Software Archive
Read-only legacy content
17060 Discussions
Cordova iOS build failed
Raiden_D_
Hi!
What is the problem? Thanks!
The following build commands failed:
	Check dependencies
(1 failure)
Command finished with error code 65: .../<APPNAME>/platforms/ios/cordova/build --release,--device
Error: .../<APPNAME>/platforms/ios/cordova/build: Command failed with exit code 65
    at ChildProcess.whenDone (/Developer/cordova/4.1.2/node_modules/cordova/node_modules/cordova-lib/src/cordova/superspawn.js:135:23)
    at ChildProcess.EventEmitter.emit (events.js:98:17)
    at maybeClose (child_process.js:753:16)
    at Process.ChildProcess._handle.onexit (child_process.js:820:5)
Raiden_d_1
I recreated the ios developer certificate in the XDK, I filled out the form, gave all the required data (name, organization, country, etc) I regenerated the certificate from the new file I was given, I downloaded the distribution certificate and finished the developer certificatet in xdk, still it's not able to export the project for ios. Log is attached. Thanks in advance!
P.s.
Why can't I create a new topic in this Intel® XDK forum? I tried 3 times still it's not been added any of the forums.
My topic: https://software.intel.com/en-us/node/623667 <-- AJAX calls in Debug module (v3088)
Raiden_d_1
Could someone help me please? It would be important! Thanks!
Raiden_d_1
Hi!
I dont't know why but for some reason it created the build. The bottom line is that it's working now.
