Software Archive
Read-only legacy content
17060 Discussions
Crash XDK on StartUP
Andrea_V_1
My XDK crash on StartUP, I have tried to reinstall the application sometimes bu i not have solved the problem. This is the LOG, tks: xdk:client:[2016-01-27T08:14:20.067Z]: (1453882460068): memlim: 767557632 xdk:client:[2016-01-27T08:14:20.071Z]: (1453882460071): Setting NW crash dump to: C:\Users\cre6027\AppData\Local\XDK xdk:client:[2016-01-27T08:14:20.314Z]: (1453882460314): Intel XDK: 2893 xdk:client:[2016-01-27T08:14:20.314Z]: (1453882460314): Platform: win32-ia32 (6.1.7601) xdk:client:[2016-01-27T08:14:20.314Z]: (1453882460314): System Info: CPU: 4 X Intel(R) Core(TM) i5-4590 CPU @ 3.30GHz Physical Memory: 8497160192 xdk:client:[2016-01-27T08:14:20.314Z]: (1453882460314): NW: 0.11.7-rc9 xdk:client:[2016-01-27T08:14:20.356Z]: (1453882460356): Created new theme: base xdk:client:[2016-01-27T08:14:20.356Z]: (1453882460356): Registered new theme: base xdk:client:[2016-01-27T08:14:20.357Z]: (1453882460358): Current theme is now: base xdk:client:[2016-01-27T08:14:20.358Z]: (1453882460358): Loading theme from: ../../public/themes/xdk.json xdk:client:[2016-01-27T08:14:20.358Z]: (1453882460358): Failed to load theme: xdk { [Error: Cannot find module '../../public/themes/xdk.json'] code: 'MODULE_NOT_FOUND' } xdk:client:[2016-01-27T08:14:20.436Z]: (1453882460436): Starting client process initialization xdk:client:[2016-01-27T08:14:20.535Z]: (1453882460535): File xdk-version.txt to clear NW cache not found. xdk:client:[2016-01-27T08:14:20.546Z]: (1453882460546): File xdk-version.txt generated sucessfully. xdk:server:[2016-01-27T08:14:20.925Z]: (1453882460925): memlim: 767557632 xdk:server:[2016-01-27T08:14:20.929Z]: (1453882460929): Setting NW crash dump to: C:\Users\cre6027\AppData\Local\XDK xdk:server:[2016-01-27T08:14:21.098Z]: (1453882461098): Starting server process initialization xdk:server:[2016-01-27T08:14:21.244Z]: (1453882461244): Http server started on the standard port 58889 xdk:server:[2016-01-27T08:14:22.170Z]: (1453882462170): NW Cache is up-to-date. xdk:server:[2016-01-27T08:14:22.250Z]: (1453882462250): Component "core:assert" starting import xdk:server:[2016-01-27T08:14:22.250Z]: (1453882462250): Component "core:assert" finished initialization xdk:server:[2016-01-27T08:14:22.250Z]: (1453882462250): Component "core:component-error" starting import xdk:server:[2016-01-27T08:14:22.250Z]: (1453882462250): Component "core:component-error" finished initialization xdk:server:[2016-01-27T08:14:22.250Z]: (1453882462250): Component "core:command-line-options" starting import xdk:server:[2016-01-27T08:14:22.250Z]: (1453882462250): Component "core:command-line-options" finished initialization xdk:server:[2016-01-27T08:14:22.250Z]: (1453882462250): Component "core:service-error" starting import xdk:server:[2016-01-27T08:14:22.251Z]: (1453882462251): Component "core:service-error" finished initialization xdk:server:[2016-01-27T08:14:22.251Z]: (1453882462251): Component "core:buffer" starting import xdk:server:[2016-01-27T08:14:22.251Z]: (1453882462251): Component "core:buffer" finished initialization xdk:server:[2016-01-27T08:14:22.251Z]: (1453882462251): Component "core:signaler" starting import xdk:server:[2016-01-27T08:14:22.252Z]: (1453882462253): Component "core:signaler" finished initialization xdk:server:[2016-01-27T08:14:22.253Z]: (1453882462253): Component "core:signaler-group" starting import xdk:server:[2016-01-27T08:14:22.254Z]: (1453882462254): Component "core:signaler-group" finished initialization xdk:server:[2016-01-27T08:14:22.254Z]: (1453882462254): Component "core:logger" starting import xdk:server:[2016-01-27T08:14:22.255Z]: (1453882462255): Component "core:logger" finished initialization xdk:server:[2016-01-27T08:14:22.255Z]: (1453882462255): Component "core:http-request" starting import xdk:server:[2016-01-27T08:14:22.255Z]: (1453882462255): Component "core:http-request" finished initialization xdk:server:[2016-01-27T08:14:22.255Z]: (1453882462255): Component "core:database" starting import xdk:server:[2016-01-27T08:14:22.256Z]: (1453882462256): Component "core:database" finished initialization xdk:server:[2016-01-27T08:14:22.256Z]: (1453882462256): Component "core:version" starting import xdk:server:[2016-01-27T08:14:22.256Z]: (1453882462256): Component "core:version" finished initialization xdk:server:[2016-01-27T08:14:22.256Z]: (1453882462256): Component "core:userfs-name-converter" starting import xdk:server:[2016-01-27T08:14:22.256Z]: (1453882462256): Component "core:userfs-name-converter" finished initialization xdk:server:[2016-01-27T08:14:22.256Z]: (1453882462256): Component "core:crash-handler" starting import xdk:server:[2016-01-27T08:14:22.257Z]: (1453882462257): Component "core:crash-handler" finished initialization xdk:server:[2016-01-27T08:14:22.257Z]: (1453882462257): Component "core:i18n-support" starting import xdk:server:[2016-01-27T08:14:22.257Z]: (1453882462257): Component "core:i18n-support" finished initialization xdk:server:[2016-01-27T08:14:22.257Z]: (1453882462257): Component "core:theme" starting import xdk:server:[2016-01-27T08:14:22.295Z]: (1453882462295): Component "core:theme" finished initialization xdk:server:[2016-01-27T08:14:22.296Z]: (1453882462296): Component "server:userfs" starting import xdk:server:[2016-01-27T08:14:22.301Z]: (1453882462301): Component "server:userfs" calling init() xdk:server:[2016-01-27T08:14:22.325Z]: (1453882462325): Component "server:userfs" finished initialization xdk:server:[2016-01-27T08:14:22.325Z]: (1453882462325): Component "server:user-profile" starting import xdk:server:[2016-01-27T08:14:22.327Z]: (1453882462327): Component "server:user-profile" calling init() xdk:server:[2016-01-27T08:14:22.327Z]: (1453882462327): Component "server:user-profile" finished initialization xdk:server:[2016-01-27T08:14:22.327Z]: (1453882462327): Component "server:ui-builder" starting import xdk:server:[2016-01-27T08:14:22.368Z]: (1453882462368): Component "server:ui-builder" calling init() xdk:server:[2016-01-27T08:14:22.370Z]: (1453882462370): Component "server:ui-builder" finished initialization xdk:server:[2016-01-27T08:14:22.370Z]: (1453882462370): Component "server:emulator-notification" starting import xdk:server:[2016-01-27T08:14:22.372Z]: (1453882462372): Component "server:emulator-notification" calling init() xdk:server:[2016-01-27T08:14:22.373Z]: (1453882462373): Component "server:emulator-notification" finished initialization xdk:server:[2016-01-27T08:14:22.373Z]: (1453882462373): Component "server:emulator-webserver" starting import xdk:server:[2016-01-27T08:14:22.374Z]: (1453882462374): Component "server:emulator-webserver" calling init() xdk:server:[2016-01-27T08:14:22.374Z]: (1453882462374): Component "server:emulator-webserver" finished initialization xdk:server:[2016-01-27T08:14:22.374Z]: (1453882462374): Component "server:new-project-creator" starting import xdk:server:[2016-01-27T08:14:22.381Z]: (1453882462381): Component "server:new-project-creator" calling init() xdk:server:[2016-01-27T08:14:22.382Z]: (1453882462382): Component "server:new-project-creator" finished initialization xdk:server:[2016-01-27T08:14:22.382Z]: (1453882462382): Component "server:zip-util" starting import xdk:server:[2016-01-27T08:14:22.384Z]: (1453882462384): Component "server:zip-util" calling init() xdk:server:[2016-01-27T08:14:22.384Z]: (1453882462384): Component "server:zip-util" finished initialization xdk:server:[2016-01-27T08:14:22.384Z]: (1453882462384): Component "server:uuid-server" starting import xdk:server:[2016-01-27T08:14:22.387Z]: (1453882462387): Component "server:uuid-server" calling init() xdk:server:[2016-01-27T08:14:22.387Z]: (1453882462387): Component "server:uuid-server" finished initialization xdk:server:[2016-01-27T08:14:22.387Z]: (1453882462387): Component "server:app-starter" starting import xdk:server:[2016-01-27T08:14:22.392Z]: (1453882462392): Component "server:app-starter" calling init() xdk:server:[2016-01-27T08:14:22.394Z]: (1453882462394): Component "server:app-starter" finished initialization xdk:server:[2016-01-27T08:14:22.394Z]: (1453882462394): Component "server:force-download" starting import xdk:server:[2016-01-27T08:14:22.396Z]: (1453882462396): Component "server:force-download" calling init() xdk:server:[2016-01-27T08:14:22.396Z]: (1453882462396): Component "server:force-download" finished initialization xdk:server:[2016-01-27T08:14:22.396Z]: (1453882462396): Component "server:updater" starting import xdk:server:[2016-01-27T08:14:22.400Z]: (1453882462400): Component "server:updater" calling init() server:updater:[2016-01-27T08:14:22.400Z]: (1453882462400): config.base-auto server:updater:[2016-01-27T08:14:22.400Z]: (1453882462400): url=auto xdk:server:[2016-01-27T08:14:22.401Z]: (1453882462401): Component "server:updater" finished initialization xdk:server:[2016-01-27T08:14:22.401Z]: (1453882462401): Component "server:editor-node" starting import xdk:server:[2016-01-27T08:14:22.423Z]: (1453882462423): Component "server:editor-node" calling init() xdk:server:[2016-01-27T08:14:22.426Z]: (1453882462426): Component "server:editor-node" waiting for delayed initialization xdk:server:[2016-01-27T08:14:22.426Z]: (1453882462426): Component "server:cordova-lib" starting import xdk:server:[2016-01-27T08:14:22.693Z]: (1453882462693): Component "server:cordova-lib" calling init() xdk:server:[2016-01-27T08:14:22.780Z]: (1453882462780): Component "server:cordova-lib" finished initialization xdk:server:[2016-01-27T08:14:22.780Z]: (1453882462780): Component "server:api-explorer" starting import xdk:server:[2016-01-27T08:14:22.787Z]: (1453882462787): Component "server:api-explorer" calling init() xdk:server:[2016-01-27T08:14:22.841Z]: (1453882462841): Component "server:api-explorer" finished initialization xdk:server:[2016-01-27T08:14:22.842Z]: (1453882462842): Component "server:plugin-listener" starting import xdk:server:[2016-01-27T08:14:22.844Z]: (1453882462844): Component "server:plugin-listener" calling init() xdk:server:[2016-01-27T08:14:22.844Z]: (1453882462844): Component "server:plugin-listener" finished initialization xdk:server:[2016-01-27T08:14:22.844Z]: (1453882462844): Component "server:git-runner" starting import xdk:server:[2016-01-27T08:14:22.846Z]: (1453882462846): Component "server:git-runner" calling init() xdk:server:[2016-01-27T08:14:22.846Z]: (1453882462846): Component "server:git-runner" finished initialization server:editor-node:[2016-01-27T08:14:22.884Z]: (1453882462884): Starting Brackets node process C:\Users\cre6027\AppData\Local\Intel\XDK\bin\node.exe C:\Users\cre6027\AppData\Local\Intel\XDK\bin\node-core server:editor-node:[2016-01-27T08:14:23.305Z]: (1453882463305): Brackets node is running on port 61347 xdk:server:[2016-01-27T08:14:23.306Z]: (1453882463306): Component "server:editor-node" finished delayed initialization xdk:server:[2016-01-27T08:14:23.307Z]: (1453882463307): Component "server:ui-builder" calling start() xdk:server:[2016-01-27T08:14:23.310Z]: (1453882463310): Component "server:ui-builder" finished start() xdk:server:[2016-01-27T08:14:23.310Z]: (1453882463310): Component "server:emulator-webserver" calling start() xdk:server:[2016-01-27T08:14:23.310Z]: (1453882463310): Component "server:emulator-webserver" finished start() xdk:server:[2016-01-27T08:14:23.310Z]: (1453882463310): Component "server:editor-node" calling start() xdk:server:[2016-01-27T08:14:23.310Z]: (1453882463310): Component "server:editor-node" finished start() xdk:server:[2016-01-27T08:14:23.311Z]: (1453882463311): Intel XDK is initialized now xdk:server:[2016-01-27T08:14:23.312Z]: (1453882463312): Writing to the server data file xdk:server:[2016-01-27T08:14:23.312Z]: (1453882463312): Wrote server data to "C:\Users\cre6027\AppData\Local\XDK\server-data.txt" xdk:client:[2016-01-27T08:14:23.549Z]: (1453882463549): Successfully read server data file xdk:client:[2016-01-27T08:14:23.707Z]: (1453882463707): Component "core:assert" starting import xdk:client:[2016-01-27T08:14:23.707Z]: (1453882463707): Component "core:assert" finished initialization xdk:client:[2016-01-27T08:14:23.707Z]: (1453882463707): Component "core:component-error" starting import xdk:client:[2016-01-27T08:14:23.707Z]: (1453882463707): Component "core:component-error" finished initialization xdk:client:[2016-01-27T08:14:23.707Z]: (1453882463707): Component "core:command-line-options" starting import xdk:client:[2016-01-27T08:14:23.707Z]: (1453882463707): Component "core:command-line-options" finished initialization xdk:client:[2016-01-27T08:14:23.707Z]: (1453882463707): Component "core:service-error" starting import xdk:client:[2016-01-27T08:14:23.708Z]: (1453882463708): Component "core:service-error" finished initialization xdk:client:[2016-01-27T08:14:23.708Z]: (1453882463708): Component "core:buffer" starting import xdk:client:[2016-01-27T08:14:23.708Z]: (1453882463708): Component "core:buffer" finished initialization xdk:client:[2016-01-27T08:14:23.708Z]: (1453882463708): Component "core:signaler" starting import xdk:client:[2016-01-27T08:14:23.708Z]: (1453882463708): Component "core:signaler" finished initialization xdk:client:[2016-01-27T08:14:23.708Z]: (1453882463708): Component "core:signaler-group" starting import xdk:client:[2016-01-27T08:14:23.710Z]: (1453882463710): Component "core:signaler-group" finished initialization xdk:client:[2016-01-27T08:14:23.710Z]: (1453882463710): Component "core:logger" starting import xdk:client:[2016-01-27T08:14:23.710Z]: (1453882463710): Component "core:logger" finished initialization xdk:client:[2016-01-27T08:14:23.710Z]: (1453882463710): Component "core:http-request" starting import xdk:client:[2016-01-27T08:14:23.711Z]: (1453882463711): Component "core:http-request" finished initialization xdk:client:[2016-01-27T08:14:23.711Z]: (1453882463711): Component "core:version" starting import xdk:client:[2016-01-27T08:14:23.711Z]: (1453882463711): Component "core:version" finished initialization xdk:client:[2016-01-27T08:14:23.711Z]: (1453882463711): Component "core:exit-notifier" starting import xdk:client:[2016-01-27T08:14:23.711Z]: (1453882463711): Component "core:exit-notifier" finished initialization xdk:client:[2016-01-27T08:14:23.711Z]: (1453882463711): Component "core:userfs-name-converter" starting import xdk:client:[2016-01-27T08:14:23.712Z]: (1453882463712): Component "core:userfs-name-converter" finished initialization xdk:client:[2016-01-27T08:14:23.712Z]: (1453882463712): Component "core:crash-handler" starting import xdk:client:[2016-01-27T08:14:23.713Z]: (1453882463713): Component "core:crash-handler" finished initialization xdk:client:[2016-01-27T08:14:23.713Z]: (1453882463713): Component "core:analytics" starting import xdk:client:[2016-01-27T08:14:23.713Z]: (1453882463713): Component "core:analytics" finished initialization xdk:client:[2016-01-27T08:14:23.713Z]: (1453882463713): Component "core:i18n-support" starting import xdk:client:[2016-01-27T08:14:23.713Z]: (1453882463713): Component "core:i18n-support" finished initialization xdk:client:[2016-01-27T08:14:23.713Z]: (1453882463713): Component "core:theme" starting import xdk:client:[2016-01-27T08:14:23.713Z]: (1453882463713): Component "core:theme" finished initialization xdk:client:[2016-01-27T08:14:23.719Z]: (1453882463719): Analytics ID: 059221af-f3aa-450f-8541-a8acc597ddca xdk:client:[2016-01-27T08:14:23.721Z]: (1453882463721): onExit listener 0: at Object.exports.onExit (C:\Users\cre6027\AppData\Local\Intel\XDK\xdk\core-modules\public\exit-notifier.js:17:2339) at setupDefaultAnalytics (C:\Users\cre6027\AppData\Local\Intel\XDK\xdk\core-modules\public\analytics.js:17:1438) at C:\Users\cre6027\AppData\Local\Intel\XDK\xdk\core-modules\public\analytics.js:17:6219 at C:\Users\cre6027\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:1229:26 at _fulfilled (C:\Users\cre6027\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:834:54) at self.promiseDispatch.done (C:\Users\cre6027\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:863:30) at Promise.promise.promiseDispatch (C:\Users\cre6027\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:796:13) at C:\Users\cre6027\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:604:44 at runSingle (C:\Users\cre6027\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:137:13) xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:app" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:help-helper" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:nativefs" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:document-manager" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:project-manager" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:aa-controller" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:projects-renderers" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:projects-renderers-jsapp" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:projects-renderers-webapp" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:projects-renderers-iotapp" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:active-sync" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:apk-installer" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:appcenter-options" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:resource-manager" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:resource-cocos2d" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:resource-cocos2djs" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:resource-phaser" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:resource-pixi" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:resource-easeljs" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:resource-plain" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:resource-render-frame" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:resource-util" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:bower-package-manager" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:services-tab" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:editor" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:live-preview" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:backend-services" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:backend-feeds" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:merged-feed" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:backend-services-ext" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:backend-service-utils" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:app-starter" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:ui-builder-client" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:project-meta" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:contenttype-registry" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:editor-registry" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:platform-registry" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:projecttype-registry" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:library-registry" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:cordova-registry" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:service-method" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:settings-db" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:adb" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:iosdb" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:device" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:device-discovery" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:dialog-box" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:test-local-server" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:quick-tour" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:hot-keys" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:persistance" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:tabs" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:hash-utils" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:file-watcher" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:tool-tip" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:cordova" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:settings-ui" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:external-links" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:external-editors-runner" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:project-list-load" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:upload-manager" starting