Software Archive
Read-only legacy content
Cordova iOS build failed
Raiden_D_
初學者
12,254 檢視
Hi!
What is the problem? Thanks!
The following build commands failed:
	Check dependencies
(1 failure)
Command finished with error code 65: .../<APPNAME>/platforms/ios/cordova/build --release,--device
Error: .../<APPNAME>/platforms/ios/cordova/build: Command failed with exit code 65
    at ChildProcess.whenDone (/Developer/cordova/4.1.2/node_modules/cordova/node_modules/cordova-lib/src/cordova/superspawn.js:135:23)
    at ChildProcess.EventEmitter.emit (events.js:98:17)
    at maybeClose (child_process.js:753:16)
    at Process.ChildProcess._handle.onexit (child_process.js:820:5)
0 積分
23 回應
Brandon_K_Intel
10,540 檢視
Will you please post the whole build log to help me future debug your issue?
Raiden_D_
初學者
10,540 檢視
Full log:
Installing "org.apache.cordova.device" for ios
Generating config.xml from defaults for platform "ios"
Calling plugman.prepare for platform "ios"
Preparing ios project
Processing configuration changes for plugins.
Iterating over installed plugins: [ 'org.apache.cordova.device' ]
Writing out cordova_plugins.js...
Wrote out iOS Bundle Identifier to "<IDENTIFIER>"
Wrote out iOS Bundle Version to "0.0.1"
Copying icon from .../<APPNAME>/img/apple-icon-60x60.png to .../<APPNAME>/platforms/ios/<APPNAME>/Resources/icons/icon-60.png
cp: no such file or directory: .../<APPNAME>/img/apple-icon-60x60.png
Copying icon from .../<APPNAME>/img/apple-icon-120x120.png to .../<APPNAME>/platforms/ios/<APPNAME>/Resources/icons/icon-60@2x.png
cp: no such file or directory: .../<APPNAME>/img/apple-icon-120x120.png
Copying icon from .../<APPNAME>/img/apple-icon-180x180.png to .../<APPNAME>/platforms/ios/<APPNAME>/Resources/icons/icon-60@3x.png
cp: no such file or directory: .../<APPNAME>/img/apple-icon-180x180.png
Copying icon from .../<APPNAME>/img/apple-icon-76x76.png to .../<APPNAME>/platforms/ios/<APPNAME>/Resources/icons/icon-76.png
cp: no such file or directory: .../<APPNAME>/img/apple-icon-76x76.png
Copying icon from .../<APPNAME>/img/apple-icon-152x152.png to .../<APPNAME>/platforms/ios/<APPNAME>/Resources/icons/icon-76@2x.png
cp: no such file or directory: .../<APPNAME>/img/apple-icon-152x152.png
Copying splash from .../<APPNAME>/img/splash-screen-320x480.png to .../<APPNAME>/platforms/ios/<APPNAME>/Resources/splash/Default~iphone.png
cp: no such file or directory: .../<APPNAME>/img/splash-screen-320x480.png
Copying splash from .../<APPNAME>/img/splash-screen-640x960.png to .../<APPNAME>/platforms/ios/<APPNAME>/Resources/splash/Default@2x~iphone.png
cp: no such file or directory: .../<APPNAME>/img/splash-screen-640x960.png
Copying splash from .../<APPNAME>/img/splash-screen-640x1136.png to .../<APPNAME>/platforms/ios/<APPNAME>/Resources/splash/Default-568h@2x~iphone.png
cp: no such file or directory: .../<APPNAME>/img/splash-screen-640x1136.png
Copying splash from .../<APPNAME>/img/splash-screen-750x1334.png to .../<APPNAME>/platforms/ios/<APPNAME>/Resources/splash/Default-667h.png
cp: no such file or directory: .../<APPNAME>/img/splash-screen-750x1334.png
Copying splash from .../<APPNAME>/img/splash-screen-1242x2208.png to .../<APPNAME>/platforms/ios/<APPNAME>/Resources/splash/Default-736h.png
cp: no such file or directory: .../<APPNAME>/img/splash-screen-1242x2208.png
Copying splash from .../<APPNAME>/img/splash-screen-2208x1242.png to .../<APPNAME>/platforms/ios/<APPNAME>/Resources/splash/Default-Landscape-736h.png
cp: no such file or directory: .../<APPNAME>/img/splash-screen-2208x1242.png
Wrote out iOS Product Name and updated XCode project file names from "<APPNAME>" to "<APPNAME>".
