Software Archive
Read-only legacy content
17061 Discussions
Cordova build failed
Nayab_S_
The build failed. An error occurred while building the application. Verify your build assets are correct and try again. Same problem for all projects which are build successfully those are not build now.
John_H_Intel2
What platform is this for?
Can you attach a text file of the build log instead of a screenshot?
Nayab_S_
This is for Android platform.
470832
John_H_Intel2
Looks like you are including a bunch of 3rd party plugins. Try removing them and see if the build succeeds. If it does, add them in one by one until you find the offending plugins that is causing you issues.
Nayab_S_
I just removed all my 3rd party plugins, even though same error comming.470853
John_H_Intel2
Found your issue.
Remove all of the entries in the Add Permissions input field for Android and you will see the text there that tells you what you can enter.
It says it must be a ;  (semi-colon) separated list, not a comma separated list like you entered it as. Hence the , error in the build log.
Nayab_S_
Thank you so much..its working now
In  older version its work fine with " , " without any problem, now its works with " ; "
any reason
John_H_Intel2
No reason :)
What version did it work with , previously?