import xdk:client:[2016-01-27T08:14:23.765Z]: (1453882463765): Component "client:git-manager" starting import xdk:client:[2016-01-27T08:14:23.797Z]: (1453882463797): Component "client:help-helper" finished initialization xdk:client:[2016-01-27T08:14:23.797Z]: (1453882463797): Component "client:nativefs" finished initialization xdk:client:[2016-01-27T08:14:23.806Z]: (1453882463806): Component "client:active-sync" calling init() xdk:client:[2016-01-27T08:14:23.806Z]: (1453882463806): Component "client:active-sync" finished initialization xdk:client:[2016-01-27T08:14:23.807Z]: (1453882463807): Component "client:apk-installer" calling init() xdk:client:[2016-01-27T08:14:23.807Z]: (1453882463807): Component "client:apk-installer" finished initialization xdk:client:[2016-01-27T08:14:23.821Z]: (1453882463821): Component "client:resource-render-frame" calling init() xdk:client:[2016-01-27T08:14:23.821Z]: (1453882463821): Component "client:resource-render-frame" waiting for delayed initialization xdk:client:[2016-01-27T08:14:23.822Z]: (1453882463822): Component "client:resource-util" calling init() xdk:client:[2016-01-27T08:14:23.822Z]: (1453882463822): Component "client:resource-util" finished initialization xdk:client:[2016-01-27T08:14:23.825Z]: (1453882463825): Component "client:resource-render-frame" finished delayed initialization xdk:client:[2016-01-27T08:14:23.835Z]: (1453882463835): Component "client:backend-services" calling init() xdk:client:[2016-01-27T08:14:23.836Z]: (1453882463836): Component "client:backend-services" finished initialization xdk:client:[2016-01-27T08:14:23.837Z]: (1453882463837): Component "client:backend-feeds" calling init() xdk:client:[2016-01-27T08:14:23.837Z]: (1453882463837): Component "client:backend-feeds" finished initialization xdk:client:[2016-01-27T08:14:23.837Z]: (1453882463837): Component "client:merged-feed" finished initialization xdk:client:[2016-01-27T08:14:23.838Z]: (1453882463838): Component "client:backend-services-ext" calling init() xdk:client:[2016-01-27T08:14:23.838Z]: (1453882463838): Component "client:backend-services-ext" finished initialization xdk:client:[2016-01-27T08:14:23.838Z]: (1453882463838): Component "client:backend-service-utils" finished initialization xdk:client:[2016-01-27T08:14:23.841Z]: (1453882463841): Component "client:project-meta" calling init() xdk:client:[2016-01-27T08:14:23.842Z]: (1453882463842): Component "client:project-meta" finished initialization xdk:client:[2016-01-27T08:14:23.846Z]: (1453882463846): Component "client:service-method" finished initialization xdk:client:[2016-01-27T08:14:23.848Z]: (1453882463848): Component "client:settings-db" calling init() xdk:client:[2016-01-27T08:14:23.848Z]: (1453882463848): Component "client:settings-db" waiting for delayed initialization xdk:client:[2016-01-27T08:14:23.849Z]: (1453882463849): Component "client:adb" calling init() xdk:client:[2016-01-27T08:14:23.861Z]: (1453882463861): Component "client:adb" waiting for delayed initialization xdk:client:[2016-01-27T08:14:23.862Z]: (1453882463862): Component "client:iosdb" calling init() xdk:client:[2016-01-27T08:14:23.863Z]: (1453882463863): Component "client:iosdb" finished initialization xdk:client:[2016-01-27T08:14:23.868Z]: (1453882463868): Component "client:persistance" calling init() xdk:client:[2016-01-27T08:14:23.869Z]: (1453882463869): Component "client:persistance" waiting for delayed initialization xdk:client:[2016-01-27T08:14:23.870Z]: (1453882463870): Component "client:file-watcher" calling init() xdk:client:[2016-01-27T08:14:23.871Z]: (1453882463871): Component "client:file-watcher" finished initialization xdk:client:[2016-01-27T08:14:23.874Z]: (1453882463874): Component "client:external-links" finished initialization xdk:client:[2016-01-27T08:14:23.875Z]: (1453882463875): Component "client:external-editors-runner" calling init() xdk:client:[2016-01-27T08:14:23.875Z]: (1453882463875): Component "client:external-editors-runner" finished initialization xdk:client:[2016-01-27T08:14:23.875Z]: (1453882463875): Component "client:project-list-load" calling init() xdk:client:[2016-01-27T08:14:23.875Z]: (1453882463875): Component "client:project-list-load" waiting for delayed initialization xdk:client:[2016-01-27T08:14:23.877Z]: (1453882463877): Component "client:upload-manager" calling init() xdk:client:[2016-01-27T08:14:23.877Z]: (1453882463877): Component "client:upload-manager" finished initialization xdk:client:[2016-01-27T08:14:23.877Z]: (1453882463877): Component "client:git-manager" calling init() client:git-manager:[2016-01-27T08:14:23.877Z]: (1453882463877): git path = C:\Users\cre6027\AppData\Local\Intel\XDK\bin\git\bin\git.exe xdk:client:[2016-01-27T08:14:23.878Z]: (1453882463878): Component "client:git-manager" waiting for delayed initialization xdk:client:[2016-01-27T08:14:23.880Z]: (1453882463880): Component "client:app-starter" finished initialization xdk:client:[2016-01-27T08:14:23.881Z]: (1453882463881): Component "client:hot-keys" calling init() xdk:client:[2016-01-27T08:14:23.882Z]: (1453882463882): Component "client:hot-keys" finished initialization xdk:client:[2016-01-27T08:14:23.883Z]: (1453882463883): Component "client:document-manager" calling init() xdk:client:[2016-01-27T08:14:23.884Z]: (1453882463884): Component "client:document-manager" finished initialization xdk:client:[2016-01-27T08:14:23.894Z]: (1453882463894): Component "client:aa-controller" calling init() xdk:client:[2016-01-27T08:14:23.894Z]: (1453882463894): Component "client:aa-controller" finished initialization xdk:client:[2016-01-27T08:14:23.929Z]: (1453882463929): Component "client:ui-builder-client" calling init() xdk:client:[2016-01-27T08:14:23.929Z]: (1453882463929): Component "client:ui-builder-client" finished initialization xdk:client:[2016-01-27T08:14:23.930Z]: (1453882463930): Component "client:dialog-box" finished initialization xdk:client:[2016-01-27T08:14:23.932Z]: (1453882463932): Component "client:tool-tip" finished initialization xdk:client:[2016-01-27T08:14:23.933Z]: (1453882463933): Component "client:settings-ui" finished initialization xdk:client:[2016-01-27T08:14:23.943Z]: (1453882463943): Component "client:resource-manager" calling init() xdk:client:[2016-01-27T08:14:23.943Z]: (1453882463943): Component "client:resource-manager" waiting for delayed initialization xdk:client:[2016-01-27T08:14:23.950Z]: (1453882463950): Component "client:resource-cocos2djs" calling init() xdk:client:[2016-01-27T08:14:23.950Z]: (1453882463950): Component "client:resource-cocos2djs" finished initialization xdk:client:[2016-01-27T08:14:23.952Z]: (1453882463952): Component "client:resource-phaser" calling init() xdk:client:[2016-01-27T08:14:23.953Z]: (1453882463953): Component "client:resource-phaser" finished initialization xdk:client:[2016-01-27T08:14:23.954Z]: (1453882463954): Component "client:resource-pixi" calling init() xdk:client:[2016-01-27T08:14:23.954Z]: (1453882463954): Component "client:resource-pixi" finished initialization xdk:client:[2016-01-27T08:14:23.955Z]: (1453882463955): Component "client:resource-easeljs" calling init() xdk:client:[2016-01-27T08:14:23.955Z]: (1453882463955): Component "client:resource-easeljs" finished initialization xdk:client:[2016-01-27T08:14:23.956Z]: (1453882463956): Component "client:resource-plain" calling init() xdk:client:[2016-01-27T08:14:23.956Z]: (1453882463956): Component "client:resource-plain" finished initialization xdk:client:[2016-01-27T08:14:23.964Z]: (1453882463964): Component "client:appcenter-options" calling init() xdk:client:[2016-01-27T08:14:23.964Z]: (1453882463964): Component "client:appcenter-options" waiting for delayed initialization xdk:client:[2016-01-27T08:14:23.965Z]: (1453882463965): Component "client:test-local-server" calling init() xdk:client:[2016-01-27T08:14:23.984Z]: (1453882463984): Component "client:test-local-server" finished initialization xdk:client:[2016-01-27T08:14:23.984Z]: (1453882463984): Component "client:tabs" finished initialization xdk:client:[2016-01-27T08:14:23.987Z]: (1453882463987): Component "client:app" calling init() xdk:client:[2016-01-27T08:14:23.995Z]: (1453882463995): Component "client:app" finished initialization xdk:client:[2016-01-27T08:14:23.997Z]: (1453882463997): Component "client:services-tab" calling init() xdk:client:[2016-01-27T08:14:23.997Z]: (1453882463997): Component "client:services-tab" finished initialization xdk:client:[2016-01-27T08:14:23.999Z]: (1453882463999): Component "client:contenttype-registry" calling init() xdk:client:[2016-01-27T08:14:24.000Z]: (1453882464000): Component "client:contenttype-registry" finished initialization xdk:client:[2016-01-27T08:14:24.000Z]: (1453882464000): Component "client:editor-registry" finished initialization xdk:client:[2016-01-27T08:14:24.003Z]: (1453882464003): Component "client:library-registry" calling init() xdk:client:[2016-01-27T08:14:24.003Z]: (1453882464003): Component "client:library-registry" finished initialization xdk:client:[2016-01-27T08:14:24.007Z]: (1453882464007): Component "client:device-discovery" calling init() xdk:client:[2016-01-27T08:14:24.008Z]: (1453882464008): Component "client:device-discovery" waiting for delayed initialization xdk:client:[2016-01-27T08:14:24.008Z]: (1453882464008): Component "client:hash-utils" finished initialization xdk:client:[2016-01-27T08:14:24.030Z]: (1453882464030): Component "client:cordova" calling init() xdk:client:[2016-01-27T08:14:24.031Z]: (1453882464031): Component "client:cordova" waiting for delayed initialization xdk:client:[2016-01-27T08:14:24.038Z]: (1453882464038): Component "client:project-manager" calling init() xdk:client:[2016-01-27T08:14:24.039Z]: (1453882464039): Component "client:project-manager" waiting for delayed