************* Processing the main config.xml file (after_prepare)  *****************
App Directory = [.../<APPNAME>]
Will process and update the following config files:
    Config.xml = [.../<APPNAME>/config.xml]
Namespaces:
    prefix/uri ''/'http://www.w3.org/ns/widgets'
    prefix/uri 'intelxdk'/'http://xdk.intel.com/ns/v1'
Name of the app is [<APPNAME>]
Updating full app name to [<APPNAME>]
Processing preference Orientation [portrait]
Processing preference permissions
Updating the versionName
Setting [CFBundleShortVersionString] to 0.0.1
Processing debuggable
Processing config file values
Image height/width = 180/180
Copied image file icon-60@3x
Copying [.../<APPNAME>/www/img/apple-icon-180x180.png] to [.../<APPNAME>/platforms/ios/build/device/<APPNAME>.app/icon-60@3x.png
Image height/width = 120/120
Copied image file icon-60@2x
Image height/width = 60/60
Image height/width = 152/152
Copied image file icon-76@2x
Image height/width = 76/76
updated icon list to [['icon', 'icon@2x', 'icon-60', 'icon-60@2x', 'icon-72', 'icon-72@2x', 'icon-76', 'icon-76@2x', 'icon-60@3x']]
Copying the iPhone 6 Plus Portrait [.../<APPNAME>/www/img/splash-screen-1242x2208.png] (1242w x 2208h) splash screen to .../<APPNAME>/platforms/ios/<APPNAME>/Resources/splash/Default-736h@3x.png.
Copying [.../<APPNAME>/www/img/splash-screen-1242x2208.png] to [.../<APPNAME>/platforms/ios/build/device/<APPNAME>.app/Default-736h@3x.png
Copying the iPad Retina portrait [.../<APPNAME>/www/img/splash-screen-1536x2008.png] (1536w x 2008h) splash screen to .../<APPNAME>/platforms/ios/<APPNAME>/Resources/splash/Default-Portrait@2x~ipad.png.
Copying the iPad portrait [.../<APPNAME>/www/img/splash-screen-768x1004.png] (768w x 1004h) splash screen to .../<APPNAME>/platforms/ios/<APPNAME>/Resources/splash/Default-Portrait~ipad.png.
Copying the iPhone 6 Portrait [.../<APPNAME>/www/img/splash-screen-750x1334.png] (750w x 1334h) splash screen to .../<APPNAME>/platforms/ios/<APPNAME>/Resources/splash/Default-667h@2x.png.
Copying [.../<APPNAME>/www/img/splash-screen-750x1334.png] to [.../<APPNAME>/platforms/ios/build/device/<APPNAME>.app/Default-667h@2x.png
Copying the iPhone 5 [.../<APPNAME>/www/img/splash-screen-640x1136.png] (640w x 1136h) splash screen to .../<APPNAME>/platforms/ios/<APPNAME>/Resources/splash/Default-568h@2x~iphone.png.
Copying the iPhone Retina [.../<APPNAME>/www/img/splash-screen-640x960.png] (640w x 960h) splash screen to .../<APPNAME>/platforms/ios/<APPNAME>/Resources/splash/Default@2x~iphone.png.
Copying the iPhone [.../<APPNAME>/www/img/splash-screen-320x480.png] (320w x 480h) splash screen to .../<APPNAME>/platforms/ios/<APPNAME>/Resources/splash/Default~iphone.png.
Copying the iPhone 6 Landscape [.../<APPNAME>/www/img/splash-screen-1334x750.png] (1334w x 750h) splash screen to .../<APPNAME>/platforms/ios/<APPNAME>/Resources/splash/Default-Landscape-667h@2x.png.
Copying [.../<APPNAME>/www/img/splash-screen-1334x750.png] to [.../<APPNAME>/platforms/ios/build/device/<APPNAME>.app/Default-Landscape-667h@2x.png
Copying the iPhone 6 Plus Landscape [.../<APPNAME>/www/img/splash-screen-2208x1242.png] (2208w x 1242h) splash screen to .../<APPNAME>/platforms/ios/<APPNAME>/Resources/splash/Default-Landscape-736h@3x.png.
Copying [.../<APPNAME>/www/img/splash-screen-2208x1242.png] to [.../<APPNAME>/platforms/ios/build/device/<APPNAME>.app/Default-Landscape-736h@3x.png
Copying the iPad Retina Landscape [.../<APPNAME>/www/img/splash-screen-2048x1496.png] (2048w x 1496h) splash screen to .../<APPNAME>/platforms/ios/<APPNAME>/Resources/splash/Default-Landscape@2x~ipad.png.
Copying the iPad Landscape [.../<APPNAME>/www/img/splash-screen-1024x748.png] (1024w x 748h) splash screen to .../<APPNAME>/platforms/ios/<APPNAME>/Resources/splash/Default-Landscape~ipad.png.
