
element.innerHTML = "file write FAILED";
// read file
function readFile()
window.requestFileSystem(LocalFileSystem.PERSISTENT, 0, gotFSRead, failRead);
function gotFSRead(fileSystem) {
fileSystem.root.getFile("readme.txt", null, gotFileEntryRead, failRead);
function gotFileEntryRead(fileEntry) {
//alert("read success");
var element = document.getElementById('fileRead');
element.innerHTML = "file read successfully";
fileEntry.file(gotFileRead, failRead);
function gotFileRead(file){
readAsText(file);
//readDataUrl(file);
function readDataUrl(file) {
var reader = new FileReader();
reader.onloadend = function(evt) {
console.log("Read as data URL");
console.log(evt.target.result);
reader.readAsDataURL(file);
function readAsText(file) {
console.log("Read as text");
//alert(evt.target.result);
element.innerHTML += "<br>" + evt.target.result;
reader.readAsText(file);
function failRead(error) {
console.log("error code = " + error.code);
alert("read failed, error code = " + error.code);