initialization xdk:client:[2016-01-27T08:14:24.042Z]: (1453882464042): Component "client:projects-renderers" calling init() xdk:client:[2016-01-27T08:14:24.042Z]: (1453882464042): Component "client:projects-renderers" waiting for delayed initialization xdk:client:[2016-01-27T08:14:24.043Z]: (1453882464043): Component "client:projects-renderers-iotapp" calling init() xdk:client:[2016-01-27T08:14:24.043Z]: (1453882464043): Component "client:projects-renderers-iotapp" finished initialization xdk:client:[2016-01-27T08:14:24.058Z]: (1453882464058): Component "client:resource-cocos2d" calling init() xdk:client:[2016-01-27T08:14:24.058Z]: (1453882464058): Component "client:resource-cocos2d" waiting for delayed initialization xdk:client:[2016-01-27T08:14:24.059Z]: (1453882464059): Component "client:navbar" starting import xdk:client:[2016-01-27T08:14:24.059Z]: (1453882464059): Component "client:tweets" starting import xdk:client:[2016-01-27T08:14:24.059Z]: (1453882464059): Component "client:projects-tab" starting import xdk:client:[2016-01-27T08:14:24.059Z]: (1453882464059): Component "client:test-tab" starting import xdk:client:[2016-01-27T08:14:24.059Z]: (1453882464059): Component "client:profilingTab" starting import xdk:client:[2016-01-27T08:14:24.059Z]: (1453882464059): Component "client:emulator" starting import xdk:client:[2016-01-27T08:14:24.059Z]: (1453882464059): Component "client:remote-tab" starting import xdk:client:[2016-01-27T08:14:24.059Z]: (1453882464059): Component "client:build-tab" starting import xdk:client:[2016-01-27T08:14:24.059Z]: (1453882464059): Component "client:bower-client" starting import xdk:client:[2016-01-27T08:14:24.059Z]: (1453882464059): Component "client:editor-tab" starting import xdk:client:[2016-01-27T08:14:24.059Z]: (1453882464059): Component "client:account" starting import xdk:client:[2016-01-27T08:14:24.059Z]: (1453882464059): Component "client:project-selector" starting import xdk:client:[2016-01-27T08:14:24.063Z]: (1453882464063): Component "client:resource-cocos2d" finished delayed initialization xdk:client:[2016-01-27T08:14:24.063Z]: (1453882464063): Component "client:settings-db" finished delayed initialization xdk:client:[2016-01-27T08:14:24.074Z]: (1453882464074): Component "client:cordova-registry" calling init() xdk:client:[2016-01-27T08:14:24.074Z]: (1453882464074): Component "client:cordova-registry" waiting for delayed initialization xdk:client:[2016-01-27T08:14:24.099Z]: (1453882464099): Component "client:quick-tour" calling init() xdk:client:[2016-01-27T08:14:24.099Z]: (1453882464099): Component "client:quick-tour" finished initialization xdk:client:[2016-01-27T08:14:24.106Z]: (1453882464106): Component "client:platform-registry" calling init() xdk:client:[2016-01-27T08:14:24.107Z]: (1453882464107): Component "client:platform-registry" finished initialization xdk:client:[2016-01-27T08:14:24.108Z]: (1453882464108): Component "client:projecttype-registry" calling init() xdk:client:[2016-01-27T08:14:24.108Z]: (1453882464108): Component "client:projecttype-registry" finished initialization xdk:client:[2016-01-27T08:14:24.112Z]: (1453882464112): Component "client:device" calling init() xdk:client:[2016-01-27T08:14:24.163Z]: (1453882464163): Component "client:device" threw exception during initialization client:adb:[2016-01-27T08:14:24.171Z]: (1453882464171): Can't find adb process. client:adb:[2016-01-27T08:14:24.172Z]: (1453882464172): Using default adb executable at "C:\Users\cre6027\AppData\Local\Intel\XDK\bin\adb\adb" xdk:client:[2016-01-27T08:14:24.179Z]: (1453882464179): Component "client:git-manager" finished delayed initialization xdk:client:[2016-01-27T08:14:24.188Z]: (1453882464188): Component "client:bower-package-manager" calling init() xdk:client:[2016-01-27T08:14:24.188Z]: (1453882464188): Component "client:bower-package-manager" finished initialization xdk:client:[2016-01-27T08:14:24.200Z]: (1453882464200): Component "client:projects-renderers-webapp" calling init() xdk:client:[2016-01-27T08:14:24.200Z]: (1453882464200): Component "client:projects-renderers-webapp" finished initialization xdk:client:[2016-01-27T08:14:24.205Z]: (1453882464205): Component "client:projects-renderers-jsapp" calling init() xdk:client:[2016-01-27T08:14:24.205Z]: (1453882464205): Component "client:projects-renderers-jsapp" finished initialization xdk:client:[2016-01-27T08:14:24.225Z]: (1453882464225): Component "client:projects-renderers" finished delayed initialization xdk:client:[2016-01-27T08:14:24.226Z]: (1453882464226): Component "client:cordova" finished delayed initialization xdk:client:[2016-01-27T08:14:24.239Z]: (1453882464239): Component "client:account" getting UI region for "account" xdk:client:[2016-01-27T08:14:24.239Z]: (1453882464239): Component "client:account" calling init() xdk:client:[2016-01-27T08:14:24.242Z]: (1453882464242): Component "client:account" finished initialization xdk:client:[2016-01-27T08:14:24.243Z]: (1453882464243): Component "client:project-selector" getting UI region for "project-selector" xdk:client:[2016-01-27T08:14:24.244Z]: (1453882464244): Component "client:project-selector" calling init() xdk:client:[2016-01-27T08:14:24.244Z]: (1453882464244): Component "client:project-selector" finished initialization xdk:client:[2016-01-27T08:14:24.248Z]: (1453882464248): Component "client:editor" calling init() xdk:client:[2016-01-27T08:14:24.248Z]: (1453882464248): Component "client:editor" finished initialization xdk:client:[2016-01-27T08:14:24.248Z]: (1453882464248): Component "client:live-preview" calling init() xdk:client:[2016-01-27T08:14:24.248Z]: (1453882464248): Component "client:live-preview" finished initialization xdk:client:[2016-01-27T08:14:24.249Z]: (1453882464249): Component "client:editor-tab" getting UI region for "develop" xdk:client:[2016-01-27T08:14:24.249Z]: (1453882464249): Component "client:editor-tab" calling init() xdk:client:[2016-01-27T08:14:24.256Z]: (1453882464256): Component "client:editor-tab" waiting for delayed initialization xdk:client:[2016-01-27T08:14:24.259Z]: (1453882464259): Component "client:tweets" finished initialization xdk:client:[2016-01-27T08:14:24.259Z]: (1453882464259): Component "client:projects-tab" getting UI region for "project" xdk:client:[2016-01-27T08:14:24.259Z]: (1453882464259): Component "client:projects-tab" calling init() xdk:client:[2016-01-27T08:14:24.260Z]: (1453882464260): Component "client:projects-tab" waiting for delayed initialization xdk:client:[2016-01-27T08:14:24.261Z]: (1453882464261): Component "client:test-tab" getting UI region for "test" xdk:client:[2016-01-27T08:14:24.261Z]: (1453882464261): Component "client:test-tab" calling init() xdk:client:[2016-01-27T08:14:24.261Z]: (1453882464261): Component "client:test-tab" waiting for delayed initialization xdk:client:[2016-01-27T08:14:24.268Z]: (1453882464268): Component "client:emulator" getting UI region for "emulate" xdk:client:[2016-01-27T08:14:24.268Z]: (1453882464268): Component "client:emulator" calling init() xdk:client:[2016-01-27T08:14:24.269Z]: (1453882464269): Component "client:emulator" finished initialization xdk:client:[2016-01-27T08:14:24.270Z]: (1453882464270): Component "client:build-tab" getting UI region for "build" xdk:client:[2016-01-27T08:14:24.270Z]: (1453882464270): Component "client:build-tab" calling init() xdk:client:[2016-01-27T08:14:24.274Z]: (1453882464274): Component "client:build-tab" finished initialization xdk:client:[2016-01-27T08:14:24.279Z]: (1453882464279): Uncaught top-level browser exception at file:///C:/Users/cre6027/AppData/Local/Intel/XDK/xdk/components/client/remote-tab/remote-tab.js:19:69: Uncaught TypeError: Cannot read property 'iosDebugImpl' of undefined Stack trace from browser: TypeError: Cannot read property 'iosDebugImpl' of undefined at file:///C:/Users/cre6027/AppData/Local/Intel/XDK/xdk/components/client/remote-tab/remote-tab.js:19:22644 at Object.context.execCb (file:///C:/Users/cre6027/AppData/Local/Intel/XDK/xdk/public/external/js/require-jquery.js:1615:33) at Object.Module.check (file:///C:/Users/cre6027/AppData/Local/Intel/XDK/xdk/public/external/js/require-jquery.js:851:51) at Object.<anonymous> (file:///C:/Users/cre6027/AppData/Local/Intel/XDK/xdk/public/external/js/require-jquery.js:1092:34) at file:///C:/Users/cre6027/AppData/Local/Intel/XDK/xdk/public/external/js/require-jquery.js:129:23 at file:///C:/Users/cre6027/AppData/Local/Intel/XDK/xdk/public/external/js/require-jquery.js:1135:21 at each (file:///C:/Users/cre6027/AppData/Local/Intel/XDK/xdk/public/external/js/require-jquery.js:57:31) at Object.Module.emit (file:///C:/Users/cre6027/AppData/Local/Intel/XDK/xdk/public/external/js/require-jquery.js:1134:17) at Object.Module.check (file:///C:/Users/cre6027/AppData/Local/Intel/XDK/xdk/public/external/js/require-jquery.js:905:30) at Object.Module.enable (file:///C:/Users/cre6027/AppData/Local/Intel/XDK/xdk/public/external/js/require-jquery.js:1122:22) [Log closed from xdk:client] xdk:server:[2016-01-27T08:14:25.937Z]: (1453882465937): memmrk: 27317536 45450496 xdk:server:[2016-01-27T08:14:30.937Z]: (1453882470937): memmrk: 27335268 45450496
Andrea_V_1
hi,
My problem started yesterday ...
I have send the log like you to the support ... but they don't respond !!!
I have also write and send log to: html5tools@intel.com
Massimo_D_
I found Why!!
With the last update of Kaspersky this problem appeared,
file "AppData\Local\Intel\XDK\xdk\node_modules\ref\build\Debug\binding.node" will be deleted by anti-virus because it be recognize as Trojan Virus ...  a very dangerous virus!!!
Try with EA version of intel xdk, with it start.....
Ok, now I know that Intel not consider who use Intel XDK for job.... interesting....
Andrea_V_1
Lol Massimo,
I have reinstalled intel XDK without kaspersky and all is OK ....
Now i put into the exception of kaspersky the file "AppData\Local\Intel\XDK\xdk\node_modules\ref\build\Debug\binding.node" ....
tks a lot
PaulF_IntelCorp
Unfortunately, the anti-virus problem has recurred. See this post for additional details > https://software.intel.com/en-us/forums/intel-xdk/topic/607054