Saving config.xml to [.../<APPNAME>/config.xml]
Saving info.plist to [.../<APPNAME>/platforms/ios/<APPNAME>/<APPNAME>-Info.plist]
************* Completed processing the main config.xml file (after_prepare)  *****************
Running command: .../<APPNAME>/platforms/ios/cordova/build --release --device
Build settings from command line:
    ARCHS = armv7 armv7s arm64
    CONFIGURATION_BUILD_DIR = .../<APPNAME>/platforms/ios/build/device
    SDKROOT = iphoneos8.0
    SHARED_PRECOMPS_DIR = .../<APPNAME>/platforms/ios/build/sharedpch
    VALID_ARCHS = armv7 armv7s arm64
Build settings from configuration file '.../<APPNAME>/platforms/ios/cordova/build-release.xcconfig':
    CODE_SIGN_IDENTITY = iPhone Distribution
    IPHONEOS_DEPLOYMENT_TARGET = 6
    PROVISIONING_PROFILE = c14e6691-2b7c-4b64-859f-f22f4d3ae3ea
=== BUILD TARGET CordovaLib OF PROJECT CordovaLib WITH CONFIGURATION Release ===
Check dependencies
Write auxiliary files
/bin/mkdir -p .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64
write-file .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/Cordova.LinkFileList
/bin/mkdir -p .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-bsgemzknwrcaxlgygwafneapzezr
write-file .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-bsgemzknwrcaxlgygwafneapzezr/CordovaLib_Prefix.pch.pch.hash-criteria
write-file .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap
write-file .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap
write-file .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap
write-file .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap
/bin/mkdir -p .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7
write-file .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/Cordova.LinkFileList
/bin/mkdir -p .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-fdllnpqcxrsgimbtxymaaoroxiqv
write-file .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-fdllnpqcxrsgimbtxymaaoroxiqv/CordovaLib_Prefix.pch.pch.hash-criteria
/bin/mkdir -p .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-eswpgckcgiucfbbkoqwrbswcngan
write-file .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-eswpgckcgiucfbbkoqwrbswcngan/CordovaLib_Prefix.pch.pch.hash-criteria
write-file .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-non-framework-target-headers.hmap
write-file .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova.hmap
/bin/mkdir -p .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s
write-file .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/Cordova.LinkFileList
CpHeader Classes/NSData+Base64.h .../<APPNAME>/platforms/ios/build/device/include/Cordova/NSData+Base64.h
    cd .../<APPNAME>/platforms/ios/CordovaLib
    export PATH="/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin:/Applications/Xcode.app/Contents/Developer/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/local/git/bin:/Developer/android-sdk-macosx/tools:/usr/local/ant/bin"
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../<APPNAME>/platforms/ios/CordovaLib/Classes/NSData+Base64.h .../<APPNAME>/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVInvokedUrlCommand.h .../<APPNAME>/platforms/ios/build/device/include/Cordova/CDVInvokedUrlCommand.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVInvokedUrlCommand.h .../<APPNAME>/platforms/ios/build/device/include/Cordova
CpHeader Classes/NSMutableArray+QueueAdditions.h .../<APPNAME>/platforms/ios/build/device/include/Cordova/NSMutableArray+QueueAdditions.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../<APPNAME>/platforms/ios/CordovaLib/Classes/NSMutableArray+QueueAdditions.h .../<APPNAME>/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVPluginResult.h .../<APPNAME>/platforms/ios/build/device/include/Cordova/CDVPluginResult.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVPluginResult.h .../<APPNAME>/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVDebug.h .../<APPNAME>/platforms/ios/build/device/include/Cordova/CDVDebug.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVDebug.h .../<APPNAME>/platforms/ios/build/device/include/Cordova
CpHeader Classes/NSDictionary+Extensions.h .../<APPNAME>/platforms/ios/build/device/include/Cordova/NSDictionary+Extensions.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../<APPNAME>/platforms/ios/CordovaLib/Classes/NSDictionary+Extensions.h .../<APPNAME>/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVPlugin.h .../<APPNAME>/platforms/ios/build/device/include/Cordova/CDVPlugin.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVPlugin.h .../<APPNAME>/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVWhitelist.h .../<APPNAME>/platforms/ios/build/device/include/Cordova/CDVWhitelist.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVWhitelist.h .../<APPNAME>/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVURLProtocol.h .../<APPNAME>/platforms/ios/build/device/include/Cordova/CDVURLProtocol.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVURLProtocol.h .../<APPNAME>/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVViewController.h .../<APPNAME>/platforms/ios/build/device/include/Cordova/CDVViewController.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVViewController.h .../<APPNAME>/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVCommandDelegate.h .../<APPNAME>/platforms/ios/build/device/include/Cordova/CDVCommandDelegate.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVCommandDelegate.h .../<APPNAME>/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDV.h .../<APPNAME>/platforms/ios/build/device/include/Cordova/CDV.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDV.h .../<APPNAME>/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVAvailability.h .../<APPNAME>/platforms/ios/build/device/include/Cordova/CDVAvailability.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVAvailability.h .../<APPNAME>/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVAvailabilityDeprecated.h .../<APPNAME>/platforms/ios/build/device/include/Cordova/CDVAvailabilityDeprecated.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVAvailabilityDeprecated.h .../<APPNAME>/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVLocalStorage.h .../<APPNAME>/platforms/ios/build/device/include/Cordova/CDVLocalStorage.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVLocalStorage.h .../<APPNAME>/platforms/ios/build/device/include/Cordova
CpHeader Classes/UIDevice+Extensions.h .../<APPNAME>/platforms/ios/build/device/include/Cordova/UIDevice+Extensions.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../<APPNAME>/platforms/ios/CordovaLib/Classes/UIDevice+Extensions.h .../<APPNAME>/platforms/ios/build/device/include/Cordova
CpHeader Classes/NSArray+Comparisons.h .../<APPNAME>/platforms/ios/build/device/include/Cordova/NSArray+Comparisons.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../<APPNAME>/platforms/ios/CordovaLib/Classes/NSArray+Comparisons.h .../<APPNAME>/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVCommandQueue.h .../<APPNAME>/platforms/ios/build/device/include/Cordova/CDVCommandQueue.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVCommandQueue.h .../<APPNAME>/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVCommandDelegateImpl.h .../<APPNAME>/platforms/ios/build/device/include/Cordova/CDVCommandDelegateImpl.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVCommandDelegateImpl.h .../<APPNAME>/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVShared.h .../<APPNAME>/platforms/ios/build/device/include/Cordova/CDVShared.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVShared.h .../<APPNAME>/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVScreenOrientationDelegate.h .../<APPNAME>/platforms/ios/build/device/include/Cordova/CDVScreenOrientationDelegate.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVScreenOrientationDelegate.h .../<APPNAME>/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVConfigParser.h .../<APPNAME>/platforms/ios/build/device/include/Cordova/CDVConfigParser.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVConfigParser.h .../<APPNAME>/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVJSON.h .../<APPNAME>/platforms/ios/build/device/include/Cordova/CDVJSON.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVJSON.h .../<APPNAME>/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVWebViewDelegate.h .../<APPNAME>/platforms/ios/build/device/include/Cordova/CDVWebViewDelegate.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVWebViewDelegate.h .../<APPNAME>/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVUserAgentUtil.h .../<APPNAME>/platforms/ios/build/device/include/Cordova/CDVUserAgentUtil.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVUserAgentUtil.h .../<APPNAME>/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVTimer.h .../<APPNAME>/platforms/ios/build/device/include/Cordova/CDVTimer.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVTimer.h .../<APPNAME>/platforms/ios/build/device/include/Cordova
