Software Archive
Read-only legacy content
17060 Discussions
Problem with cordova-plugin-whitelist
jeff_r_
Unlike other plugins the whitelist plugin is always seen as a newly added. Given this clicking the Chrome debugger under the XDK Debug tab ALWAYS results in an upload and rebuild to the cloud-based server. The resultant code works just fine, but this constant uploading and rebuilding is a problem - J
PaulF_IntelCorp
Are you adding the whitelist plugin manually to your app? The XDK will do that automatically, you do not need to add it to your project.