ProcessPCH .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-fdllnpqcxrsgimbtxymaaoroxiqv/CordovaLib_Prefix.pch.pch CordovaLib_Prefix.pch normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    export LANG=en_US.US-ASCII
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c-header -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -MD -MT dependencies -MF .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-fdllnpqcxrsgimbtxymaaoroxiqv/CordovaLib_Prefix.pch.d -c .../<APPNAME>/platforms/ios/CordovaLib/CordovaLib_Prefix.pch -o .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-fdllnpqcxrsgimbtxymaaoroxiqv/CordovaLib_Prefix.pch.pch --serialize-diagnostics .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-fdllnpqcxrsgimbtxymaaoroxiqv/CordovaLib_Prefix.pch.dia
ProcessPCH .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-eswpgckcgiucfbbkoqwrbswcngan/CordovaLib_Prefix.pch.pch CordovaLib_Prefix.pch normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c-header -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -MD -MT dependencies -MF .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-eswpgckcgiucfbbkoqwrbswcngan/CordovaLib_Prefix.pch.d -c .../<APPNAME>/platforms/ios/CordovaLib/CordovaLib_Prefix.pch -o .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-eswpgckcgiucfbbkoqwrbswcngan/CordovaLib_Prefix.pch.pch --serialize-diagnostics .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-eswpgckcgiucfbbkoqwrbswcngan/CordovaLib_Prefix.pch.dia
ProcessPCH .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-bsgemzknwrcaxlgygwafneapzezr/CordovaLib_Prefix.pch.pch CordovaLib_Prefix.pch normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c-header -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -MD -MT dependencies -MF .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-bsgemzknwrcaxlgygwafneapzezr/CordovaLib_Prefix.pch.d -c .../<APPNAME>/platforms/ios/CordovaLib/CordovaLib_Prefix.pch -o .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-bsgemzknwrcaxlgygwafneapzezr/CordovaLib_Prefix.pch.pch --serialize-diagnostics .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-bsgemzknwrcaxlgygwafneapzezr/CordovaLib_Prefix.pch.dia
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVInvokedUrlCommand.o Classes/CDVInvokedUrlCommand.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-fdllnpqcxrsgimbtxymaaoroxiqv/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVInvokedUrlCommand.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVInvokedUrlCommand.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVInvokedUrlCommand.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVInvokedUrlCommand.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSDictionary+Extensions.o Classes/NSDictionary+Extensions.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-fdllnpqcxrsgimbtxymaaoroxiqv/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSDictionary+Extensions.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSDictionary+Extensions.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/NSDictionary+Extensions.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSDictionary+Extensions.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSData+Base64.o Classes/NSData+Base64.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-fdllnpqcxrsgimbtxymaaoroxiqv/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSData+Base64.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSData+Base64.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/NSData+Base64.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSData+Base64.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPluginResult.o Classes/CDVPluginResult.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-fdllnpqcxrsgimbtxymaaoroxiqv/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPluginResult.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPluginResult.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVPluginResult.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPluginResult.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWhitelist.o Classes/CDVWhitelist.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-fdllnpqcxrsgimbtxymaaoroxiqv/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWhitelist.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWhitelist.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVWhitelist.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWhitelist.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin.o Classes/CDVPlugin.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-fdllnpqcxrsgimbtxymaaoroxiqv/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVPlugin.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSMutableArray+QueueAdditions.o Classes/NSMutableArray+QueueAdditions.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-fdllnpqcxrsgimbtxymaaoroxiqv/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSMutableArray+QueueAdditions.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSMutableArray+QueueAdditions.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/NSMutableArray+QueueAdditions.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSMutableArray+QueueAdditions.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVURLProtocol.o Classes/CDVURLProtocol.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-fdllnpqcxrsgimbtxymaaoroxiqv/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVURLProtocol.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVURLProtocol.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVURLProtocol.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVURLProtocol.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVViewController.o Classes/CDVViewController.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-fdllnpqcxrsgimbtxymaaoroxiqv/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVViewController.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVViewController.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVViewController.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVViewController.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVLocalStorage.o Classes/CDVLocalStorage.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-fdllnpqcxrsgimbtxymaaoroxiqv/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVLocalStorage.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVLocalStorage.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVLocalStorage.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVLocalStorage.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSArray+Comparisons.o Classes/NSArray+Comparisons.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-fdllnpqcxrsgimbtxymaaoroxiqv/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSArray+Comparisons.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSArray+Comparisons.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/NSArray+Comparisons.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSArray+Comparisons.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/UIDevice+Extensions.o Classes/UIDevice+Extensions.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-fdllnpqcxrsgimbtxymaaoroxiqv/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/UIDevice+Extensions.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/UIDevice+Extensions.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/UIDevice+Extensions.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/UIDevice+Extensions.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandQueue.o Classes/CDVCommandQueue.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-fdllnpqcxrsgimbtxymaaoroxiqv/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandQueue.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandQueue.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVCommandQueue.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandQueue.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandDelegateImpl.o Classes/CDVCommandDelegateImpl.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-fdllnpqcxrsgimbtxymaaoroxiqv/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandDelegateImpl.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandDelegateImpl.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVCommandDelegateImpl.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandDelegateImpl.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVConfigParser.o Classes/CDVConfigParser.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    cd .../<APPNAME>/platforms/ios/CordovaLib
    export PATH="/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin:/Applications/Xcode.app/Contents/Developer/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/local/git/bin:/Developer/android-sdk-macosx/tools:/usr/local/ant/bin"
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-fdllnpqcxrsgimbtxymaaoroxiqv/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVConfigParser.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVConfigParser.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVConfigParser.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVConfigParser.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVJSON.o Classes/CDVJSON.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-fdllnpqcxrsgimbtxymaaoroxiqv/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVJSON.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVJSON.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVJSON.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVJSON.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUserAgentUtil.o Classes/CDVUserAgentUtil.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-fdllnpqcxrsgimbtxymaaoroxiqv/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUserAgentUtil.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUserAgentUtil.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVUserAgentUtil.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUserAgentUtil.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWebViewDelegate.o Classes/CDVWebViewDelegate.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-fdllnpqcxrsgimbtxymaaoroxiqv/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWebViewDelegate.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWebViewDelegate.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVWebViewDelegate.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWebViewDelegate.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVTimer.o Classes/CDVTimer.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    export LANG=en_US.US-ASCII
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-fdllnpqcxrsgimbtxymaaoroxiqv/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVTimer.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVTimer.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVTimer.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVTimer.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSDictionary+Extensions.o Classes/NSDictionary+Extensions.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-eswpgckcgiucfbbkoqwrbswcngan/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSDictionary+Extensions.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSDictionary+Extensions.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/NSDictionary+Extensions.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSDictionary+Extensions.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVInvokedUrlCommand.o Classes/CDVInvokedUrlCommand.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-eswpgckcgiucfbbkoqwrbswcngan/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVInvokedUrlCommand.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVInvokedUrlCommand.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVInvokedUrlCommand.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVInvokedUrlCommand.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSData+Base64.o Classes/NSData+Base64.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-eswpgckcgiucfbbkoqwrbswcngan/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSData+Base64.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSData+Base64.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/NSData+Base64.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSData+Base64.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVPluginResult.o Classes/CDVPluginResult.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-eswpgckcgiucfbbkoqwrbswcngan/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVPluginResult.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVPluginResult.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVPluginResult.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVPluginResult.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVPlugin.o Classes/CDVPlugin.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-eswpgckcgiucfbbkoqwrbswcngan/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVPlugin.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVPlugin.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVPlugin.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVPlugin.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSMutableArray+QueueAdditions.o Classes/NSMutableArray+QueueAdditions.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-eswpgckcgiucfbbkoqwrbswcngan/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSMutableArray+QueueAdditions.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSMutableArray+QueueAdditions.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/NSMutableArray+QueueAdditions.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSMutableArray+QueueAdditions.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVWhitelist.o Classes/CDVWhitelist.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-eswpgckcgiucfbbkoqwrbswcngan/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVWhitelist.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVWhitelist.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVWhitelist.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVWhitelist.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVURLProtocol.o Classes/CDVURLProtocol.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-eswpgckcgiucfbbkoqwrbswcngan/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVURLProtocol.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVURLProtocol.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVURLProtocol.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVURLProtocol.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVViewController.o Classes/CDVViewController.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-eswpgckcgiucfbbkoqwrbswcngan/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVViewController.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVViewController.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVViewController.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVViewController.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVLocalStorage.o Classes/CDVLocalStorage.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-eswpgckcgiucfbbkoqwrbswcngan/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVLocalStorage.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVLocalStorage.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVLocalStorage.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVLocalStorage.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/UIDevice+Extensions.o Classes/UIDevice+Extensions.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-eswpgckcgiucfbbkoqwrbswcngan/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/UIDevice+Extensions.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/UIDevice+Extensions.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/UIDevice+Extensions.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/UIDevice+Extensions.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSArray+Comparisons.o Classes/NSArray+Comparisons.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-eswpgckcgiucfbbkoqwrbswcngan/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSArray+Comparisons.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSArray+Comparisons.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/NSArray+Comparisons.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSArray+Comparisons.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVCommandQueue.o Classes/CDVCommandQueue.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-eswpgckcgiucfbbkoqwrbswcngan/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVCommandQueue.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVCommandQueue.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVCommandQueue.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVCommandQueue.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVCommandDelegateImpl.o Classes/CDVCommandDelegateImpl.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-eswpgckcgiucfbbkoqwrbswcngan/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVCommandDelegateImpl.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVCommandDelegateImpl.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVCommandDelegateImpl.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVCommandDelegateImpl.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVConfigParser.o Classes/CDVConfigParser.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-eswpgckcgiucfbbkoqwrbswcngan/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVConfigParser.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVConfigParser.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVConfigParser.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVConfigParser.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVJSON.o Classes/CDVJSON.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-eswpgckcgiucfbbkoqwrbswcngan/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVJSON.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVJSON.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVJSON.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVJSON.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVUserAgentUtil.o Classes/CDVUserAgentUtil.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    cd .../<APPNAME>/platforms/ios/CordovaLib
    export PATH="/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin:/Applications/Xcode.app/Contents/Developer/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/local/git/bin:/Developer/android-sdk-macosx/tools:/usr/local/ant/bin"
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-eswpgckcgiucfbbkoqwrbswcngan/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVUserAgentUtil.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVUserAgentUtil.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVUserAgentUtil.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVUserAgentUtil.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVWebViewDelegate.o Classes/CDVWebViewDelegate.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-eswpgckcgiucfbbkoqwrbswcngan/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVWebViewDelegate.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVWebViewDelegate.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVWebViewDelegate.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVWebViewDelegate.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVTimer.o Classes/CDVTimer.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-eswpgckcgiucfbbkoqwrbswcngan/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVTimer.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVTimer.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVTimer.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVTimer.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSDictionary+Extensions.o Classes/NSDictionary+Extensions.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-bsgemzknwrcaxlgygwafneapzezr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSDictionary+Extensions.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSDictionary+Extensions.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/NSDictionary+Extensions.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSDictionary+Extensions.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVInvokedUrlCommand.o Classes/CDVInvokedUrlCommand.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    export LANG=en_US.US-ASCII
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-bsgemzknwrcaxlgygwafneapzezr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVInvokedUrlCommand.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVInvokedUrlCommand.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVInvokedUrlCommand.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVInvokedUrlCommand.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSData+Base64.o Classes/NSData+Base64.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-bsgemzknwrcaxlgygwafneapzezr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSData+Base64.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSData+Base64.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/NSData+Base64.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSData+Base64.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPluginResult.o Classes/CDVPluginResult.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-bsgemzknwrcaxlgygwafneapzezr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPluginResult.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPluginResult.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVPluginResult.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPluginResult.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSMutableArray+QueueAdditions.o Classes/NSMutableArray+QueueAdditions.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-bsgemzknwrcaxlgygwafneapzezr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSMutableArray+QueueAdditions.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSMutableArray+QueueAdditions.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/NSMutableArray+QueueAdditions.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSMutableArray+QueueAdditions.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin.o Classes/CDVPlugin.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-bsgemzknwrcaxlgygwafneapzezr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVPlugin.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWhitelist.o Classes/CDVWhitelist.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-bsgemzknwrcaxlgygwafneapzezr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWhitelist.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWhitelist.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVWhitelist.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWhitelist.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVURLProtocol.o Classes/CDVURLProtocol.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-bsgemzknwrcaxlgygwafneapzezr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVURLProtocol.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVURLProtocol.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVURLProtocol.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVURLProtocol.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVViewController.o Classes/CDVViewController.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-bsgemzknwrcaxlgygwafneapzezr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVViewController.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVViewController.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVViewController.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVViewController.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVLocalStorage.o Classes/CDVLocalStorage.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-bsgemzknwrcaxlgygwafneapzezr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVLocalStorage.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVLocalStorage.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVLocalStorage.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVLocalStorage.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/UIDevice+Extensions.o Classes/UIDevice+Extensions.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-bsgemzknwrcaxlgygwafneapzezr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/UIDevice+Extensions.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/UIDevice+Extensions.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/UIDevice+Extensions.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/UIDevice+Extensions.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSArray+Comparisons.o Classes/NSArray+Comparisons.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-bsgemzknwrcaxlgygwafneapzezr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSArray+Comparisons.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSArray+Comparisons.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/NSArray+Comparisons.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSArray+Comparisons.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandQueue.o Classes/CDVCommandQueue.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-bsgemzknwrcaxlgygwafneapzezr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandQueue.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandQueue.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVCommandQueue.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandQueue.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandDelegateImpl.o Classes/CDVCommandDelegateImpl.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-bsgemzknwrcaxlgygwafneapzezr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandDelegateImpl.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandDelegateImpl.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVCommandDelegateImpl.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandDelegateImpl.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVConfigParser.o Classes/CDVConfigParser.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-bsgemzknwrcaxlgygwafneapzezr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVConfigParser.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVConfigParser.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVConfigParser.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVConfigParser.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUserAgentUtil.o Classes/CDVUserAgentUtil.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-bsgemzknwrcaxlgygwafneapzezr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUserAgentUtil.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUserAgentUtil.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVUserAgentUtil.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUserAgentUtil.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVJSON.o Classes/CDVJSON.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-bsgemzknwrcaxlgygwafneapzezr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVJSON.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVJSON.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVJSON.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVJSON.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWebViewDelegate.o Classes/CDVWebViewDelegate.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-bsgemzknwrcaxlgygwafneapzezr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWebViewDelegate.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWebViewDelegate.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVWebViewDelegate.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWebViewDelegate.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVTimer.o Classes/CDVTimer.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    cd .../<APPNAME>/platforms/ios/CordovaLib
    export PATH="/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin:/Applications/Xcode.app/Contents/Developer/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/local/git/bin:/Developer/android-sdk-macosx/tools:/usr/local/ant/bin"
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=6 -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../<APPNAME>/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../<APPNAME>/platforms/ios/build/device -include .../<APPNAME>/platforms/ios/build/sharedpch/CordovaLib_Prefix-bsgemzknwrcaxlgygwafneapzezr/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVTimer.d --serialize-diagnostics .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVTimer.dia -c .../<APPNAME>/platforms/ios/CordovaLib/Classes/CDVTimer.m -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVTimer.o
Libtool build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/libCordova.a normal armv7s
    export IPHONEOS_DEPLOYMENT_TARGET=6
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/libtool -static -arch_only armv7s -syslibroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -L.../<APPNAME>/platforms/ios/build/device -filelist .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/Cordova.LinkFileList -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/libCordova.a
Libtool build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/libCordova.a normal arm64
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/libtool -static -arch_only arm64 -syslibroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -L.../<APPNAME>/platforms/ios/build/device -filelist .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/Cordova.LinkFileList -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/libCordova.a
Libtool build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/libCordova.a normal armv7
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/libtool -static -arch_only armv7 -syslibroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -L.../<APPNAME>/platforms/ios/build/device -filelist .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/Cordova.LinkFileList -o .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/libCordova.a
CreateUniversalBinary .../<APPNAME>/platforms/ios/build/device/libCordova.a normal armv7\ armv7s\ arm64
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/libtool -static .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/libCordova.a .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/libCordova.a .../<APPNAME>/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/libCordova.a -o .../<APPNAME>/platforms/ios/build/device/libCordova.a
=== BUILD TARGET <APPNAME> OF PROJECT <APPNAME> WITH CONFIGURATION Release ===
Check dependencies
Code Sign error: Provisioning profile does not match bundle identifier: The provisioning profile specified in your build settings (“<APPNAME>”) has an AppID of “<MAIL>.<APPNAME>” which does not match your bundle identifier “<IDENTIFIER>”.
CodeSign error: code signing is required for product type 'Application' in SDK 'iOS 8.0'
** BUILD FAILED **
The following build commands failed:
	Check dependencies
(1 failure)
Command finished with error code 65: .../<APPNAME>/platforms/ios/cordova/build --release,--device
Error: .../<APPNAME>/platforms/ios/cordova/build: Command failed with exit code 65
    at ChildProcess.whenDone (/Developer/cordova/4.1.2/node_modules/cordova/node_modules/cordova-lib/src/cordova/superspawn.js:135:23)
    at ChildProcess.EventEmitter.emit (events.js:98:17)
    at maybeClose (child_process.js:753:16)
    at Process.ChildProcess._handle.onexit (child_process.js:820:5)
Thank you!
John_H_Intel2
員工
10,540 檢視
641 Check dependencies
642 Code Sign error: Provisioning profile does not match bundle identifier: The provisioning profile specified in your build settings (“<APPNAME>”) has an AppID of “<MAIL>.<APPNAME>” which does not match your bundle identifier “<IDENTIFIER>”.
643 CodeSign error: code signing is required for product type 'Application' in SDK 'iOS 8.0'
644
645 ** BUILD FAILED **
Your provisioning profile does not match your cert.
Raiden_D_
初學者
10,540 檢視
I don't know what is the problem. I did the steps below:
1,  Projects -> Build Settings -> iOs -> Provisioning profile -> select ad hoc
2,  Build -> Cordova hybrid mobile app platforms -> iOs -> Overwiew -> iOS CERTIFICATE -> edit -> download csr file
3,  developer.apple.com -> member center -> dev centers, iOs -> Certificates, Identifiers & Profiles -> Certificates ->
        3.1,  Certificates -> all -> + button -> Production, App Store and Ad Hoc -> select csr file -> generate -> download
        3.2,  Identifiers -> App Ids -> + button -> Name: paste app name -> Explicit App ID, Bundle ID: paste app id -> continue -> submit -> done
        3.3,  Provisioning Profiles -> all -> + button -> Distribution, Ad Hoc -> continue -> select app id -> continue -> Select certificate -> continue -> Select device -> continue -> profil name: paste app name -> generate -> download file
4,  Projects -> Build Settings -> iOs -> Ad hoc provishing file -> select downloaded file
5,  Build -> go to next step -> build app now -> waiting -> build error
Thanks!
John_H_Intel2
員工
10,540 檢視
You have an appID of xdk.intel.blank.template in the Project settings tab. Your appID you setup with apple is com.raidendonogmail.com.standarddemo, hence they dont match.
Raiden_D_
初學者
10,540 檢視
Thanks, but not work :(
John_H_Intel2
員工
10,540 檢視
Are you uploading your project after you have these values set? If not, the cloud is not getting updated.
Raiden_D_
初學者
10,540 檢視
I updated the project at the cloud, is it ok, or I enclosed in extracted file?
John_H_Intel2
員工
10,540 檢視
I am going to send you a private message.
Raiden_D_
初學者
10,540 檢視
Thank you very much for help, John!
Raiden_d_1
初學者
10,540 檢視
Hi!
I have the same problem like last year.I did everything as needed, but I got an error everytime during the building process.
The only change is that we have a different apple developer account, and maybe the account settings need some configuration. Im not sure about that. I registered the device, made the certificates, generated the application id and i have a provisioning profile too. Anybody have an idea what the problem should be?
The application Ids what i used are:
  • com.livestudio.plazmamenedzser
  • com.livestudio.eu.plazmamenedzser
  • com.raidendonogmail.com.plazmamenedzser
Sincerely Robert!
Anusha_M_Intel1
10,540 檢視
It looks like your certificate and provisioning profile does not match. Can you regenerate it and try?
Amrita_C_Intel
10,540 檢視
Hello Raiden,
It could be possible that your certificate is expired. After a year it gets expired and you are required to renew it from your apple developer account. Can you check it generally says expired or not in your apple developer account. If it is expired you need to repeat the process of generating certificate and provisioning profile as mentioned in this document.
https://software.intel.com/en-us/xdk/docs/building-cordova-ios-apps-intel-xdk
Raiden_d_1
初學者
10,540 檢視
Hi!
The certificate should not be expired, because i created it in the past few days. I tried it more times. I regenerated again and maybe  it's giving me another error code now. I attached the log. Maybe is it still some problem about the profile?
Raiden_d_1
初學者
10,540 檢視
Anybody have an idea what the problem should be? This is very important project! :-/ Thank you!
John_H_Intel2
員工
10,540 檢視
If you are sure that your certificate and provisioning profile are correct, give this a try.
https://software.intel.com/en-us/xdk/blog/remove-xdk-local-data
Raiden_d_1
初學者
10,540 檢視
It was the problem! It's work! Thank you!
Raiden_d_1
初學者
10,540 檢視
Hi!
I updated xdk to version 3088, and I created the developer certificates but the ios build crushes and returns an error. What is the problem?
Build log: CLICK
Thank you!
Raiden_d_1
初學者
10,540 檢視
Sorry for bad link, this is the valid log
Anusha_M_Intel1
10,307 檢視
@Raiden, make sure you are using a distribution cert instead of a development one.
回覆
